Original written signatures vs. Copies/scans/faxes/electronic documents
MIREGMGR
A search reveals that this topic has been discussed here at considerable length...but without much actual evidence one way or the other.
Does anyone know of a written FDA stance or comment on original signatures vs. copies/scans/faxes, anywhere...?
Maybe in a 483, or some other obscure communication?
Our management wants to begin scanning must-retain signed paper records, then shredding the originals. The cost savings for storage space and office-staff labor would be significant.
The scanning would not be a Part 11 compliant process, since there is no live linkage at scan-time from the original document creator/signer to the identify assigned to the resulting scan-file.
:notme:
Marc
Are you referring to a physically written signature on a piece of paper?
MIREGMGR
Yes...as contrasted to an image or pixelization of that physical signature, and then the printing of that image onto a new piece of paper.
By the way, the title of the OP was edited to add "electronic documents"...which changes the direction to the thread in a way I had not intended.
21CFR Part 11 is quite clear regarding the requirements and handling of documents that never go through a paper stage, and signatures that are originally created and affixed in electronic form.
The intended question pertains to originally-paper documents that constitute FDA-required records and are originally signed in physical form, and whether the FDA has made any written statement as to the acceptability of a copy, scan or fax of such a physically-signed paper document as equivalent for regulatory purposes to that original physically-signed paper document.
I'm aware of several narrowly limited instances of such statements, i.e. 510(k) filings and mammography reports must have original physical signatures, and probably one or two other narrow categories. I'm looking for a general statement.
Marc
I did that purposefully to include the electronic signature aspect in case that was / is relevant.
Tell me if I did 'wrong'. I can easily change the thread title.
BradM
:notme:
An interesting question. I'm thinking there is something in a CFR, but I am unsure.
To me, this plays with the other thread on signing job descriptions. In regulated industries we have been so ingrained with the notion of signing everything, signature is everything, etc. I'll do some checking around.
MIREGMGR
Based on these guidelines by the FDA, medical device companies should not shred their originals.
I referred to the premarket-submission guidelines in my post above as "510(k) filings"...but these rules' signature requirements are specialized. I don't think they can reasonably be said to be applicable to all medical-device-maker records.
Please explain, though, how you're deriving general guidance on shredding of originals from this document. I can't find any such inference.
There is an explicit requirement for physical signatures in the mammography reporting guidance as well.
BradM
OK, now I'm getting confused.:D Requiring original signatures on documentation, and the method of archiving/electronically storing that documentation may be two different things. For example, you may have a policy of storing original documentation until, submission, ( or two years, or whatever), then scanning the document as best document available.
Are you wondering about original signature, archiving, or both?
MIREGMGR
The records in question are created on paper, and receive an original physical signature. The internal proposal is then to scan them, store the scans electronically, and shred the originals. A record that was to be subsequently referenced or otherwise utilized would be printed onto paper for that utilization process...thus simulating the original document, but with a reproduced signature instead of a physical original. As noted above, this would take place in a non-Part-11-compliant context.
Because it's relevant in focusing the discussion, the types of documents in question are production records for validated processes utilized to manufacture defined-sterile-packaged-lifetime batches of Class II single-use disposable devices. These records constitute part of our DHR for these products.
K
kathykru
I work for a drug company and have an ex-FDA Consultant on site doing a PAI Inspection, and this exact question was asked.
He stated that if you destroy the original, you must verify the scan to the original document first to confirm that the scan contains all of the original (pgs. and text) and is ledgible. This must be a documented activity.
Based on his recommendation, we are not going to destroy originals.
Hope this helps!
L Original Documentation - Need to maintain any original hand written documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
E Original Brand Labeler (OBL) in China China Medical Device Regulations 2
N Original signed IQ/OQ/PQ missing - but have data - Do we do it over? ISO 13485:2016 - Medical Device Quality Management Systems 2
T More than One Original Test Report - Original Print General Measurement Device and Calibration Topics 4
P Who is the OEM (Original Equipment Manufacturer)? EU Medical Device Regulations 5
G Original Data Copying to Maintain Compliance with 21 CFR Part 820.180 US Food and Drug Administration (FDA) 2
F Can you reference original FAI (First Article Inspection) after Delta? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
V Supplier Moving Manufacturing Location after original PPAP APQP and PPAP 4
T Stamping Original Paper Document 'Record Copy' in Red Ink - Document Control Document Control Systems, Procedures, Forms and Templates 4
H ISO 9001:2000 Certificate - Original approval date 18 July 1995 and valid until 2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
Q OEM (Original Equipment Manufacturer) PPAP Applicability Query IATF 16949 - Automotive Quality Systems Standard 4
P Benchmark of OEM (Original Equipment Manufacturer) Sourcing Audit Process Audits and Layered Process Audits 8
Marc "This American Life" reveals original Coca-Cola recipe World News 0
G OEM (Original Equipment Manufacturer) Calibration of In-House Measurement Equipment General Measurement Device and Calibration Topics 18
S Reference to original Calibration Certificate - ISO 17025 Section 5.10.9 ISO 17025 related Discussions 4
P Medical Device OEM (Original Equipment Manufacturer) Agreements Other Medical Device and Orthopedic Related Topics 5
P What's the original definition of "sigma level"? Capability, Accuracy and Stability - Processes, Machines, etc. 1
D Training Records - Requirement to keep original copy of training/assessment form? Records and Data - Quality, Legal and Other Evidence 12
Stijloor OEM (Original Equipment Manufacturer) Requirements for Global MMOG/LE Completion Customer and Company Specific Requirements 15
W Requirement to save original, handwritten internal audit notes? US Food and Drug Administration (FDA) 11
J Required to put original manufacturers on Approved Supplier List? Supplier Quality Assurance and other Supplier Issues 6
T Monthly SPC original data sheets - What should be done with the reports? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
E [Ask] Original Equipment Manufacturing/Manufacturer Misc. Quality Assurance and Business Systems Related Topics 1
S Definition OEM (Original Equipment Manufacturer) - Exact definition of OEM Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
D Can we destroy original paper files before retention period if we scan them? Records and Data - Quality, Legal and Other Evidence 17
Marc Reporter Discovers People Living In Original Star Wars Set Coffee Break and Water Cooler Discussions 4
Marc 40th Anniversary of the original Star Trek - From the I'm Getting Old Department World News 22
M Is TS16949 Only for OEM (Original Equipment Manufacturer) Customers? IATF 16949 - Automotive Quality Systems Standard 8
J Internal Audit Reports - Mandatory to keep original paper copy? Internal Auditing 16
R Retention of records - Original Order Form vs. Computer Entry record - ISO 13485 Records and Data - Quality, Legal and Other Evidence 12
D Need to get ISO recertified for a site change, but just near to the original site? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q European Legislation 76/769/EEC - Seeking the original legislation Various Other Specifications, Standards, and related Requirements 4
B Honda - What's different from US OEM (Original Equipment Manufacturer) requirements? Customer and Company Specific Requirements 4
C Procedures - New Revision or Original Issue - Upgrading to ISO9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
V Definition OEM - Definition of OEM - Original Equipment Manufacturer Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 8
Raffy Calibration Labels - Original Calibrating Date or New Date? General Measurement Device and Calibration Topics 9
G The Original "Introductions" Thread started in 2001 and split off October 2009 Coffee Break and Water Cooler Discussions 3892
V In-House Calibration vs. OEM (Original Equipment Manufacturer) Calibration General Measurement Device and Calibration Topics 2
D PPAP Master Parts - Do we have to save the original PPAP parts? APQP and PPAP 2
T ISO 13485 - Assembly instructions written vs. online ISO 13485:2016 - Medical Device Quality Management Systems 5
R Electronic and hand-written footnotes for GDP Document Control Systems, Procedures, Forms and Templates 1
I Does training have to be written? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
D Does every piece of equipment used in a laboratory need to have an IQ protocol written and executed? ISO 13485:2016 - Medical Device Quality Management Systems 1
J ISO 13485 Audit Nonconformance written against 6.3 Infrastructure ISO 13485:2016 - Medical Device Quality Management Systems 25
S Formal written response to a corrective action? Nonconformance and Corrective Action 9
L Part 11 Certified to legally binding of hand written signatures Other Medical Device Regulations World-Wide 3
R Importance of Written Procedures in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Registrar Charges Per CAR Written Registrars and Notified Bodies 18
H Most Poorly Written FDA Warning Letter Ever? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
A HSE Written Procedure Occupational Health & Safety Management Standards 6
