Originating and Approving Internal Procedures
P
pearson114
Is it acceptable for one person (QM) to originate and approve internal procedures? (against ISO9001/AS9100/AS9120).
Thanks.
Coury Ferguson
Moderator here to help
Re: Originating and Approving Procedures
Is it acceptable for one person (QM) to originate and approved internal procedures? (against ISO9001/AS9100/AS9120).
Thanks.
Yes, as long as your procedure states who has the authority to write and approve, in my opinion.
But, the best idea is to get the person (owner) responsible for the process be the writer and the QM as the person who approves the procedure. But again, this is my opinion.
Thanks.
It depends what you mean by 'acceptable', really! These standards don't prohibit such a thing, but you might want to ask yourself if it's desirable. If you look at the pros and cons, you may find that, with some exceptions, the QM shouldn't produce/approve the vast majority of QMS documentation - unless that person wants to have the burden of responsibility and accountability for everything found needing action in the future...:mg:
The Specialist
In my opinion you need to have more than one sign-off on any quality document.
Responsibilities should be defined as to who writes procedures on behalf of which department. It should then be agreed whom is responsible for the technical review and quality review of the document.
The process the OP describes undermines the QMS process IMO.
Any? What about forms, work instructions? It maybe good 'CYA' in the Pharmaceutical Industry, but wouldn't that be 'overkill' for most businesses...?
What are your thoughts to back up such advice?
The Specialist
Forms and work instructions are filled out by one member and then reviewed/approved by another are they not?
This in itself means that there is a different 'originator' and review/approver.
The purpose of the review and approval process (weather a peer review or quality review) is that any errors are immediately identified and rectified as necessary. Unfortunately, errors are made by even the most experienced professional.
Coury Ferguson
The bottom line here pearson114 is that ISO9001/AS9100/AS9120 does not specify who has to approve and/or originate the procedures. The Organization determines the authority and responsibilities in your documented procedure, in my opinion.
I don't think that's the case always. I have experienced a number of situations where someone writes something down - let's say a task they don't do very frequently - as a 'work instruction' and it's only they that do this work. Why would anyone else need to review/approve it?
BTW, checking for errors isn't really what this is about - given that you work in a highly regulated industry and that may be the culture - for those outside your industry...and the OP wasn't specifically asking about regulated industry.
The Specialist
Coury, I agree.
Perhaps I wasn't clear with my response.
You are right that there are no such stipulations. However I (personally) would question the effectiveness of a QM System that allows this to happen (same author/approver)
To the OP: I hear what you are saying about ‘over-kill’ with review and approval sign-offs. It is down to your organisation to determine what documentation requires this level of review. This will be determined by the importance of the document, technical content and probability of error (e.g. check-box forms may be considered out of scope of your review process).
I will stand by my original post though, when I recommend that the documentation example you gave in the OP be written, reviewed and/or approved by more than one member.
This just makes sound QM sense and adds strength to your QMS.
qusys
Thanks.
It depends on what you have established in your document control procedure in this sense, including the responbility and the authority to do so.
My opinion is that this process could be in jeopardy and not be effective, because the same person could emit a procedure by himsel/herself and approve, whitout sharing or finding agreement with other potentially impacted/involved process owners.:bigwave:
V Analysis of Raw Materials, as per pharmacopoeia ... of target OR originating country US Food and Drug Administration (FDA) 1
C Approving AWS as a supplier (ISO 13485) ISO 13485:2016 - Medical Device Quality Management Systems 4
M Suitable form or questionnaire for approving consultants Document Control Systems, Procedures, Forms and Templates 9
N Understanding, Challenging & Approving Supplier Control Plans FMEA and Control Plans 7
R Question of Approving Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
JoCam Approving a Test House on a Medical Device as a part of a 510k Submission 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Q Approving Software Suppliers in an AS9100 Company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
R Approving a New Hand Assembly Line at a Supplier Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Approving Suppliers by "Grandfathering" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
N Role of Quality Function in Approving Work Instructions Document Control Systems, Procedures, Forms and Templates 4
Q AS9100 Clause 8.3 - Control of Nonconforming Product Process for Approving Personnel AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T Approving Consulting Firms in a Medical Device Company ISO 13485:2016 - Medical Device Quality Management Systems 25
T Approving Suppliers - Approving Marketing Companies Other ISO and International Standards and European Regulations 10
L Approving myself as a Supplier - Should we be on our own ASL AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
M Gage R&R for Big Parts - Approving a Variable Gage using only 1 Part Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
G Does AS9100 require approving your Customer as a Supplier? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
J Re-approving documents when the responsible person leaves or changes responsibilities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
A Qualifying and Approving Equipment for Welding AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A Process for Approving Personnel Making Decisions - AS9100 Clause 8.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
B Approving Suppliers - Consultants AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
J Approving Suppliers under 7.4.1 - Approved Suppliers List - ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Approving Suppliers under 7.4.1 - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
Anerol C Who is Approving your Manufacturing Visual Aids / Process Sheets? Document Control Systems, Procedures, Forms and Templates 6
T Approving documents prior to issue - What guarantees their adequacy? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
lanley liao How to understand this words that the planning of internal audit shall take into consideration the results of previous audits? Oil and Gas Industry Standards and Regulations 10
A Add MDSAP to Internal Audit Schedule Medical Device Related Regulations 0
M ISO13485:2016, MDSAP and Internal Audits ISO 13485:2016 - Medical Device Quality Management Systems 8
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
S Would this be a second site for the purposes of internal and third party audits? General Auditing Discussions 4
V Internal Auditor Competency KPI IATF 16949 - Automotive Quality Systems Standard 14
J ISMS - Internal Audits Internal Auditing 3
M ISO 13485:2016 internal audit checklist Medical Device and FDA Regulations and Standards News 5
A Internal Audit Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
salaheddine96 Internal audit planning Internal Auditing 2
D CB and customer audits considered as internal audits? General Auditing Discussions 9
E MDR internal audit Internal Auditing 1
B Internal Auditor Competency - Product Auditors Internal Auditing 9
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
F Internal transfer of work from one line to another? Qualification and Validation (including 21 CFR Part 11) 3
B Looking for 10 Internal Audit Online Training Participants ISO 17025 related Discussions 2
R Monitor production quality - Internal KPIs Manufacturing and Related Processes 5
R IATF 16949 - Outsourcing of internal audits Internal Auditing 10
M Major vs. Minor for Internal Audits? Internal Auditing 10
T Internal Nonconformance procedure thoughts (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
