OSHA Requirements and NRTL Electrical Equipment Listing
W
w_grunfeld
My company develops and markets a NDT tester for Tube Inspections based on novel APR technology. It is CE marked for marketing in the EU region and as far as I am aware there is no commensurate legal requirement to market in the US. However, I am told that OSHA requires all employers to ensure all electrical equipment is NRTL listed. Is this a fact or just the common wisdom? The Tester is Type Certified under the applicable UL standard (UL 60950)
Stijloor
Any OSHA experts who can help Willy?
Thank you!
Stijloor.
MIREGMGR
...I am told that OSHA requires all employers to ensure all electrical equipment is NRTL listed.
Yes and no.
OSHA section 1910.303(b)(1)(i) requires, in general, that electrical equipment be suitable for installation and use in conformity with the provisions of that and the associated parts of OSHA. Generally, this provision is parallel to (and historically originated with) the essentially identical requirement in the National Electrical Code (NEC), an advisory consensus standard published by the National Fire Protection Association. Both OSHA and the NEC provide that suitability of equipment for an identified purpose may be evidenced by listing or labeling for that identified purpose.
As an alternative to listing or labeling, it's possible in theory to convince an OSHA enforcement authority, local electrical inspector enforcing the locally-adopted-by-reference NEC, or buying-organization purchasing agent, technician or engineer "following the rules" that directly provided documentation of testing and analysis--essentially, a Tech File--shows that an item of electrical equipment is suitable for the prospective user's intended purpose.
In practice this usually is not practical, because individual inspectors do not have the training and time to evaluate such an extensive NRTL-investigation-equivalent analysis, and those inspectors are permitted and expected by custom to reject equipment that is not prima facie acceptable.
In that regard, an NRTL listing or labeling indication is partly analogous to CE Marking, in that even though it's not legally mandatory it's nonetheless broadly expected because it efficiently communicates to individuals in the purchase-and-installation chain that an item will be safe and effective if used as directed.
Doug Tropf
From: http://www.osha.gov/dts/otpca/nrtl/1910refs.html
With respect to 1910.303 and 1910.307, the definition of "Acceptable" under 29 CFR 1910.399 specifies, with few exceptions, that conductors and equipment must be approved only by "nationally recognized testing laboratories." Similar definitions apply to the other sections that require approval.
W
w_grunfeld
Thanks for the clarification. I think approved by an NRTL can mean Type Test Certification, by an NRTL and not necessarily NRTL listing.
MIREGMGR
Yes, "tested" can be equivalent to "listed", as long as the test process was passed or approved.
http://www.osha.gov/dts/otpca/nrtl/1910refs.html#1910_303-307
You might want to obtain from the NRTL with whom you are working a formal statement to that effect, in case your salespeople get pushback from particular purchase-candidates who insist on the traditional language.
hogheavenfarm OSHA Regulations as Applicable ISO Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Work Environment - ISO 9001 Clause 6.4 vs. OSHA Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M OSHA Requirements for Fork Truck Training Occupational Health & Safety Management Standards 12
S OSHA and IEC61010 and IEC60601-1 - Varied Requirements Occupational Health & Safety Management Standards 1
S OSHA Requirements for air hose nozzle - Can it be metal or is it plastic? Occupational Health & Safety Management Standards 2
L OSHA Forklift Training Requirements - Qualification of the "trainer" Occupational Health & Safety Management Standards 9
B OSHA Top Ten webinar, March 31 (free online) [Deleted] Misc. Quality Assurance and Business Systems Related Topics 1
E OSHA - 1926.252(e) - Oily Rag Storage Occupational Health & Safety Management Standards 22
Sidney Vianna Interesting Discussion Legal compliance as part of ISO 45001 accredited certification. Major OSHA penalties in the USA. Occupational Health & Safety Management Standards 15
R OSHA - How often an employee needs to be Re-Trained on Safety Methods Occupational Health & Safety Management Standards 4
M AS9100 Re-Cert Audit - Auditor concerned with OSHA regulations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Scott Catron OSHA Hazcom GHS Implementation - June 1 2015 deadline Occupational Health & Safety Management Standards 8
S OSHA Form 174 Template Occupational Health & Safety Management Standards 13
G OSHA Requirement for Training on HAZCOM Occupational Health & Safety Management Standards 19
G Is there an OSHA Safety Accreditation? Occupational Health & Safety Management Standards 9
K NRTL mark per OSHA regulations - Preferences and experiences IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Possibly Unwarranted OSHA Citation Question Occupational Health & Safety Management Standards 7
Mikey324 How to Check for Legal (OSHA Federal & State) Updates Occupational Health & Safety Management Standards 5
S OSHA and UL 60601-1 Relationship Other Medical Device Related Standards 3
M Identifying Routine and Non-Routine Activities: OSHA OHSAS 18001 Occupational Health & Safety Management Standards 6
M Documentation for Health & Safety (OSHA) require ECO's? ISO 13485:2016 - Medical Device Quality Management Systems 11
T Status of Material Safety Data Sheet (OSHA Compliant) vs. 10993 Certificate US Food and Drug Administration (FDA) 5
M Management of Change regulations by the US EPA and the US OSHA Various Other Specifications, Standards, and related Requirements 4
C What should a temporary, remote location have in place to ensure OSHA compliance? Occupational Health & Safety Management Standards 14
J Safety requirement for snap-off ID strap - OSHA Requirement? Various Other Specifications, Standards, and related Requirements 3
Jim Wynne Interesting Signs - Possible new OSHA requirement? Funny Stuff - Jokes and Humour 7
M Recordable Injuries OSHA 300 Log - What kind injuries are required to be recorded? Various Other Specifications, Standards, and related Requirements 11
Z Audit Check List for Safety Machinery - Conformity with OSHA 1910 General Auditing Discussions 7
Marc BSI and OSHA Web Site Various Other Specifications, Standards, and related Requirements 1
S OSHA Exposure Limits - Regulations for Exposure Information Various Other Specifications, Standards, and related Requirements 1
Raffy OSHA vs. OHSAS 18001 vs. Work Environment - Clause 6.4 Occupational Health & Safety Management Standards 16
P UDI-PI requirements on reusable surgical device, do we need serialisation? ISO 13485:2016 - Medical Device Quality Management Systems 0
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J WAIVED ON Q1 - We Don't have to comply with FORDS customer specific requirements IATF 16949 - Automotive Quality Systems Standard 2
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
Techilady Ford Special Characteristics Communication and Agreement Form (SCCAF) provides production requirements? FMEA and Control Plans 4
P Requirements for being an European Representative EU Medical Device Regulations 3
C ISO 14001:2015 6.1.3 Compliance Obligations - Legal requirements monitoring ISO 14001:2015 Specific Discussions 0
lanley liao How to understand correctly the requirements of API monogram products Oil and Gas Industry Standards and Regulations 0
A GPS Regulatory requirements? Manufacturing and Related Processes 6
J SSQR-01 Vision Requirements- Color Blindness AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P ISO 14644 Class 8 Cleanroom Air Filter Requirements Other Medical Device Related Standards 4
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
R Weld Penetration Standards and Requirements Manufacturing and Related Processes 2
S Registration of Medical Device in Hong Kong - labeling requirements Other Medical Device Regulations World-Wide 0
L Requirements for Cables used for Low-Voltage DC Mains (12-36VDC) IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M AS9100D Registrar pre-audit requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
D LiPo battery minimum requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
