Our company is planning to file MDD not MDR next month. Do we require to show chemical characterization report ?
Our company is planning to file MDD not MDR next month. Do we require to show chemical characterization report ? We received the 510K for that device last year saying that this material is safe as it has long history of use, so no chemical characterization was done. Do we require to do that fir MDD ? or Literature information and history of safe use is sufficient ?
planB
Eksimar,
refer to ISO 10993-1:2018, which talks about _material_ (i.e. both chemical and physical) characterisation throughout the document, especially in section 6.1 "Physical and chemical information for biological risk analysis" - quote:
Gathering physical and chemical information on the medical device or component is a crucial first step in the biological evaluation [...] The extent of physical and/or chemical characterization required depends on what is known about the material formulation, what nonclinical and clinical safety and toxicological data exist, and on the nature and duration of body contact with the medical device. At a minimum, the characterization shall address the constituent chemicals of the medical device and possible residual process aids or additives used in its manufacture. [...]
If the combination of all materials, chemicals and processes has an established history of safe use in the intended application, and the physical properties have not changed, then it is possible that further characterization and additional data sets (e.g. chemical analysis of extracts or biological testing) will not be necessary. In this case the rationale shall be documented.
So if you have enough existing data at hand to demonstrate compliance to this section, no further material characterisation testing is warranted.
HTH,
Gerhard
levatorsuperioris
but.... you also need to know the manufacturing and handling residuals.... so generally you need analysis. Just because you are using Ti64 ELI does not mean you will pass an 10993 assessment, Ti64 ELI plus chemical characterization (or highly controlled) are required.
M Gap analysis Checklist - Software company planning to go for 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Transferring ISO 17025 from one company to another ISO 17025 related Discussions 1
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
F IVD registration in EU - Northern Ireland based company EU Medical Device Regulations 0
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
A AS9100D - Clause 8.1 Operation - Coating service company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
L Have been purchased by a corporate company ISO 13485:2016 - Medical Device Quality Management Systems 7
R Advice needed: Shall I report my not complying company to NB / competent Authority (Europe) EU Medical Device Regulations 6
lanley liao What shoud i do if our company top management has been changed. Oil and Gas Industry Standards and Regulations 8
S Malcolm Baldrige Company Dashboard Quality Tools, Improvement and Analysis 3
T IATF Rules for sharing production space with another company IATF 16949 - Automotive Quality Systems Standard 10
J Leveraging another company's ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
R MDEL and company affiliate Canada Medical Device Regulations 0
S Is QMS like a set of rules and regulations that a company follows? ISO 13485:2016 - Medical Device Quality Management Systems 10
E Contract manufacturer FDA requirements foreign company US Food and Drug Administration (FDA) 6
J How much to charge for helping a startup company with initial ISO 13485 certification? Consultants and Consulting 3
J Sister-company providing parts is only ISO 9001 registered IATF 16949 - Automotive Quality Systems Standard 7
D IATF 16949 Requirement for CMMI in a Global Company Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
M Address change for a company with CE/ISO13485 EU Medical Device Regulations 2
M IT validation for a paper based MD repair company QMS ISO 13485:2016 - Medical Device Quality Management Systems 6
M QMS for a repair/servicing company ISO 13485:2016 - Medical Device Quality Management Systems 2
C Internal Audits in a tiny Dx Company Internal Auditing 33
T ISO 13485 - 5.5.1 Responsibility and authority - Small Company Independence ISO 13485:2016 - Medical Device Quality Management Systems 13
F Quality manual for trading company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
L Implementing the PRRC role in a company EU Medical Device Regulations 7
BeaBea ISO 9001 Customer Feedback Methods - What has worked for your company? Service Industry Specific Topics 17
M Customers Request AS9100 certification - Small Company (less than 20 employees) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
U Document Approval - Software company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T EQMS for small medical device company ISO 13485:2016 - Medical Device Quality Management Systems 18
qualprod Corona virus Contingency plan - What have you done in your company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
Q Must product name be listed the same name in FURLS, UDI, GUDID and Company Website? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
E Sharepoint for ISO 13485 QMS for small IVD company ISO 13485:2016 - Medical Device Quality Management Systems 11
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
Z 510(k) usage - Company has 2 physically similar products Medical Device and FDA Regulations and Standards News 2
Q Company Ownership Change ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
L Contracted Manufacture Company wanting to be able to design and manufacture own product. 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
D ISO9001 for one man company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
T Client Communication - SaaMD company Misc. Quality Assurance and Business Systems Related Topics 3
R Notified Body for MDD 1Q20 - Florida Company Registrars and Notified Bodies 4
E In need of a new TGA sponsor - Small software company Other Medical Device Regulations World-Wide 4
F ISO 17025 8.8 Internal Audits in a segmented company ISO 17025 related Discussions 5
E Company A supplies pharmaceuticals to the MOI - Who is responsible? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J Quality Assurance in China - Developing a quality management system for a California company Misc. Quality Assurance and Business Systems Related Topics 9
S How to determine & document Organizational Knowledge of a company Document Control Systems, Procedures, Forms and Templates 4
U IT Process is Taken From company and Added to Corporate Structure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G Is ISO 9001:2015 certification worth it for a company that does only contract manufacturing? Quality Management System (QMS) Manuals 14
N Non traumatic edge - Remark in some of my company drawings EU Medical Device Regulations 1
