Our QS9000 audit team has been using checklists to perform internal audits
barb butrym
#21
what about a check mark as evidence of audit execution (record).....does not fly for me on the surface.....or any other auditor I know.......Maybe its a registrar quirk....but I have written up companies for that before....how hard depends on what else I see in the audit program and records of the audits. If there is an audit trail that provides evidence I back off... if all I see are check marks, then i find a evidence to show it was not effective, believe me if a company has to resort to just check marks, evidence will be there. I know I am a great advocate of 'do what adds value" BUT I draw the line here.....No trail --- no audit
Kevin Mader
One of THE Original Covers!
#22
Warning: projection to soon follow.
Doing something half committed often results in waste. If an organization wants to optimize the audit process, they must determine what the inputs are and if the outputs meet the expectations (a registrar's or thier own). Only then can they tailor the process to achieve their goals, save time and money, and keep the integrity of the audit program. These initial steps can not be "short cut" to the dismay of the organization looking only for the short-term gain. Being an advocate for value added is in my opinion correct. I would find a three hour internal audit with audit team formalized working papers and an audit report with plenty of objective evidence more valuable than a 45 minute check off on canned questions. I'm with you Barb. If a trail of objective evidence can't be uncovered and demonstrated in an audit report, hard to say if an audit took place at all.
Back to the group....
[This message has been edited by Kevin Mader (edited 15 June 1999).]
Marc
#23
My 2 cents - a check mark doesn't say shit. Either cite specifically what was looked at (the evidence) or there's no evidence there was an audit.
#24
Well, my audit group does both.
As the "owner" of the Internal Auditing Process, I do have a core group of "canned" questions, (modified from our original registrar's question list) that we use as a base.
Beyond that, I meet with the people who will be the audit team, and we review the procedures that are relevant to the area that we are going to audit. We add to the core question list, issues that are to be evaluated based upon the procedures that are relevant.
This system has worked very well. What we gain from it is is ongoing familiarity with the types of things that an outside auditor will be looking for as well as addressing the specific issues that go on at the facility from day-to-day.
As we move from audit to audit the "added" questions are different. Even if we are looking at procedures that have existed for years, we will either look at specific parts of that procedure (to create different auditable items), or check a look a new/different relevant procedures for a given element.
Bottom line... we have the core questions (or as some have called them "canned" questions) and add to them the Company-specific questions relative to our operations and quality system documentation. We end up with a fresh audit package each audit.
Thanks for allowing me to contribute!
ALM
#25
Everywhere I turn I hear value-added auditing.
But I never see anything on the "how" to do it. Any ideas?
Kevin Mader
#26
Dawn,
Try using flow charts as part of the audit process. Look for pauses and redundancy in the charts (i.e. did you have to repeat a step or did something remain stagnant)? As a matter of general commenting in the Audit Report, a statement should be made to inform the auditee of your discovery. From there, the auditee may use this information to improve the process, hence making the operation increase in value. Remember that auditors are interested in compliance to the program, but they are also interested in the effectiveness of the program too.
Regards,
Kevin
Howard Atkins
Forum Administrator
#27
One of the subjects that I have not seen covered here is the fact that checklists show proof of "planning audits".
We write checklists based on our procedures for our own guidance but in our procedure we have written that "according to the auditor's judgement he can ask more or other questions. We then write a report using the questions as headings. The creation of a checklist shows planning and refreshes the auditor on the purpose of the audit. It is also possible to add other questions based on incidents that have happened.
barb butrym
#28
Way back we did one on planning..Marc even has a couple plan things in the PDF ZONE. Things to include on a list are any followup/reviews of past actions from CA/PA, customer complaints, n/c material/process stuff, etc. observations from audits, as well as findings from audit reports (internal and otherwise)...
I typically include alot more in case a re-assignmant of auditors happes during the process, so work is not duplicated..my planning/status check list is http://www.qs9000.com/pdf_files/QF317-2.pdf in the pdf zone if you are interested...also include an input space on area check lists for info from the reviews.
Administrator Note: Hyperlink to barb's form added. I like barb's form. I also prefer, and use, copies of procedures as barb was writing about earlier in this thread. When using the 'copy of procedure' method you can come close to the 'check mark' audit, IMHO.
[This message has been edited by admin (edited 12 July 1999).]
spenceat
#29
I have recently started as a QA Manager and one of the first objectives I was asked to do was to produce an Intenal Audit Program.
One of my concerns was what is the best method while auditing a process or function, do I use a standrd set of questions on a checklist or do I use my own initiative.
After reading the above replies, it seems to me the best route forward is to use a procedure, make and ask questions relavant to that process or function and keep as objective evidence.
Since my internal auditing skills are limited, is there any best way of ensuring while using procedures as a form of checklist, the SCOPE of my internal audit schedules is still satisfying ISO requirements?
Andy
barb butrym
#30
there is much todo about that question andy....but let me add my 2 cents here before the group gets fired up.
Perform the audit to the procedures, then that done, answer the canned questions from what you observed/noted while auditing. Your audit trail, over time and experience, will have the details you need to determine whether the System is functioning properly. The audit trail is key. You should be able to recreate..many months later...the situations noted, both conforming and not. That and a cross reference of elements to areas will provide you all the information you need, of course that assumes (arrrrhhh I hate that word)the documentation has covered the shalls in the first place and has been properly cross referenced.
Add to the schedule... the 20 elements, then the scope of taht audit is to review the findings from all the audits in that element..for instance. Training....review all area audits for findings on training issues. I do this best with a report cover sheet (electronic) that has classifiations of findings, those include things like training, traceability, inspection status, stats, doc control, equipment, records, repeat occurrances, previous CAs issued/closed....what ever works, serves a quick reference for Management Review as well. This came from a retention report for the DoD I used to have to do, and adapted it to ISO.
[This message has been edited by barb butrym (edited 12 July 1999).]
Q Promoted to "Maintenance Manager - What should I expect in an ISO / QS9000 audit? QS-9000 - American Automotive Manufacturers Standard 6
A WE DID IT! Passed the muster of a QS9000 Certification Audit QS-9000 - American Automotive Manufacturers Standard 9
Marc Due Date for QS9000 Audit Response QS-9000 - American Automotive Manufacturers Standard 4
M Third day of our ISO 9001/QS9000/TE audit - What do we put on the letterhead? QS-9000 - American Automotive Manufacturers Standard 1
B QS9000's New Dock Audit Requirement QS-9000 - American Automotive Manufacturers Standard 13
L QS9000 Adequacy Audit Matrix QS-9000 - American Automotive Manufacturers Standard 2
R Is a complete Internal Audit prior to registration a direct requirement of QS9000? Internal Auditing 3
S Was QS9000 replaced by ISO/TS 16949 since December 2006? Document Control Systems, Procedures, Forms and Templates 4
M Where can I buy a copy of the QS9000 standard? QS-9000 - American Automotive Manufacturers Standard 16
P ISO/TS16949 Lead Auditor requirements - Transitioning from QS9000 to ISO/TS16949 General Auditing Discussions 6
Q QS9000 Tier 2 for 12 Years - Transitioning to ISO9001 - Where do I start? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
I AS9100 vs. QS9000 vs. ISO-TS16949 - Similarities and Differences AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L 7.3 excluded from Scope in QS9000, back in TS16949? IATF 16949 - Automotive Quality Systems Standard 1
B Converting from QS9000 to TS 16949 ... HOW? WHO? HOW MUCH? IATF 16949 - Automotive Quality Systems Standard 2
S TS16949 - QS9000 Gap Analysis and comparison matrix IATF 16949 - Automotive Quality Systems Standard 10
B Does anyone have a good cross reference from QS9000 to TS16949? IATF 16949 - Automotive Quality Systems Standard 2
Z ISO / TS16949 Quality Manual needed - Changing from QS9000 to ISO / TS16949 IATF 16949 - Automotive Quality Systems Standard 17
S SOP Numbering - About to change over from QS9000 to ISO 9001 Document Control Systems, Procedures, Forms and Templates 13
J Getting Rid of QS9000 Procedures that are no longer necessary with TS 16949 IATF 16949 - Automotive Quality Systems Standard 5
C QS9000 TE vs. TS16949 - Registration Applicability and Requirements Conflicts IATF 16949 - Automotive Quality Systems Standard 3
Manix Template of Supplement K from the QS9000 APQP manual APQP and PPAP 11
T qs9000 standard QS-9000 - American Automotive Manufacturers Standard 2
B TS 16949 Implementation - Upgrade from QS9000 - What are the Steps? IATF 16949 - Automotive Quality Systems Standard 1
M Advertising - Trucks with ISO9002, TS16949, ISO14001, & QS9000 written on them IATF 16949 - Automotive Quality Systems Standard 2
M ISO 9001 vs. QS9000 vs. ISO 14001 - Job interview tomorrow night for a QM position Career and Occupation Discussions 4
K The "Shalls" of QS9000 T&E Supplement QS-9000 - American Automotive Manufacturers Standard 4
J QS9000 Management Review - Review every section and sub-section of the manual? Management Review Meetings and related Processes 3
J Powerway Software - We are moving from QS9000 to TS 16949 Quality Assurance and Compliance Software Tools and Solutions 2
S QS9000 to TS16949 Transition - How difficult was it, REALLY?? QS-9000 - American Automotive Manufacturers Standard 4
Raffy ISO9001:2000 Transition from QS9000 - Or Both? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Raffy Training to QS9000 QS-9000 - American Automotive Manufacturers Standard 1
S TS16949 Prerequisite - An organization must already be QS9000 certified? QS-9000 - American Automotive Manufacturers Standard 19
Y QS9000 officially obsolete and replace by TS 16949? QS-9000 - American Automotive Manufacturers Standard 3
J Big 3 can hold your QS9000 registration hostage! QS-9000 - American Automotive Manufacturers Standard 22
R QS9000 Software - Has anyone heard about QSP a UK Package QS-9000 - American Automotive Manufacturers Standard 0
A ISO 9001:2000 Vs QS9000 QS-9000 - American Automotive Manufacturers Standard 0
M Six Sigma - Las similitudes entre six sigma y qs9000 Six Sigma 2
R Writing QM for QS9000 & ISO9K2K QS-9000 - American Automotive Manufacturers Standard 5
P QS9000 manuals revision outdated QS-9000 - American Automotive Manufacturers Standard 7
H FMEA Comparison QS9000 and VDA 4.2 FMEA and Control Plans 2
R Ford, QOS and QS9000 QS-9000 - American Automotive Manufacturers Standard 3
S iso 9001/qs9000/iso14001 QS-9000 - American Automotive Manufacturers Standard 2
C QS9000:1998 TO ISO 9001:2000 + ISO-TS 16949:2002 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J QS9000 supplier reqts Supplier Quality Assurance and other Supplier Issues 3
B Product ID, Inspection and Test Status, - QS9000 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M QS9000 to TS16949 QS-9000 - American Automotive Manufacturers Standard 11
J Calibration lab reqts for QS9000 (TS also?) QS-9000 - American Automotive Manufacturers Standard 2
D QS9000 "compliant" QS-9000 - American Automotive Manufacturers Standard 5
W SPC all the time? Does QS9000 require statistical control on all processes? QS-9000 - American Automotive Manufacturers Standard 3
D Red, Yellow, and Green and QS9000 Suppliers - Visual evaluation of the status QS-9000 - American Automotive Manufacturers Standard 2
