Out Of Tolerance Gauge And Holding Back Quarantined Product
BRUCE R.
I would like to know what is the proper way to handle out of tolerance gauge in reference to holding and quarantined product. If a gauge has a calibration interval of one year how can you possibly go back and check product made up to a year ago. With more and more manufacturers not holding product in their warehouses for long periods of time how can they possibly go back and check their product against a out of tolerance gauge? How should the calibration lab notify the production floor?:( :(
D.Scott
That is one of the hardest problems you will face in regard to calibration. Your records should indicate where the gage is being used which should give you an idea of what has been measured with it. From there, you may be able to determine what has been sent out. Your system should allow you to evaluate the effect the OOT gage had on the final product. If, for example, you knew the gage was being used to measure a non-critical characteristic and maybe the product underwent a subsequent quality check, maybe you wouldn't need to do anything.
On the other hand, you may determine the gage was OOT past a "safety" point so you would have to notify the customer they "MIGHT" have some suspect parts.
As to the one year interval, I would assume you don't use the gage without verifying the state of calibration. For example, the date on the label is confirmed, the instrument inspected for dirt/damage and zeroed out before use. In our shop, if a gage were dropped , dirty, or wouldn't zero, the operators would take the gage to the lab. I am sure there are a some reasons why a gage could be off without giving you an indication but most should be found before use. I guess if you are still worried about the interval you might consider using a validation block daily before using the gage.
Dave
BRUCE R.
We have in place many of the things you have suggested. During our last audit, the auditor ask a question about a notice we send out to notify the department heads about a OOT gauge. The notice has two paragraphs asking the department head to choose one. The paragraphs ask them if the out of tolerance condition warrants the product to be quarantine or not. The auditor ask us how can you quarantine the product if it is already been shipped. I guess I'm looking for a way to word our out of tolerance notice that will satisfy everyone if that's possible.
You could add a sub-option to the quaratine option asking if the risk warrants notifying the customer of suspect product having shipped.
BRUCE R.
You gentlemen have made some good suggestions and thanks for your help. I will be meeting with my quality supervisor today and hopefully put this item finally to bed.
ugurkavi
Registered Visitor
Umm, what about Gage R&R in regular intervals? Wouldn't that help catching a varitaion that would be due to out of tolerance gauge?
G
Grizz1345
I agree this is the great black hole for calibration. When I worked at Pratt&Whitney Aircraft any gage used to check a part was serialized and that number was put on the paperwork for that part. There was no exceptions. Since then I have worked in the auto industry and it is wide open. Very often our parts are on a customers car before the gage is found to be bad. What we do is have the appropriate manager sign a statement to the effect that the out of tolerance gage did not affect the overall quality of the product. I am not sure this is valid or even good business, but it is what we do at the present time. Short of holding all parts until the gages that checked them are calibrated I am not sure there is a perfect answer to your problem.:cool:
BradM
Some really great suggestions, here. By the posts I can tell everyone are old pros at this stuff, but I will throw some things out there for consideration.
First, let's make the assumption that within a stable system, instruments should not be out of tolerance (O.O.T). The processes are fairly stable, instruments are in good working order, appropriate uncertainty ratios are assigned, intervals set correctly, etc. So, something is not working like it should.
Could you increase the tolerance? Buy more reliable instruments? Buy standards with less uncertainty? Could you establish say process limits, where the instrument may be O.O.T. by say 1 PSI, but set a process limit for 2 PSI?
So if an instrument is O.O.T., is the instrument drifting, standard bad, etc.? By what magnitude is the unacceptable error? The magnitude may not be great enough to significantly affect the product.
As mentioned earlier, possibly some Root Cause analysis to determine the O.O.T. cause. Shortened interval, intercomparison verifications, and limited calibrations may be alternatives also.
I realize this is 1st grade stuff and some of this things costs time and money, but if I had what I would deem as "critical exposure", I would do everything in my power to eliminate the O.O.T. involving customer notification, shipped product, etc.
C Gauge R&R %Tolerance Template for One-sided Tolerance - Wire Pull Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Out of tolerance gauge blocks - How did these blocks go out of tolerance? General Measurement Device and Calibration Topics 21
R Circularity tolerance of 0.25mm - The correct Go/NoGo gauge size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Gauge (Gage) R&R study - Samples required from full tolerance spread? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 13
S Tolerance limits for micro balance General Measurement Device and Calibration Topics 1
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
WEAVER Electronic Weighing Scale Calibration Tolerance Manufacturing and Related Processes 1
Ronen E Tolerance intervals (?) question - Flow Rate Probability Range Statistical Analysis Tools, Techniques and SPC 6
D Tolerance when verifying an analytical balance General Measurement Device and Calibration Topics 3
E Discussion between co-worker on tolerance and uncertainty and how to apply it. Thoughts? 17025 ISO 17025 related Discussions 1
O Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
T GRR based on part tolerance or process variation. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Excel OOT (Out of Tolerance) Formula Excel .xls Spreadsheet Templates and Tools 3
S Question about a basic additive variance/tolerance example Quality Tools, Improvement and Analysis 2
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Y How to fix weight tolerance for plastic injection molded part? Does it vary with material groups? Manufacturing and Related Processes 1
F Position tolerance check gage manufacturing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
M GD&T tolerance or band? Using a symbol like parallelism // Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Gage R&R without tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
V Using K-Factor(Tolerance Interval) Analysis for Design Verification Statistical Analysis Tools, Techniques and SPC 3
C Acceptable NDC for %GR&R part inspection to Tolerance (%Tolerance) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Cpk for Unilateral Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 7
S Doubts about SPC taken in Machining - Part has +-0.01 Tolerance Statistical Analysis Tools, Techniques and SPC 5
A Calibration tolerance for data logger General Measurement Device and Calibration Topics 3
N Straightness Gage Tolerance General Measurement Device and Calibration Topics 0
G Calculating Tolerance of a Panel Meter with a 2 degrees of an Arc General Measurement Device and Calibration Topics 0
kedarg6500 Excel spreadsheet for Unilateral Tolerance Study wanted Excel .xls Spreadsheet Templates and Tools 2
U Control Charting a Feature with Bonus Tolerance Quality Tools, Improvement and Analysis 10
J Process Capability - How much percentage of tolerance? VDA Standards - Germany's Automotive Standards 3
B Gage R&R MSA - Variation, Tolerance, Variance by different methods IATF 16949 - Automotive Quality Systems Standard 23
R Fixing of tolerance limit - Electronic weighing balance with the capacity of 150 Kgs General Measurement Device and Calibration Topics 5
bobdoering Unilateral Tolerance Capability Calculations Capability, Accuracy and Stability - Processes, Machines, etc. 1
bobdoering Unilateral Tolerance Capability Calculation Imported Legacy Blogs 0
H Tolerance, decimal places, and measuring equipment capability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Out of Dimensional Tolerance - MRB Audit Issue Nonconformance and Corrective Action 11
P Profile Tolerance and CPK Manufacturing and Related Processes 3
J Position Tolerance Called to Datums with MMC Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M 10 parts, 3 operators, 3 measurements GR&R study tolerance question Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
