Ovality and Flatness generated after Heat Treatment of Rolled Rings
Chennaiite
Never-say-die
Please suggest why the ovality is generated after normalzing of rolled ring
I have encountered this problem in Hardening & Tempering. For me, what you have asked is a million dollar question. I have conducted enough experiments to conclude the problem, but ended up losing to Heat treatment process. Causes include Geometry of the part (in your case wall thickness may be less), location of part in the trolley, stacking method in the trolley, metallurgical specification of the part before HT, Furnace controls, etc. BTW, not just rolled part, even Forged & Machined parts do not make exempt from this problem.
BTW, thanks for raising this point.
bobdoering
Stop X-bar/R Madness!!
Any time you try to heat treat to a final geometric condition - whether it is a dimension or form feature - you are risking capability doom (unless you have a wide open tolerance.) It is as difficult as dialing in the height of a loaf of bread from the oven.
machrk
Distortion can occur during heat treatment processes - are parts being uniformly heated all the way through ? Was there some residual stress prior to heat treatment ? Are parts constrained from expansion - contraction in any way during the heating & cooling processes ? A metallurgical forensic "CSI" approach can help if you are having ongoing problems - all too often there isn't just a single cause to a problem - there may be multiple factors acting together..
I'd also suggest that you try the Eng-Tips forum website - lots of folks there with shop floor workshop knowledge on how to avoid probs like this - start here
cheers
@SteelyQueen aka machrk (also @KerrieAnne) :)
(Mechanical Testing Lab & QMS Manager - Bachelor of Metallurgy)
R Gage R&R Study - Within Job Variation (Ovality, Taper) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
hogheavenfarm GDT Flatness measurement question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
F Flatness VS parallelism Design and Development of Products and Processes 6
B How to do a control chart - Machining product that requires flatness control Capability, Accuracy and Stability - Processes, Machines, etc. 1
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
G From an ISO 17025 auditor perspective must micrometer calibration check anvil flatness? General Measurement Device and Calibration Topics 4
I Flatness - Rectangular part using the three jack method Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
N Do I need to approach galvanized steel sheet flatness issue with DOE? Problem Solving, Root Cause Fault and Failure Analysis 9
G How to compute or estimate a micrometer or caliper flatness using optical flat General Measurement Device and Calibration Topics 2
W Standard for Micrometer Anvil Flatness Oil and Gas Industry Standards and Regulations 5
G Caliper or Micrometer's Dimensional Flatness General Measurement Device and Calibration Topics 5
C Flatness Measurement Errors from a Datum - Test Method General Measurement Device and Calibration Topics 3
P Checking flatness with Go and No Go Jig Manufacturing and Related Processes 2
J Flatness measured to locations of a plane Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
B Result of a Flatness MSA on a CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
C Measuring Flatness of a Pump Cover General Measurement Device and Calibration Topics 14
N The right method to Measure and Evaluate a Flatness Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
F Reason a plane would have a runout applied and not a flatness callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
E Flatness Measurement of Plastic Molded Parts - Clamping / Holding Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Micrometer Parallelism and Flatness Calibration Requirements and Specs General Measurement Device and Calibration Topics 10
G Determining flatness and parallelism rapidly Manufacturing and Related Processes 2
Q Micrometers to Measure Coating Thickness - Failed Calibration Flatness & Parallelism General Measurement Device and Calibration Topics 9
optomist1 GD&T Flatness Automatic Indirect Control Rule #1 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 20
B Flatness Call Out confusing me - What they are wanting and how to check it? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 42
C Surface Plate Calibration - How to verify the flatness of a granite surface plate General Measurement Device and Calibration Topics 1
B Inspection Tools for Flatness and Channel Depth of Bipolar Fuel Cell Plates Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Techniques for Measuring Flatness General Measurement Device and Calibration Topics 37
Z Inspection of Flatness of a part using an electronic device Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
W Warping / Flatness SPC - X bar-R chart - Control is Max 0.15 Statistical Analysis Tools, Techniques and SPC 5
D Flatness tolerances for tempered cold rolled stainless steel coils Manufacturing and Related Processes 3
Proud Liberal Flatness / Straightness / Bow specification Various Other Specifications, Standards, and related Requirements 12
D Optical flats - "FLATNESS INTERPRETATION CHART, Light Wave Band Pattern Guide" General Measurement Device and Calibration Topics 4
D Looking for 100% sort testing equipment for overall length, flatness, and parallelism General Measurement Device and Calibration Topics 1
S What is the best method for checking the flatness of a flexible part? General Measurement Device and Calibration Topics 4
S Customer Generated Purchase Orders Quality Manager and Management Related Issues 3
S Customer generated PURCHASE ORDERS Customer only sends Schedules ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D QMS Performance Based on how many NCRs were generated month to month Nonconformance and Corrective Action 8
E How do you perform a GR&R for system software generated values? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
L Arima Output - Relationship between my raw data and the residuals generated Using Minitab Software 1
M ACPAC Accounting System Generated Forms - Part of ISO? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
I New ERP system - Need Doc. Numbers for ERP generated PO's, Packing Slips, etc? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M All Internally Generated Documents ? Required to be Controlled or Not All? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
V Digital Product Definition (DPD) - Computer generated drawings Software Quality Assurance 8
Y Measurement of Force (Newtons) generated General Measurement Device and Calibration Topics 9
S Number of CAPAS (Corrective Preventive Action) Generated in a Company Nonconformance and Corrective Action 1
I Does ISO 9001 requires the Control of All Records generated? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M System Level Root Causes for each individual CAR generated in the system? Problem Solving, Root Cause Fault and Failure Analysis 10
J Must accounting software generated forms be numbered? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P Can anyone help with ESD Protection (PCBA)? How is ESD generated? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
