Oven Calibration Range: How many points?
Hi guys,
We have several ovens here were I work, and we have always used either:
1. A single point calibration because the oven is used at a single point at a particular process (we have a limitation label on the oven stating the exact temperature point we calibrate at)
2. A range calibration, using only 2 points
An internal auditor brought up the point that a calibration is defined as 3 points within a range, so would using 2 points not considered a true calibration?
The temperature ranges for example are:
45-85°C
40-130°C
We have the requester fill out a "Calibration Assessment Form" where they have to document their process tolerance (working range). From this information, we then determine if we have the correct standard (4:1), and to list the calibration range we will be using, taking account the process tolerance.
Example
40-85°C with a process tolerance of ±3°C.
We would then use the following test points for calibration:
37 & 88°C.
Anyone see a problem with analogy? Should we be using 3 points?
Hershal
Metrologist-Auditor
I would suggest for single points, just run cal at those points.....
For a range, low and high ends of the range and a mid-point.....if the range is large enough, say 30 C or more, add 1/4 and 3/4 points, just to chart the linear curve.....
Of course, the cal could also be done in accordance with ASTM Standards.....
Hershal
Al Dyer
Great,
I think that linearity would be the greatest cause of variation in an oven and needs to be verified. As a simle test at home just put a thermometer in your oven and watch how accurate it really is over its operating range.
Al...
Jerry Eldred
Ihave always used "3 Points is a calibration" for the reason that they equate to offset, gain and linearity. If you only calibrate to 2 points you only have offset and gain, but not linearity.
The other detail I wondered about was chamber profile. Do you profile the oven chamber? That is often more of an issue than controller accuracy. I've calibrated many ovens over the years and seen chamber inaccuracy far exceed that of the controller.
A very loose definition of the profile is verifying uniformity of the physical parts of the chamber you use for your process. The common method is a 9-point profile, where you check the eight corners of a "box" (the cubic area of the chamber used for the process), and a center point.
Hope this doesn't stir up the pot too much.
Thanks for all the replies. I forgot to mention that when the oven is new, we perform a thermal profile per mfg's specifications. We have a procedure that dictates how many sensors to use, and how uniformity is calculated. We also determine the average temp, min, max, variance, greatest difference between all sensors, and finally uniformity. We normally don't do a uniformity check again unless the oven was repaired, or baffles were adjusted.
When we check most ovens, it usually involves placing a single temperature sensor in the middle of the oven. In the past, we have used a type T SLE thermocouple, but we are now moving to using RTD's for better accuracy in order to maintain a 4:1 calibration ratio.
celestica - 2005
In our plant, we calibrate using a 10-probe hygrothermograph. We check only the temperature/s in which the oven is used. We then check the graph and if the graph is not linear, we subject the oven for troubleshooting.
Q
Quality-Misfit - 2008
I have a small oven that I would like to calibrate it's used to dry parts only the range is 90°F ± 5° . Can some provide information on how to do this correctly to meet ISO requirements?
Qulity-Misfit
BradM
Qulity-Misfit
Hello there!
There are three different checks you can do:
1. Verify the controller is accurate. Usually, you will hook up to it with a simulator and verify it's accurate. If the controller has been made within the last ten years, it should be fine.
2. Verify the controller with the sensor. You can pull the sensor out of the oven and place it in a calibrating furnace/oil bath, or use ice/boiling water with a standard probe. Although not as optimal, you can use a standard probe and place beside the control sensor while it is installed.
3. Make a performance verification of the uniformity of the oven, or verification of a "sweet spot" in an oven. Say there is one spot that is used, and it is clear to all that products don't go anywhere else, then you can verify that one spot.
All of this will involve having a traceable standard for verification. In specific applications like yours where the oven runs at a constant temperature, many drop a calibrated thermometer in the top of the oven (assuming this is a benchtop or something like that) and have the measuring tip of the thermometer inches within the product to be measured.
Assure the thermometer is calibrated and has acceptable accuracy. I would get a spare.
Q
Hello there!
It is a benchtop oven very small footprint. We do have a calibrated Fluke 177 that can measure temperature. Don't I have to write a calibration procedure for this if so what is the format?
Thanks,
Quality-Misfit
Al Rosen
I would keep it simple. For a small drying oven you can place a thermocouple in the center and take measurements for 3 cycles to confirm that it stays within the temperature. If you only use it at 90 deg, then do it at that temperature and identify that it is used at 90 deg.
W Equipment for Oven Calibration, Uniformity and System Accuracy Tests AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Traceable Calibration Of An Oven Thermometer General Measurement Device and Calibration Topics 4
M TS 16949 and Form, Fit or Function? What about Calibration of Oven Controllers? IATF 16949 - Automotive Quality Systems Standard 5
K Pyrometry Question - Furnace and Oven Instrument Calibration IAW AMS 2750 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
B Calculating Measurement Uncertainty in Oven Calibration (using thermocouples) Measurement Uncertainty (MU) 4
W Is an Oven I/O/Q Validation Required or is Calibration Sufficient? Qualification and Validation (including 21 CFR Part 11) 7
B Temperature Gage on an Oven was Out of Calibration Period General Measurement Device and Calibration Topics 15
N Bench Top Oven Calibration Standards General Measurement Device and Calibration Topics 8
R Setting Calibration Tolerance on Gauges - Oven Calibration and Stepped Plug Gage General Measurement Device and Calibration Topics 10
A Oven Controller Specifications - BAC5621 and AMS2750F AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J CQI-9 - Can OEM do Oven Studies? Reliability Analysis - Predictions, Testing and Standards 1
S Performing PQ on a Small (tabletop) Air Heat Treating Oven ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Auditor states my Oven Thermocouples must be Calibrated General Measurement Device and Calibration Topics 18
I Is it common practice for a bake oven to require a CQI-9? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D How to Calibrate and Verify a Heating Oven General Measurement Device and Calibration Topics 3
J Moisture Detection and Measurement in Vacuum Oven (Plastic Dryness) General Measurement Device and Calibration Topics 2
WEAVER Thermocouple Extension Wire for Temperature Measurement in an Oven General Measurement Device and Calibration Topics 9
N Is Air Burst test for oven treated condoms still required under ISO 4074? Other Medical Device Related Standards 1
P NADCAP Certified - Heat Treat Continuous Belt Driven Oven question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
N Can a Calibrated Digital Thermometer be used to monitor my oven? General Measurement Device and Calibration Topics 12
W Oven Leak Test Method - Integrity of the chamber to hold gas Qualification and Validation (including 21 CFR Part 11) 3
M Validation of Processes - Is Cl 7.5.2 applicable to bricktile firing in an oven? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S Oven Qualification - Thermal profile during the OQ of a vacuum oven General Measurement Device and Calibration Topics 6
P VMP template for a Dry Heat Depyrogenation Oven FAT thru PQ Document Control Systems, Procedures, Forms and Templates 1
T Oven Validation Protocol (procedure) needed General Measurement Device and Calibration Topics 19
R Paperless Chart Recorder to Monitor Oven Cycle Temperatures Manufacturing and Related Processes 5
Adriane Need Help to Verify an Infrared Cure Oven General Measurement Device and Calibration Topics 9
Marc Convection Oven Cooking - If you have one, do you like it? Cooked a turkey yet? Coffee Break and Water Cooler Discussions 17
W Leak Detection - Oven Seals General Measurement Device and Calibration Topics 1
G MSA Studies on heat shock tests - Should we just be calibrating the oven? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
W Next Calibration Due Date Calibration Frequency (Interval) 5
