Over Complicated Work Instructions
bobdoering
Stop X-bar/R Madness!!
#11
There's nearly always a period of surveillance of new employees with the intention of verifying competency. We can assume that an electronics technician knows how to solder, among other basic skills (which is a reasonable basis for hiring), so we should be able to assume that such a person doesn't need to read a work instruction or be trained in those areas.
That may or may not be a valid assumption (although a common assumption) - however, if you believe it is (and you have iron clad hiring processes) the process I provided to track and resolve any evidence to the contrary (in the cases where the assumptions end up failing) for that issue will surely cover that.
bobdoering
#12
That is where a process likes to pass on "urban legend" undocumented process requirements - such as "this company's definition of the visual requirement for a cold solder joint" (or even better: "this shift's definition of the visual requirement for a cold solder joint.") Sometimes it works for a while.
Rand T
#13
Sounds like they were preparing for the need for temps - which would fall under that definition.
They moved permanent employees around from dept. to dept quite often, and never had the time to train to the instructions, so there was a lot of "Sally, train Juan on what to do" which usually meant that a lot of what was in the instructions was omitted.
bobdoering
#14
Yes, that is a classic methodology for passing on urban legend and tribal knowledge information. It has issues with consistency and tracking of the origin of the methods ("we have always done it that way...but we have no idea why"), but is acceptable for many TCE quality level processes.
arios
#15
This is a note from the ISO 9001 std, in section 4.2.1.:
"NOTE The extent of the quality management system documentation can differ from one organization to another due to
a) the size of organization and type of activities,
b) the complexity of processes and their interactions, and
c) the competence of personnel."
I think it says it all. Your documentation can be tailored to your needs. For instance, if your personnel is competent to do a certain task, then you don't have to write in detail how to they are supposed to "connect the dots"
bobdoering
#16
Absolutely. If you never have an internal or external corrective action that goes back to the instructions not be clear or thorough enough, then you are on the right track. But, the point is YOU need to understand the risks based on the hiring practices (which may change based on the available pool), or the ever raising bar of customer expectations, that may not be adequately communicated through past "competence" or via urban legend.
The caveat is whether you are satisfied with the clarity or comprehensiveness of your documentation and are willing to let your customer tell you when you are not. The degree of detail is not a function of "not enough time" - that is not on the ISO list above.
adickerson
#17
Yes, there are a lot of assumptions that will build up using this logic - they key one being: "Were they trained properly at previous jobs?" One way to gage this is if there is a need for a corrective action on a process that falls under the "believed to be previously trained" portion area, good time to scrap the notion and develop training.
Hate to have the customer be the "sorter" for this problem, but if your truly fear redundant training (especially more than you fear customer rejections), it is an option. It is the option the minimalists will revel in.
Assessing the training at other sites or developing a training program is not in the scope of a Work Instruction. Work Instructions should be specific to a process and should provide the details specific to the process.
I don't have any problem with training or employee testing and evaluation. Like I said Work Instructions and Job Descriptions go hand in hand. Evaluating workers and testing skills should be done...just as part of training and not in the reference documents of a production line.
When it comes to new employees and customer rejections I will say this - if one employe can mess up entire processes and then this can get to the customer without any detection then the problem is not with the training but with the system. Remember, "improper employee training" is never root level corrective action. Detection of problems should be build into any process - trust your worker is doing a good job, just verify to be sure.
bobdoering
#18
Exactly.
Yeah, people try to sell that all the time...and yet, they still hold some importance to training. Interesting paradox, is it not? It might work as long as you have no visual or other sensory inspection as detection. "They" do like to blame "the system". It is a nebulous enough of a target to never be wrong. Interesting to exclude training from the "system", huh?
...trust your worker is doing a good job, just verify to be sure.
Trust and verify. But verify to what? Usually the work instructions. I typically feel if a worker makes a mistake, and there was no work instruction to identify to problem, it is your fault, not theirs. If there is a work instruction, and you have evidence they were trained, then you have something to hang your hat on.
JaneB
#19
I worked for a previous company that came up with this silly corporate requirement that every step in an instruction had to state the following for every single step;
What?
Who?
Why?
When?
Where?
So for instance, not only did you have to say something like "zero the digital indicator" or "place the part on the fixture" you had to state the answers to those 5 questions for every single step.
Yikes.
Good idea to make sure it's covered off overall... but in every single step?
Only if 'the person off the street' were presumed to be doing a step at a time with zero comprehension let alone memory of the previous step... in which case the management of the company has some serious shortfalls.
U EU-MDR: Complicated supply chain EU Medical Device Regulations 4
P Nonlinear Fit for a Complicated Curve - Fitting a Function to the Data Statistical Analysis Tools, Techniques and SPC 6
I Control Plan Overdone (Overly Complicated) or Not FMEA and Control Plans 21
B Complicated Production Process - Sub-Process Documentation Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Customer Satisfaction in a very complicated organization. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Design Control Issues - Toolroom says the system is too complicated Design and Development of Products and Processes 15
J Instructions for use for Class I devices under MDR EU Medical Device Regulations 1
T ISO 13485 - Assembly instructions written vs. online ISO 13485:2016 - Medical Device Quality Management Systems 5
U Intended Users in IFU (Instructions for Use) EU Medical Device Regulations 5
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
K EU MDR Annex 1 Chapter III: Information in the Instructions for Use-23.4 (e) the performance characteristics of the device; EU Medical Device Regulations 1
J Documentation structure - Do I need Work Instructions? Document Control Systems, Procedures, Forms and Templates 23
C Work Instructions; Controlled/Uncontrolled? Document Control Systems, Procedures, Forms and Templates 5
M User manual / instructions for use for class II device always required? Medical Device and FDA Regulations and Standards News 3
L MDR - Information in the instructions for use - clausole 23.4.(z) EU Medical Device Regulations 2
S ISO 18223-2 Temperature symbol in the Legend table in the Instructions for Use Other ISO and International Standards and European Regulations 4
S Providing IFU (Instructions for Use) in multiple languages EU Medical Device Regulations 0
M Informational The USFDA Continues to Remind Facilities of the Importance of Following Duodenoscope Reprocessing Instructions: FDA Safety Communication Medical Device and FDA Regulations and Standards News 0
Z IFU (Instructions for Use) Symbol - 7010:M002 - can it be in black? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
I Document levels and approval requirements for lower level documents like work instructions, forms etc. Document Control Systems, Procedures, Forms and Templates 18
N Electronic Instructions for use (eIFU) EU Medical Device Regulations 2
Marc Elsmar Xenforo Software Instructions #2 - 9/2018 Elsmar Xenforo Forum Software Instructions and Help 0
Marc Elsmar Xenforo Software Instructions #1 - 9/2018 Elsmar Xenforo Forum Software Instructions and Help 0
M Batch record supersedes all other instructions 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N Updating class I device IFU with instructions to use class II cleared device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
H SPC Work Instructions (WI) Statistical Analysis Tools, Techniques and SPC 2
S Are 2 Hard Copies of Procedures and Instructions Required? ISO 13485:2016 - Medical Device Quality Management Systems 6
K IATF 16949 Cl. 8.5.1.2 - Requirements of Work Instructions and Documents IATF 16949 - Automotive Quality Systems Standard 2
J Work Instructions - We have approx 1,000 work instructions from over the years Document Control Systems, Procedures, Forms and Templates 8
Ajit Basrur Incoming Inspection for Instructions for Use (IFU) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Product Instructions (IFU) - Placement Requirements - ISO 13485:2003/2016 Other ISO and International Standards and European Regulations 2
C Manufacturing Process Work Instructions - Format Manufacturing and Related Processes 4
D 207/2012 Update for MDR (?) - Instructions for Use (IFU) EU Medical Device Regulations 9
R How to Control Videos as part of the QMS Documented Procedures and Instructions Document Control Systems, Procedures, Forms and Templates 2
D eQMS/ERP System Admin Work Instructions - Where do they fit? Misc. Quality Assurance and Business Systems Related Topics 5
R ISO 50001 - Manual and instructions Sustainability, Green Initiatives and Ecology 8
C Following Order of Work Instructions ISO 13485:2016 - Medical Device Quality Management Systems 23
M CAPA due to Consumer not following Maintenance Instructions... Nonconformance and Corrective Action 9
V Suggest Packing Instructions for Electrical Control panel Document Control Systems, Procedures, Forms and Templates 4
Q Allowed no manuals, technical instructions traceability in products ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Video Screencasts for Work Instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Process Changes, but Work Instructions/Process Maps are not updated ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
O Regulatory Notification for IVD IFU Instructions Revision ISO 13485:2016 - Medical Device Quality Management Systems 3
Q Help sections in Software Programs as Work Instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Should we have Work Instructions for HR or not Document Control Systems, Procedures, Forms and Templates 5
M Who should write Departmental Work Instructions Document Control Systems, Procedures, Forms and Templates 6
S Informational Please help this newbie understand ISO 9001 Work Instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 44
T Work Instructions for Assembly vs. Disassembly Misc. Quality Assurance and Business Systems Related Topics 11
S Do Work Instructions have to be in harmony with the related Control Plan? Document Control Systems, Procedures, Forms and Templates 1
