Over-labelling the manufacturers name at the front of the device
JoCam
Hi All,
If I was to purchase a class I medical device from the US to distribute in Europe would I be able to over-label the manufacturers name at the front of the device with my company's name, and change the product name by over-labelling? The OEM's name and address will still be on the label bearing the CE mark on the back of the device.
Jo
rob73
looking for answers
Re: Over-labelling
If the device is CE marked it take it the device is already on the market in the EU, if so then it may fall under "parallel imports".
https://www.gov.uk/government/publications/parallel-imports-of-medical-devices
If not you will need to be careful not to end up as the "manufacturer" under OBL rules.
Personally i would just add a "supplied by JoCam" label and leave the OEM's detail still on there.
Is there a big issue with leaving the OEM name on the packaging?
JoCam
Re: Over-labelling
Thank you Rob,
I'm not sure if the device is being sold in Europe, so yes, you could be right and we may end up being a parallel importer.
We may want to remove the original manufacturer from everything except the on-product label that carries the CE mark. Can this be done, or can we only put our name on the device if we state that we are the distributor? Also, I'm concerned about changing the product name, as surely this is important for the CE mark.
I, personally, am with you on just adding our company name stating "distributed by", but need a standard or regulation to back this up before I break the bad news to the rest of the group.
Jo
JoCam
Re: Over-labelling
Thanks again Rob, but we don't wish to go down the Own Brand Labelling road, so I suppose this means we should be affixing a "distributed by" label each time we apply a label with our company name on. I was wondering whether OBL could be avoided by keeping the original manufacturers details on the CE mark label alone.
Jo
rob73
looking for answers
Re: Over-labelling
Yes, looking at your reply again it does seem to fall into a bit of a grey area as the device itself would not be changed, but saying that if you put your details and a CE mark you would surely be taking regulatory responsibility for the product?
Could it be regarded as a procedure kit?, which enable a "manufacturer" to put existing CE marked products into different packaging so long as the intended use is not changed.
There is a bit in the article.
http://www.emergogroup.com/blog/2008/05/are-you-considered-medical-device-manufacturer
JoCam
Re: Over-labelling
Hi Rob,
We're not putting our name on the CE mark label, that will still carry the original manufacturers name and address. We don't wish to take regulatory responsibility for the device. I just need to know whether we can replace the manufacturers name in all other places on the device, and change their product name to include a product name of one of our devices.
Jo
rob73
looking for answers
Re: Over-labelling
If the "outer" packaging does not have a CE mark then should be no issues, if however it does, it could be implied that you CE marked it, as just by looking at packaging you could not tell the device inside had a different manufacturer and CE mark.
Best thing to do is ask your certification body for clarification.
pkost
I would be extremely cautious about over labeling product with your details, especially the product name. The product name is typically listed on the DoC and therefore intrinsic to the conformity of the product; similarly the company name, although this is slightly less of a concern if the "manufactured by" details aren't covered.
Distributed by stickers are quite common, although I have always seen them stuck over a non critical area
I would suggest if you want to do this, you work with the manufacturer for them to create the product in the form you would like, instead of trying to tread a fine line - there is nothing to stop them from manufacturing a product that references yours and contains more of your branding and less of theirs - it would also look more professional
JoCam
Thank you pkost,
I've made the decision to over-label the manufacturer name but not change the device name. The manufacturer will be aware of what we are doing, so some kind of distributor agreement will be set up. It also transpires that we will be buying the product to rent out and not sell.
Thank you again,
Jo
N Over labelling in Japan Japan Medical Device Regulations 1
P Labelling of an Accessory EU Medical Device Regulations 2
C Labelling translation of word "contents" EU Medical Device Regulations 1
M Medical Devices Regulations and labelling requirements UAE Other Medical Device Regulations World-Wide 0
S Labelling Questions (use of color and symbols) US Medical Device Regulations 1
D UDI-DI and UDI-PI labelling EU Medical Device Regulations 1
ChrisM Re-labelling purchased power supply EU Medical Device Regulations 1
E MDR Labelling & Languages EU Medical Device Regulations 2
C Labelling and UDI Requirements - Implications of serial numbers US Medical Device Regulations 1
H OTC DRUG Private Labelling Distributor: GMP REQUIREMENT ISO 13485:2016 - Medical Device Quality Management Systems 0
J UDI and Labelling hierarchy and requirements for separate device components EU Medical Device Regulations 7
H Medical Device Labelling ISO 13485:2016 - Medical Device Quality Management Systems 11
S Design & Development records for Medical Devices Packaging and Labelling ISO 13485:2016 - Medical Device Quality Management Systems 9
S Third party accessory registration and labelling Other US Medical Device Regulations 4
T Design Traceability - Labelling / Instructions for Use ISO 13485:2016 - Medical Device Quality Management Systems 5
F Labelling to comply with both FDA and MDR US Food and Drug Administration (FDA) 6
D Labelling and IFU deadlines EU Medical Device Regulations 3
JoCam Importer Labelling EU Medical Device Regulations 1
D Change to labelling - does it require a new 510(k)? US Food and Drug Administration (FDA) 5
A Medical device labelling Date of manufacture US Food and Drug Administration (FDA) 3
M Labelling - Is there a guidance or regulations that specifically defines the 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Barcode Labelling - Mistake Proofing Ideas & Systems Manufacturing and Related Processes 2
Z Labeler Code - Private labelling for OTC (Over the Counter) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
Z NHP Health Canada Private Labelling Other ISO and International Standards and European Regulations 4
P New Global HQ Suggestions for Virtual manufacturing/own brand labelling of medical devices? EU Medical Device Regulations 5
Anonymous16-2 Labelling Training Training - Internal, External, Online and Distance Learning 3
D IVD (in vitro diagnostic) Labelling Requirements - 98/79/EC CE Marking (Conformité Européene) / CB Scheme 2
S Article 22 Procedure Pack Labelling EU Medical Device Regulations 5
F Labelling requirements for a medical device containing fragrance allergens EU Medical Device Regulations 3
H Re-labelling in IVDD - Re-label two products and package them as one CE Marking (Conformité Européene) / CB Scheme 5
S Industry Labelling Standards - non medical Manufacturing and Related Processes 0
JoshuaFroud Serial numbers and labelling when sharing device components ISO 13485:2016 - Medical Device Quality Management Systems 1
T Colour of symbols on Medical Device labelling and packaging Other Medical Device Related Standards 1
B Practical ideas for information labelling in healthcare environment IEC 27001 - Information Security Management Systems (ISMS) 2
G FDA UDI markings "label" vs. "labelling" (labeling)? US Food and Drug Administration (FDA) 4
R US FDA Mandatory Labelling contents for an OTC medical device US Food and Drug Administration (FDA) 0
M Technical File (STED) labelling - When you compile tech files do we have to include all the product labels? EU Medical Device Regulations 2
M Over-labelling - Any requirements or best-practices? Other Medical Device Regulations World-Wide 0
TheMightyWife Address Change - Medical Device Packaging Labelling Requirements EU Medical Device Regulations 7
S Labelling in Medical Device Software IEC 62304 - Medical Device Software Life Cycle Processes 8
M Is "Made in (Country)" a labelling requirement? Other Medical Device Regulations World-Wide 8
N Own brand labelling/virtual manufacture of IVD's EU Medical Device Regulations 4
M EN 374-2 One time test and labelling Other Medical Device Related Standards 0
V Software medical device labelling EU Medical Device Regulations 8
JoCam UDI - Direct Labelling EU Medical Device Regulations 9
JoCam Medical Device Final Assembly Labelling EU Medical Device Regulations 2
J Malaysia - Full Labelling Local Language Translation Other Medical Device Regulations World-Wide 1
S Adding claims on medical device labelling 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Labelling Requirements for USB-Powered Device Other Medical Device Related Standards 1
J0anne Alternatives to 'Latex Free' Labelling Other Medical Device Related Standards 9
