Hi! I'm working with the compliance of a company assembling lines of analysis instrumentation for biological analysis. The company doesn't design any of the instruments themselves, they purchase finished, CE compliant instruments & machines and assemble them into larger workflows based on each customers requirements. They also write software to talk to all instruments and facilitate/coordinate the operation of each instrument in the assembly.
As I've understood it, an installation like this can fall into two definitions:
1) Assembly of Machinery in the Machine Directive (definition taken from §38 of Guide to the Application of the Machinery Directive)
For a group of units of machinery or partly completed machinery to be considered as an assembly of machinery, all of these criteria must be fulfilled:
− the constituent units are assembled together in order to carry out a common function, for example, the production of a given product;
− the constituent units are functionally linked in such a way that the operation of each unit directly affects the operation of other units or of the assembly as a
whole, so that a risk assessment is necessary for the whole assembly;
− the constituent units have a common control system – see §184: comments on section 1.2.1, and §203: comments on section 1.2.4.4 of Annex I.
2) Fixed Installation in the EMC Directive (definition taken from EMC Directive, Article 3 (3))
‘fixed installation’ means a particular combination of several types of apparatus and, where applicable, other devices, which are assembled, installed and intended to be used permanently at a predefined location;
I believe in this instance it should be considered an Assembly of Machinery since all instruments in the line are assembled together to carry out a common function (analysis of biological samples), they are linked in a way that the operation of each unit directly affects other units in the line, and they have a common control system in that they are operated by the software suite developed by the company I'm working with. If I'm correct in this interpretation of the MD, then a full conformity assessment should be carried out.
Where I'm hesistant is if this would also be classified as a Fixed Installation according to the EMCD? If that is the case, then how should I interpret the following clause from the EMCD (§36):
Due to their specific characteristics, fixed installations need not be subject to the affixing of the CE marking or to the EU declaration of conformity.
I doubt that this clause would allow the company to ignore the MD (and any potential LVD requirements as well)?
