Oxygen gauge on Nitrogen supply
K
Kevin H
#11
I've got to disagree with posts made so far. I spent about 8 years working as a field engineer for Airco Industrial Gases (BOC Gases & I think Air Liquide now, I haven't kept track of the mergers). Pressure is pressure, doesn't matter if it's oxygen, nitrogen, helium, hydrogen, etc. What does matter is that guages identified as being cleaned for oxygen service have been specially cleaned to remove all traces of oils, greases, etc. that could react with oxgen and create a mini-bomb. You wouldn't believe what can burn or initiate a fire or explosion in an oxygen line - a particle of rust going too fast in a flow stream and hitting an elbow in a black iron pipe is enough to start a fire that will ignite the pipe!
What is important is that any flowmeters are correctly made for the gas being measured at the pressure and temperature it's being used at. Ideally, your flowmeter has label on it saying for nitrogen @ xyz pressure & yy temperature. Even that is not super critical, as long as you realize that you can develop a revised flow based on the gas, the pressure, the temperature of the gas, and do so. It's not an incredibly hard calculation - we did it a lot in the field for demonstrations when we didn't have the correct flowmeter (We absolutely did not use a fuel gas or notrogen flowmeter in an oxygen line.) On the other hand, that was 20 years ago, so the details are a little vague as to what equations to use. A lot of the flowmeters installed in large lines are pressure and temperature corrected automatically using pressure and temperature sensors.
As to shmos bypassing the planned safety of not being able to add a fuel gas cylinder to an oxygen line, our safety updates were full of very creative ones who managed to do things like that and the resulting catastrophes.
Oxygen safety was something we took seriously - I shut down 2 projects becasue of safety issues. In one, the customer's engineer had rejected our help in sizing piping and had selected a valve that was too small to adequately flow the amount of oxygen needed without exceeding safe velocities. In the second, the plant had cleaned black iron oxygen piping with acetone at the recomendation of their chemist. Acetone leaves a residue that is potentially explosive in an oxygen atmosphere. I refused to permit our piping to be connected to the plant's oxygen lines until the issue was corrected.
ScottK
Not out of the crisis
#12
You have worked for a couple of our major customers and I agree with your oxygen cleaning points. We have very strict procedures in place for part that are purchased "Clean for O2 Service" and we are audited by our customers for this.
However - The reason I advise changing the gauge isn't so much from an unsafe condition standpoint (as you say - pressure is pressure) but from an auditor standpoint.
If I was doing a compliance audit and I saw that I would latch on and dig-dig-dig to make sure there AREN'T any unsafe conditions elswhere. Because that just screams "sloppy" at me.
#14
WOW, a big :thanks: to everyone for their input.
Having had a night to think about it, I'm going to write it up as a non-conformity in the audit report. This will ensure it gets reported at Thursdays quality review meeting.
As for Al's last question, what would happen if you put oxygen in a gauge that has been used on nitrogen?
Regards
Paul
SteveK
#15
Paul,
As indicated in the thread, special care is needed with Oxygen supplies wrt grease, contamination, materials of construction etc due to the possibility of ignition or explosion. This is why gas regulators (e.g. for reducing 200bar to typically 4 or 7 bar) when they are used for medical purposes are tested for Adiabatic Compression (ignition) to ISO 10524-1. Other than the labelling on their faces, bourbon gauges for Oxygen or Nitrogen (or another gas) have the same construction (as Kevin H indicated pressure is pressure). Obviously gas regulators (certainly in a medical context) should have correct labelling on their gauges (as would be specified by the gauge purchaser), but so long the gauge was oxygen compatible (see first point), in answer to the new question – nothing! Regulator fittings (in the UK - Bull Nose or Pin Index) that connect to the cylinder are the gas specific component, together with gas specific outlets (that would connect e.g. to a gas specific hose assembly - again in a medical context). If you were naughty, you could if it is possible, remove the front of the gauge and remove or change the gas reference.
Steve
#16
Steve
Thank you for the clear explanation. The plan is to change the gauges with nitrogen specific ones and chuck the oxygen ones.
It'll give the facilites team something to do............
:thanx:
Paul
ScottK
#17
Regards
Paul
Nothing.
We use nitogen to set and test most of our "clean for O2 service" parts. In fact, in order to mistake proof our assembly operation we use no compressed air in our assembly or cleaning areas at all. All of our testing and setting is done with Nitrogen and, on occasion, Helium.
The reason for this is that compressed air is generally lubricated and we can't have those lubricants getting into the parts.
N Medical Devices in oxygen rich environment IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P IEC 60601 11.2.2 - Oxygen Rich Environment sources of ignition IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Oxygen enriched environment applicability - Operating table used in general surgeries in hospital IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
C Requirements for dissolved oxygen and/or head space oxygen in Pharmaceuticals Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
S Oxygen mask and nebilzer mask Applied standards EU Medical Device Regulations 2
M Regulations for oxygen/air-tubing and connectors inside of ME equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
F Heat and Moisture Oxygen Port Changes Classification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
T CFDA issues notice for Small Oxygen Respirators (9/16/2013) China Medical Device Regulations 0
B Defining Expected Oxygen Leakage for Safety Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Ronen E Nidek Medical Class I recall: Medical Mark5 Nuvo Lite Oxygen Concentrators Other US Medical Device Regulations 0
N Chemical Oxygen Demand (COD) Determination in Industrial Waste Water General Measurement Device and Calibration Topics 5
R Testing Medical Equipment used in conjunction with Oxygen Rich Environments IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
M Oxygen Data Logger that we can place with each shipment via aircraft ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T Is Oxygen a Drug per FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
A An Example of a Risk Analysis Report for a Class II Medical Device (Oxygen Mask) ISO 14971 - Medical Device Risk Management 29
A Recreational Oxygen Concentrator - FDA or other requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
H Oxygen Purity Requirements - Oxygen to use in electrical arc furnace ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Risk of fire in an Oxygen rich environment - Fire Prevention - IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
F Oxygen Concentrator Hazards ISO 13485:2016 - Medical Device Quality Management Systems 9
ScottK Oxygen Cleaning and Surfactants used for leak detection Various Other Specifications, Standards, and related Requirements 1
S Do we need to submit our memory foam oxygen mask gasket for FDA approval? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C How about the classification under 93/42/EEC? Sterile oxygen mask ISO 13485:2016 - Medical Device Quality Management Systems 7
G Process monitoring of portable & stationary oxygen units: Can we use Cpk, Ppk, SPC ? Capability, Accuracy and Stability - Processes, Machines, etc. 3
G Process monitoring - Stationary and portable oxygen units ISO 13485:2016 - Medical Device Quality Management Systems 1
C Gauge R&R Question Using Minitab Software 1
J Gauge Suggestion: Specialty or Custom General Measurement Device and Calibration Topics 1
I How many gauges in a Go/No Go Gauge? General Measurement Device and Calibration Topics 7
J Designing new gauge tracking software IATF 16949 - Automotive Quality Systems Standard 4
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
K I’m looking for a square probe for my linear height gauge Manufacturing and Related Processes 1
A Gauge Study for Small Lots Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Supplier Checking With Gauge Pin Problem Solving, Root Cause Fault and Failure Analysis 2
H Analog Pressure Gauge with no EN837 accuracy class information General Measurement Device and Calibration Topics 5
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
R Do Brands Matter When Purchasing Bore Gauge? General Measurement Device and Calibration Topics 2
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G Comparing Gauge Blocks - Translating the calibration between the master set and the QA set General Measurement Device and Calibration Topics 2
F Gauge R&R & Calibration Intervals Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
Ron Rompen Source needed for Spline Form gauge (GO and NOGO members) General Measurement Device and Calibration Topics 3
S Gauge R and R - Product - Conveyor belt with threads that goes on Sprocket Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
