OXYGEN RICH ENVIRONMENT analysis
rothlis
Hi all,
We are looking at using compliance with clause 11.2.2.1 to establish whether it is safe to use our device in the operating room during clinical research, where it will be used at the patient's ears. Despite Peter Selvey's observation that the standard is actually concerned with areas inside the ME EQUIPMENT, we are conservatively assuming that leaks from a mask or nasal cannula could feasibly result in an oxygen concentration > 25% in the immediate area where our device is used.
Our design meets the criteria of "a source of ignition" according to Figure 36 due to the presence of 40 V on a capacitive circuit. The 300 trial ignition test does not easily fit into our current schedule, so we were hoping that we could build upon the standard's advice that "Items 4) and 5) address the worst case where the atmosphere is 100 % oxygen, the contact material (for item 5) is solder and the fuel is cotton. Available fuels and oxygen concentrations should be taken into consideration when applying these specific requirements. Where deviations from these worst case limits are made (based on lower oxygen concentrations or less flammable fuels) they shall be justified and documented in the RISK MANAGEMENT FILE."
Does anybody have any experience justifying deviation from the worst case limits? Our thinking was that the best way to do this would be to locate the origin of the Figure 36 graph and work from the data which informed it to generate a new graph based on our less-than-worst-case conditions, but we have been unable to track that down. Or are there any other suggestions on how to tackle this?
Thanks in advance.
Peter Selvey
Personally I would start with some experiments. Stand alone oxygen sensors are not that expensive so you could place them around your device either fitted to some volunteers or dummy set up and see how feasible it is to create >25% with an oxygen leak. It could eliminate the discussion about the applicability of Clause 11.2.2.
Also it's worth to have some perspective on the intent of flammability requirements and the relationship with the 25% limit. Normal flammability tests like FV-0 (UL 94 V0) are not designed to eliminate flame or ignition, but instead to show that a fire would be extinguished within a certain timeframe (10s). The point is to ensure that an electrical device does not propagate fire easily. These tests are done in 21% Oxygen (natural air) and assumed to be valid up to 25%. For higher concentrations of oxygen, the time taken to extinguish could be longer than 10s, therefore higher oxygen concentrations could invalidate FV-0 and other flammability ratings. Hence the standard uses 25% as a switch to decide if clause 11.2.2 is applicable or not, because it affects propagation, not ignition.
In terms of patient safety, 10s is already too long time if something is catching on fire directly on the patient e.g. at a person's ear. Also there may be plenty of material around which is highly flammable at 21% such as hair or clothing. Therefore, parts that directly contact the patient should anyhow be designed with negligible risk of ignition. The level of oxygen may still impact the probability of ignition, but the potential for ignition still exists even at 21%.
Of course, this issue applies to a wide range of medical devices that directly contact the patient (for example, pulse oximeter, temperature probe), but in practice no one really worries about it. The reason is that low power secondary circuits have inherently negligible risk from ignition.
I'm struggling to find a reason behind the 0.5µF/35V criteria for capacitive circuits. Actually for both the resistance and capacitive circuits, the sparking is determined as much by stray parameters in the circuit (e.g. self inductance) rather than the capacitor/current value itself. I can only guess that experiments were performed years ago that found 0.5u/35V to be the threshold, but it would hugely depend on the length and gauge of cabling, capacitor type and so on. Perhaps a special pulse capacitor with 1m of wiring? I suspect that modern high density SMD caps with short wires would struggle to make a spark let alone have enough energy for ignition of surrounding material.
rothlis
Thanks Peter. We appreciate getting your expert input on this.
We were going to try and do some estimation based on diffusion, but this sounds like a good back-up if the analysis looks dubious.
Since posting, we're pretty sure we found the source in Kohl et al 2000. There's a sparse set of data points that, along with added safety margin, were translated into the plots we find in Figures 35 - 37. Given the limited data set, there isn't really much there for extrapolating to different conditions. And they didn't test above 30 V on the assumption that relevant designs wouldn't need more than that.
N Medical Devices in oxygen rich environment IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P IEC 60601 11.2.2 - Oxygen Rich Environment sources of ignition IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
F Risk of fire in an Oxygen rich environment - Fire Prevention - IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
R Testing Medical Equipment used in conjunction with Oxygen Rich Environments IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
S Oxygen Generator - Classification EU Medical Device Regulations 3
M Oxygen enriched environment applicability - Operating table used in general surgeries in hospital IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
C Requirements for dissolved oxygen and/or head space oxygen in Pharmaceuticals Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
S Oxygen mask and nebilzer mask Applied standards EU Medical Device Regulations 2
M Regulations for oxygen/air-tubing and connectors inside of ME equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
F Heat and Moisture Oxygen Port Changes Classification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
T CFDA issues notice for Small Oxygen Respirators (9/16/2013) China Medical Device Regulations 0
B Defining Expected Oxygen Leakage for Safety Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Ronen E Nidek Medical Class I recall: Medical Mark5 Nuvo Lite Oxygen Concentrators Other US Medical Device Regulations 0
N Chemical Oxygen Demand (COD) Determination in Industrial Waste Water General Measurement Device and Calibration Topics 5
M Oxygen Data Logger that we can place with each shipment via aircraft ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T Is Oxygen a Drug per FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
A An Example of a Risk Analysis Report for a Class II Medical Device (Oxygen Mask) ISO 14971 - Medical Device Risk Management 29
A Recreational Oxygen Concentrator - FDA or other requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
H Oxygen Purity Requirements - Oxygen to use in electrical arc furnace ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
sonflowerinwales Oxygen gauge on Nitrogen supply ISO 13485:2016 - Medical Device Quality Management Systems 16
F Oxygen Concentrator Hazards ISO 13485:2016 - Medical Device Quality Management Systems 9
ScottK Oxygen Cleaning and Surfactants used for leak detection Various Other Specifications, Standards, and related Requirements 1
S Do we need to submit our memory foam oxygen mask gasket for FDA approval? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C How about the classification under 93/42/EEC? Sterile oxygen mask ISO 13485:2016 - Medical Device Quality Management Systems 7
G Process monitoring of portable & stationary oxygen units: Can we use Cpk, Ppk, SPC ? Capability, Accuracy and Stability - Processes, Machines, etc. 3
G Process monitoring - Stationary and portable oxygen units ISO 13485:2016 - Medical Device Quality Management Systems 1
E Rich O2 Environment Testing Laboratories (Clause 11.2.2 ME EQUIPMENT and ME SYSTEMS) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
B How does Forbes calculate networth for their Rich List ? Coffee Break and Water Cooler Discussions 0
Marc If I was a Rich Man - Flying car production rolls forward World News 4
P How to retire rich? Coffee Break and Water Cooler Discussions 90
S Environment Monitoring System Validation ISO 14001:2015 Specific Discussions 1
W Strategy for determining which components from a system should be "ME EQUIPMENT" -- home healthcare environment IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
optomist1 QAQC In A Pure Transactional Environment Service Industry Specific Topics 2
L ESG - Environment Social & Governance ISO 14001:2015 Specific Discussions 4
Sidney Vianna Informational ESG - Environment, Social & Governance issues gaining ground in the Business World Sustainability, Green Initiatives and Ecology 22
L Job Aids for administrative staff in GLP environment Document Control Systems, Procedures, Forms and Templates 6
D Controlled Environment requirements Miscellaneous Environmental Standards and EMS Related Discussions 1
D Infrastructure: Equipment, Work Environment and Contamination Control ISO 13485:2016 - Medical Device Quality Management Systems 4
F Hi friends, can anyone show me an example of a procedure for ISO 13485 6.4.1 Work Environment? ISO 13485:2016 - Medical Device Quality Management Systems 4
M Informational US FDA draft guidance – Testing and Labeling Medical Devices for Safety in the Magnetic Resonance (MR) Environment Medical Device and FDA Regulations and Standards News 0
B Practical ideas for information labelling in healthcare environment IEC 27001 - Information Security Management Systems (ISMS) 2
I CAP/CLIA Environment - Part 11 Compliance Qualification and Validation (including 21 CFR Part 11) 3
G Infrastructure and Environment for the operation of processes (ISO 9001 7.1.3 & 7.1.4) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Informational DITTA White Paper on Cybersecurity: Best Practices in the Medical Technology Manufacturing Environment Medical Device and FDA Regulations and Standards News 0
I Documents for Manufacturing Environment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
L PC in patient environment - BF applied part that uses USB to connect to PC IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
M AS9100d (section 7.1.3) example of compliance in machine shop environment. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
G ISO 17025 - Requirement to Monitor Environment ISO 17025 related Discussions 10
