P value not greater than 0.05 for Capability Analysis
Cognizant
As part of validation we did 3 PQ runs each run with 4 cavities. Total 36 data sets with 30 data points each.
We are ok on 34 data sets for which pvalue is greater than 0.05 and Cpks > 1.33.
We are struggling with the last two data sets for which p value < .05 but CPKS are way above 1.33. We did all the investigation and we could not figure out what is causing this issue. I am not sure how to satisfy our customer. Please respond.
Cognizant
for both data sets: p value<.005.
Anderson Darling Probability plot using Minitab
reynald
Well AD does have false alarms.
For instance I generated 36 datasets each with n = 30 using Normal (0,1) then used AD test on minitab.
3 were concluded as non-normal (p-valuees = 0.037, 0.035, 0.020 ).
So I guess if p-value is not very low, take the p-value conclusion in conjunction with the histogram and probability plots. Assess if it could pass visually.
R Can Ppk value be greater than Cpk and if yes, under what conditions? Statistical Analysis Tools, Techniques and SPC 10
Proud Liberal Improving low p-value Statistical Analysis Tools, Techniques and SPC 13
BeaBea Registrars with VAR (Value Added Reseller) experience Registrars and Notified Bodies 8
qualprod Best approach to get a real value as average? Statistical Analysis Tools, Techniques and SPC 6
F Missing value of Uncertainty B Measurement Uncertainty (MU) 10
F Calibration certificate content - Average Value and True Value ISO 17025 related Discussions 6
S In BAC5300 we have machining mismatch allowed is 3tau, what is the value of tau? Document Control Systems, Procedures, Forms and Templates 1
S Change value of target during a batch Capability, Accuracy and Stability - Processes, Machines, etc. 0
A Acceptance p-value for linearity and bias analysis in minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Torque Value for Different types of Fasteners (Socket Head, Button Head, CSK) Manufacturing and Related Processes 2
M IATF 16949 - 8.5.6.1.1 Providing a list of process controls: Does this requirement add value to QMS? IATF 16949 - Automotive Quality Systems Standard 4
qualprod Cycle times, value stream mapping, inventory, average values? Lean in Manufacturing and Service Industries 1
Ashok sunder What are the criteria for setting a target KPI value against a quality objective? Benchmarking 7
S Adding Value prior to signing EASA Form 1 EASA and JAA Aviation Standards and Requirements 5
M Creating a Plant Level Value Stream Map Process Maps, Process Mapping and Turtle Diagrams 1
A IMDS - Changing the Locked Weight Value RoHS, REACH, ELV, IMDS and Restricted Substances 1
T Value Chain Map for Food Services Industry Service Industry Specific Topics 1
O P-Value less than 0.05. but everything else in control Statistical Analysis Tools, Techniques and SPC 19
qualprod P x I = Value interpretation for residual risk? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
O CPK with a P value less than 0.005 Manufacturing and Related Processes 8
G What degrees of freedom means in uncertainty budget and how do I set the value Measurement Uncertainty (MU) 2
Q Really do they add value (Vision, Mission, Values)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D What is the exact Temperature Coefficient Value to be set on a Conductivity Meter? General Measurement Device and Calibration Topics 2
M Value Stream Mapping Calculations Process Maps, Process Mapping and Turtle Diagrams 5
L How to interpret the average R bar Value shown in the R Chart Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Non Value Added Corrective Actions IATF 16949 - Automotive Quality Systems Standard 15
R How To Calculate & Print CDF and Lower Bound CDF value for some t(time) with Minitab? Using Minitab Software 1
P Purpose of calculating Uncertainty value in calibration study Measurement Uncertainty (MU) 5
J Agenda of Value Stream Mapping workshop required Quality Tools, Improvement and Analysis 1
M What is the value of documenting in-process rework for easily-detectable issues? Quality Manager and Management Related Issues 4
R VSM - Value Stream Mapping (catheter manufacturing unit) Customer Complaints 10
W Quality for value adding or certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
T Cpk for 0 as Ideal Value Statistical Analysis Tools, Techniques and SPC 1
dubrizo Internal Audit Value - What is the point of conducting internal audits to a checklist Internal Auditing 40
L 5 minutes only for this Survey on the Value of PDCA and Your EMS Miscellaneous Environmental Standards and EMS Related Discussions 1
M How calculate P value for Linearity and Bias using Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
J F and P-value in L9 Taguchi Design Using Minitab Software 22
S Value of Ppk or Cpk when targeting thinner material Statistical Analysis Tools, Techniques and SPC 4
B How to validate Microsoft Excel Spreadsheet Calculations for the Cpk value Capability, Accuracy and Stability - Processes, Machines, etc. 9
V Analysis of 'Value Added' System & Process Steps - Inspection Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
P Which ISO 13485 clause(es) are applicable for Value Proposition Creation ISO 13485:2016 - Medical Device Quality Management Systems 1
R The Value and Effectiveness of In Process Inspection Quality Manager and Management Related Issues 17
D Value-Added Analysis - Staff (Employee) Satisfaction Quality Tools, Improvement and Analysis 11
T ISO Auditor Training - What online training is actually value added? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M Specific Capability case - Target Value is same as the Lower Limit Capability, Accuracy and Stability - Processes, Machines, etc. 9
S GR&R for an "R" value instrument installed on my 10K Horizontal Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Value Stream Mapping for a Product Family Lean in Manufacturing and Service Industries 5
WCHorn Are Inspection Operations Value Added? Lean in Manufacturing and Service Industries 50
J How does Layout Inspection determine Reference Value? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
