Package validation on a different product in an already validated package?
Biobry
Hello, I'm new to the quality system work and have been asked to take over a lot of the package validation work, so maybe someone can help me out with this question. We have a device for which the packaging validation work has already been completed. It is a multi-layer wound care device. We added another layer to it to make a new product and we will be packaging the new product in the same packaging (poly/poly pouch). At what point does the packaging validation need to be re-done? Because this is technically a different product in the same package, does it need to be re-validated or because of the similarity and the same packaging will the old validation be sufficient?
BradM
Hello, and welcome to the Cove!:bigwave:
Just because my mind works slow:lol:, let's set some variables:
A= Original product
B=Original Package- multi layers
C= New product
Before, A went into B. Now, C is going into B. Correct?
Is this a sterile product, and thus sterile packaging? How is it sterilized?
G
gholland
I think he's not changing the package but adding another layer of something to his wound care product.
If it is a significant change in mass then you would want to re-run the packaging test as you are changing the results of the vibration and shock testing. I am not talking on a per-piece basis here but on the total mass of the package. If you are adding something that could abrade the plastic package and cause a hole during vibration testing you would need to re-test. If the dimensions on your product have changed you would need to re-test.
Is the product stacked the same way in your package? If you've changed anything about the packaging configuration you would need to re-test in my opinion.
:2cents:
MIREGMGR
When the same packaging system will be used for a multiplicity of products, you do the validation for the family of products by establishing a Process Challenge Device, i.e. the worst-case of the products for which that packaging solution will be used. That worst case might be in regard to mass, volume, odd shape that stresses the materials across a bondline, or other parameters...as long as you can document a technically comprehensive analysis of why you have identified the worst case.
If the packaging is validated for the worst case product, it is validated for all less-challenging products as well.
If a single worst case product cannot be identified because several products are differently "worst case" in regard to different parameters, you might have to perform some of the validation work in multiple instances.
As gholland says above, if in your two-product family the new product is significantly different and must be considered the worst case, you'll need to validate the packaging over again, with that product as the challenge.
Kevin Mader
One of THE Original Covers!
Leverage your risk management activity to determine if new design concerns are raised by the new configuration. As our peers have offered, by validating the super-set, you may have the rationale to support a 'no' decision to re-validation. This is harder to establish when the super-set becomes a sub-set as in your situation. However, this does not in itself mean that a re-validation is required. By reperforming the risk management activities you may establish the appropriate mitigating rationale, especially for minor configuration changes.
Establish the plan that explains your approach to validation detailing the strategy you plan to leverage. You might end up having to run a few protocols as opposed to having to rerun the entire suite of validation protocols. Create a sound summary of your validation effort (or why one wasn't needed) to establish your regulatory footing.
Regards,
Kevin
Biobry
Wow, thank you all very much for your fast responses. It sounds like we will need to re-do the validation. Bot Product A and C are folded several times and then placed into the poly pouch. The extra layer added to the product to make product C does add thickness to the final package (which is gamma sterilized). It seems like this extra thickness inside the same packaging and in the same packaging configuration would make the new device, C, the "worst case", needing re-validation. I think we'll have to look into it just a little more first. If the difference in the average thickness between Product A and C is negligible then we could do a risk assessment and make the case that the validation could apply. If the difference in thickness is enough we would re-validate.
Thanks again for the suggestions.
s.parakos
Does the extra thickness of the new product actually place extra stress on the packaging and in particular the seals? That would be my main area to investigate.
Simon
Jimmy the Brit
Sorry to join this so late, but you also need to consider the product bioburden changes as this is a terminally sterilized product. Sometimes dressings and films can have a high bioburden due to inherent static charge /Van de Waals forces: this should be estimated and taken into account in your sterility assurance calculations, as must any change to the standard microflora and its resistance to the sterilization process, if the extra layer is a different material, or from a different supplier.
Neither of these are critical deficiencies, but a picky auditor could challenge your sterility assurance and that is never a pleasant experience.
Regards,
Jimmy
M API 4F/7K/8C Design Package Validation Oil and Gas Industry Standards and Regulations 2
shimonv Packaging Validation for Non-Sterile Package EU Medical Device Regulations 6
R How to go about package validation on a class II, non-sterile device US Food and Drug Administration (FDA) 4
M "Streamlining Package Seal Validation" - I'm looking for this article reference Book, Video, Blog and Web Site Reviews and Recommendations 2
F Sterile Barrier Package (Tyvek Pouch) Validation Question ISO 13485:2016 - Medical Device Quality Management Systems 7
S Does Package Validation required for Service Parts Packaging Carton Box? ISO 13485:2016 - Medical Device Quality Management Systems 1
G IQ, OQ, PQ Package for Label Printer Applicator and Software Validation - Help wanted Qualification and Validation (including 21 CFR Part 11) 2
B Handling, Storage and Distribution - Package Validation Test Method Options? US Food and Drug Administration (FDA) 7
B Validation of statistical software - To validate a CAQ-Statistic-Package Statistical Analysis Tools, Techniques and SPC 1
DuncanGibbons Technical Data Package vs Digital Product Definition APQP and PPAP 0
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
N Post Market Surveillance Package Example Wanted ISO 13485:2016 - Medical Device Quality Management Systems 1
H Re-labelling in IVDD - Re-label two products and package them as one CE Marking (Conformité Européene) / CB Scheme 5
M UDI-PI on a package that contains more devices EU Medical Device Regulations 3
M Identical Sales Package in Different Countries Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
F Adding a medical device in another medical device package EU Medical Device Regulations 2
M Package Integrity Test ASTM F 2096 or ASTM 1929 Quality Assurance and Compliance Software Tools and Solutions 1
M Medical device package insert in EU and USA Japan Medical Device Regulations 2
M Switching (Migrating) to a new QMS Software Package Document Control Systems, Procedures, Forms and Templates 14
J Referencing Medical Device in FDA records - Package contains several other components Other Medical Device Regulations World-Wide 1
S Package performance testing for non-sterile Hydrogels US Food and Drug Administration (FDA) 1
ernieto IVD Vials - If we CE Mark a kit's package, do we also have to CE Mark the vials? CE Marking (Conformité Européene) / CB Scheme 4
S "Update" the PPAP Package after Mass Production Commences APQP and PPAP 2
Pmarszal GUDID Packaging - Two part package Other US Medical Device Regulations 5
A API (American Petroleum Institute) Design Package Content Requirements Oil and Gas Industry Standards and Regulations 1
N Foil Package Integrity Testing ISO 4074 Other Medical Device Related Standards 1
P ASTM-F2096 Medical Package Testing Various Other Specifications, Standards, and related Requirements 1
S Package Storage Direction in an I.T. Warehouse ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A JEDEC Std to use as reference for a package of size of 29x29mm with 0.8mm ball pitch Design and Development of Products and Processes 6
B In-Process Sampling Plan for a Secondary Package Adjustment Process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D Incentive Package for obtaining ISO 14001 Certification ISO 14001:2015 Specific Discussions 6
H Package Integrity Testing Acceptance Criteria ISO 13485:2016 - Medical Device Quality Management Systems 3
S AS9100C Complete Internal Audit Software Package Recommendations Quality Assurance and Compliance Software Tools and Solutions 13
R What is PSW - Statistical Process Package + Level 5 APQP and PPAP 7
J MOT (Traveler/Router) Software Package Help Quality Assurance and Compliance Software Tools and Solutions 3
K Can anyone recommend a PPAP software package? Quality Assurance and Compliance Software Tools and Solutions 11
C Lean Sigma Manufacturing Handoff Package Contents FMEA and Control Plans 8
Q Faking Data - Refusing to sign Falsified PPAP Submission package Nonconformance and Corrective Action 27
M How to validate a Dye Test method used to evaluate Package Integrity Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
D Packaging Addition - Non-sterile barrier to protect the whole package 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 12
V Issue: Suppliers charge for complete Level III PPAP package - Heat Treated Parts APQP and PPAP 16
J Cpk & Ppk - Reviewing a PPAP Package - Some questions Statistical Analysis Tools, Techniques and SPC 8
G Various ?QMS? packages on the market - Which software package? Quality Assurance and Compliance Software Tools and Solutions 35
M MRP/QMS Software Package to replace our current Paper QMS - Help Quality Assurance and Compliance Software Tools and Solutions 4
J What is a Standard Level IV QA Package General Measurement Device and Calibration Topics 1
H Surgical Sealant Package Integrity Test for Glass Vial Filled Product Other Medical Device Related Standards 3
J Testing to ISO 8573 (Compressed Air Package) Classification 4, Paragraph 6.1 Other ISO and International Standards and European Regulations 8
T Electronic Package inserts EU Medical Device Regulations 6
M APQP Timing Plan Details and APQP Package Contents (e.g.: floor plan) - Batch Mfg. APQP and PPAP 5
