Packaging Re-Validation - Sealer machine broke down or was changed to a new one
G
gitgiv
Hi all,
Can someone please help with this one:
If our packaging sub-contractor validated sealer machine broke down or was changed to a new one - except for machine qualification - would we need to perform packaging validation all over again?
Thanks! :)
somashekar
Hi all,
Thanks! :)
Yes.
New machine involves new installation qualification, and logically the next steps of operational and performance qualification follows. The new machine may be different to the broken down sealing machine, and hence the logical full re-validation.
If the machine was repaired with the appropriate spares without altering the specifications of the machine, an installation qualification would do. However a sound practice would be to have a full re-validation.
Ajit Basrur
If its a like for like change ie. same brand and make of sealing machine, a simple qualification is required. However, if you change to a different model and make, a detailed equipment qualification is required.
G
gitgiv
Would we need to do packaging validation (dye, peel and burst tests) all over again if it's the same machine?
somashekar
Of course yes, if it is a new machine.
It depends, in case of machine breakdown, what and how in the machine was replaced / repaired, and made good to work.
To support our response, can you kindly tell us what was the nature of the machine breakdown ?
G
gitgiv
Can you explain what you mean by "simple qualification"?
Thanks again for your quick and informative response!
Ajit Basrur
Since its a new Sealer,
1. perform Installation Qualification,
2. identify some Operational Qualification parameters that you feel are necessary for quality and safety like temperature verification, calibration and time verification. Also perform certain safety parameter verification (poka yoke) if you have on the Sealer.
3. perform a condensed Performance Qualification by testing end product to the spec like Leak Test.
Hope that helps :)
G
gitgiv
Thank you very much. We are a small start-up company and need all the good advices we can get...
Y
Yarocin
Hi!
You discussed the situation when a new sealer is installed. I performed the IQ, OQ and PQ for one sealer, but there are other two on the site. They are the same brand and model. Could you please advise: Should I perform the same tests as for the first sealer?
Is it possible to shorten the qualification process of the other two sealers? Do I have to perform all OQ tests again?
Thank you.
J Shelf Life Validation for new Heat Impulse Medical Packaging Sealer Qualification and Validation (including 21 CFR Part 11) 2
W Packaging / Heat Sealer Validation - IOQ (Installation/Operational Qualification) Qualification and Validation (including 21 CFR Part 11) 15
H Software Validation for FFS Packaging Machine Qualification and Validation (including 21 CFR Part 11) 1
P Unrealistic Packaging Validation Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 39
Y Packaging validation for non-sterile Medical Equipment Other Medical Device Related Standards 1
V Tyvek packaging for Medical device process validation Qualification and Validation (including 21 CFR Part 11) 2
shimonv Packaging Validation for Non-Sterile Package EU Medical Device Regulations 6
R Medical Device Packaging Label Validation Other US Medical Device Regulations 8
P Sterile Medical Packaging and Shelf Life Validation Sample size ISO 13485:2016 - Medical Device Quality Management Systems 10
R Can a Distributor perform Packaging Validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Packaging Validation - IOQ Protocol template for a Sartorius Checkweigher Design and Development of Products and Processes 2
I Work Instruction for Validation of Packaging to EN ISO 11607-2 Requirements Document Control Systems, Procedures, Forms and Templates 3
P Sterile Packaging Validation Requirements - Accredited Laboratory or not? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
P Sterile Packaging Validation - FDA Requirements for Statistically Valid Tests 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
ScottK Validation of SAP - Secondary Packaging Manufacturer Qualification and Validation (including 21 CFR Part 11) 8
S Does Package Validation required for Service Parts Packaging Carton Box? ISO 13485:2016 - Medical Device Quality Management Systems 1
T Packaging Validation - New Machinery - Terminally Sterilized Medical Devices Qualification and Validation (including 21 CFR Part 11) 7
M Do I need to do Packaging Validation? Other Medical Device and Orthopedic Related Topics 3
B Packaging Validation is Suffocating me - We deliver our products non-sterilized Other Medical Device and Orthopedic Related Topics 14
B Packaging Validation - Storage Distribution Testing Qualification and Validation (including 21 CFR Part 11) 4
A Packaging Validation / Qualification Report for Medical Devices - Example ISO 13485:2016 - Medical Device Quality Management Systems 5
M Packaging standards - ASTM vs ISTA Other Medical Device Related Standards 0
M Packaging studies - ISTA vs ASTM CE Marking (Conformité Européene) / CB Scheme 0
F UDI-PI required on packaging (MDR) EU Medical Device Regulations 2
C Packaging Long Parts Manufacturing and Related Processes 3
G Special 510K possible? Only the packaging has changed Other US Medical Device Regulations 0
B Setting flexible packaging specification limits ISO 14971 - Medical Device Risk Management 4
V Packaging in Distributor Practices EU Medical Device Regulations 0
R Green dot required on packaging? Medical Device and FDA Regulations and Standards News 2
shimonv Single lot release for sterile packaging 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
R Applicable ISO standards - packaging and others Medical Device and FDA Regulations and Standards News 4
A FDA guidance on non-sterile Medical Device Packaging Medical Device and FDA Regulations and Standards News 7
C 21 CFR 803 malfunction detected during packaging - report? Other US Medical Device Regulations 1
E Latex in packaging Other Medical Device Related Standards 4
H Expired packaging material - Expired unused Tyvek pouches Other Medical Device and Orthopedic Related Topics 2
A GUDID - Packaging Levels 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
A Packaging device with accessories already on the market Other Medical Device Regulations World-Wide 0
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
Q EU Rep for Packaging waste, WEEE and Battery disposal CE Marking (Conformité Européene) / CB Scheme 0
L AS5553 Clause 3.1.7 e "Control packaging material ..................reused" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
L Packaging unsterile medical devices ISO 13485:2016 - Medical Device Quality Management Systems 6
M MDR - Packaging - Secondary Medical Device Boxes EU Medical Device Regulations 2
M UDI size on packaging EU Medical Device Regulations 3
M UDI placement - Packaging levels EU Medical Device Regulations 2
E Unit Dose Packaging Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
K Packaging and Damaged Parts returned from a Service Provider (Anodize) - Who is Responsible? Manufacturing and Related Processes 20
B 510(k) clearance claim on medical device product packaging Other US Medical Device Regulations 6
E Packaging Specifications Mercedes-Benz U.S. International IATF 16949 - Automotive Quality Systems Standard 4
T Colour of symbols on Medical Device labelling and packaging Other Medical Device Related Standards 1
R Labels on sterile packaging EU Medical Device Regulations 5
