Packaging seal inspection
Does anyone know of a cost effective machine that can be used to detect pouch defects such as contamination and holes in paper, tyvak and high barrier tyvak pouches? I looked in to PTI seal sensor but it is too expensive.
Swerf
Hi, we routinely use foil pouches to package sub-components of our medical device. We use a dunk test to verify seal integrity. We place the sealed pouch in an desiccator partially filled with water (enough to submerge the packaged subcomponent) place the lid on the desiccator an ensure a good seal (may need to use a lubricant on the gasket to get a good seal) and use a vacuum pump to pump down the chamber to at least 10in. Hg (or relevant pressure stated by your pouch mfr). We then observe the pouch for one minute. If the seal is satisfactory then no streams of bubbles should be observed. If the heat seal was ineffective, or if the pouch has a hole then the operator will observe a steady stream of bubbles. Pretty low tech method, but we've used it for many years with great success! Hope this helps!
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
N Symbol for Medical Device Sterile Packaging - "Inspect Seal Before Opening" Other Medical Device Related Standards 5
R Seal Packaging - Burst and Leak Specifications for a Foil Seal applied to a PTFE well Manufacturing and Related Processes 4
M Packaging standards - ASTM vs ISTA Other Medical Device Related Standards 0
M Packaging studies - ISTA vs ASTM CE Marking (Conformité Européene) / CB Scheme 0
F UDI-PI required on packaging (MDR) EU Medical Device Regulations 2
C Packaging Long Parts Manufacturing and Related Processes 3
H Software Validation for FFS Packaging Machine Qualification and Validation (including 21 CFR Part 11) 1
G Special 510K possible? Only the packaging has changed Other US Medical Device Regulations 0
B Setting flexible packaging specification limits ISO 14971 - Medical Device Risk Management 4
V Packaging in Distributor Practices EU Medical Device Regulations 0
R Green dot required on packaging? Medical Device and FDA Regulations and Standards News 2
shimonv Single lot release for sterile packaging 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
R Applicable ISO standards - packaging and others Medical Device and FDA Regulations and Standards News 4
A FDA guidance on non-sterile Medical Device Packaging Medical Device and FDA Regulations and Standards News 7
C 21 CFR 803 malfunction detected during packaging - report? Other US Medical Device Regulations 1
E Latex in packaging Other Medical Device Related Standards 4
H Expired packaging material - Expired unused Tyvek pouches Other Medical Device and Orthopedic Related Topics 2
A GUDID - Packaging Levels 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
A Packaging device with accessories already on the market Other Medical Device Regulations World-Wide 0
P Unrealistic Packaging Validation Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 39
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
Q EU Rep for Packaging waste, WEEE and Battery disposal CE Marking (Conformité Européene) / CB Scheme 0
L AS5553 Clause 3.1.7 e "Control packaging material ..................reused" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
L Packaging unsterile medical devices ISO 13485:2016 - Medical Device Quality Management Systems 6
M MDR - Packaging - Secondary Medical Device Boxes EU Medical Device Regulations 2
Y Packaging validation for non-sterile Medical Equipment Other Medical Device Related Standards 1
M UDI size on packaging EU Medical Device Regulations 3
M UDI placement - Packaging levels EU Medical Device Regulations 2
E Unit Dose Packaging Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
K Packaging and Damaged Parts returned from a Service Provider (Anodize) - Who is Responsible? Manufacturing and Related Processes 20
B 510(k) clearance claim on medical device product packaging Other US Medical Device Regulations 6
E Packaging Specifications Mercedes-Benz U.S. International IATF 16949 - Automotive Quality Systems Standard 4
T Colour of symbols on Medical Device labelling and packaging Other Medical Device Related Standards 1
R Labels on sterile packaging EU Medical Device Regulations 5
A Interpretation of Article 16 (2b) - Packaging, samples and Certificate EU Medical Device Regulations 10
I Medical Device Packaging Multilingual Labeling EU Medical Device Regulations 3
N Process Flow diagram steps for inspection and packaging APQP and PPAP 4
C ISO 7010 m002 mandatory action - Color requirements on Packaging IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
shimonv GTIN Number on the Packaging of a Serviced Medical Device EU Medical Device Regulations 0
shimonv Is UDI required on the Packaging of a Serviced/Repaired Medical Device? Other US Medical Device Regulations 3
C QR Code on Medical Device Packaging and Notification to Notified Body EU Medical Device Regulations 1
TheMightyWife Address Change - Medical Device Packaging Labelling Requirements EU Medical Device Regulations 7
E Use of FDA Cleared logo on packaging US Food and Drug Administration (FDA) 8
V Tyvek packaging for Medical device process validation Qualification and Validation (including 21 CFR Part 11) 2
S Symbols - Device label versus Packaging label ISO 13485:2016 - Medical Device Quality Management Systems 1
Y Sterile device packaging under MDR EU Medical Device Regulations 3
A Medical Device Class 2A, non sterile bodyworn packaging requirements CE Marking (Conformité Européene) / CB Scheme 7
N Medical device non sterile packaging requirement CE Marking (Conformité Européene) / CB Scheme 1
P Drug packaging / filling operations Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
