Packaging Validation - New Machinery - Terminally Sterilized Medical Devices
ttuyoc
Hello All,
I work for a medical device manufacturer that manufactures terminally sterilized medical devices.
We are in the process of moving to another facility and one of our tray sealing machines is currrently validated following the ISO 11607-2 standards. (IQ,OQ,PQ protociols)
We are going to purchase 2 similar machines that are going to be sealing the same type of tray to the same tyvek lid as our current machine does. Will the new machines require a full validation or is there a way we can perform solely a PQ, since we have our critical parameters set for the current machine?
Any thoughts?
Stijloor
Hello All,
We are in the process of moving to another facility and one of our tray sealing machines is currently validated following the ISO 11607-2 standards. (IQ,OQ,PQ protocols)
Any thoughts?
Can someone help our Member?
Thank you very much.
Stijloor.
somashekar
Hello All,
Any thoughts?
New machines ..so will need fresh IQ for each of them.
OQ to ensure that your critical parameters without any change still reproduces the same result on both the new machines. Learning from the previous validation is applied here to ensure that same are still effective, (or minor changes made to get required results).
If any changes are indeed made though minor, then a PQ will show continued optimum performance.
Sterilization being a critical process the sealing integrity is top priority and I would say complete validation, taking all the learnings from the first done validation.
MIREGMGR
I mostly agree with Somashekar, except that I'd think if the two new machines are identical models with identical options and setups to be used for an identical task with identical materials in an identical environment, then perhaps only one of them will need a full IQ/OQ/PQ, with the other one needing only a verification of identical performance with an identical setup.
Ajit Basrur
MIREGMGR is right.
As per GHTF, Process Validation Guideline, sec 6.4
The need for revalidation should be evaluated and documented. This evaluation should include historical results from quality indicators, product changes, process changes, changes in external requirements (regulations or standards) and other such circumstances.
Revalidation may not be as extensive as the initial validation if the situation does not require that all aspects of the original validation be repeated. If a new piece of equipment is purchased for a validated process, obviously the IQ portion of the validation needs to be repeated. However, most of the OQ aspects are already established. Some elements of PQ may need to be repeated, depending on the impact of the new equipment.
PS : Welcome to the Cove, ttuyoc :agree1:
MIREGMGR
By the way...the existing machine will need to have its validation verified as well, since the de- and re-installation of the machine itself, the physically different-location environment, and the new set of supporting utilities etc. may affect the IQ, per 5.2.
Juan Dude
Since sterilization is a critical process I would go with this advice. :2cents:
Y Packaging validation for non-sterile Medical Equipment Other Medical Device Related Standards 1
V Tyvek packaging for Medical device process validation Qualification and Validation (including 21 CFR Part 11) 2
shimonv Packaging Validation for Non-Sterile Package EU Medical Device Regulations 5
R Medical Device Packaging Label Validation Other US Medical Device Regulations 8
P Sterile Medical Packaging and Shelf Life Validation Sample size ISO 13485:2016 - Medical Device Quality Management Systems 10
R Can a Distributor perform Packaging Validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Packaging Validation - IOQ Protocol template for a Sartorius Checkweigher Design and Development of Products and Processes 2
I Work Instruction for Validation of Packaging to EN ISO 11607-2 Requirements Document Control Systems, Procedures, Forms and Templates 3
P Sterile Packaging Validation Requirements - Accredited Laboratory or not? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
P Sterile Packaging Validation - FDA Requirements for Statistically Valid Tests 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
G Packaging Re-Validation - Sealer machine broke down or was changed to a new one Other ISO and International Standards and European Regulations 11
ScottK Validation of SAP - Secondary Packaging Manufacturer Qualification and Validation (including 21 CFR Part 11) 8
J Shelf Life Validation for new Heat Impulse Medical Packaging Sealer Qualification and Validation (including 21 CFR Part 11) 2
W Packaging / Heat Sealer Validation - IOQ (Installation/Operational Qualification) Qualification and Validation (including 21 CFR Part 11) 13
S Does Package Validation required for Service Parts Packaging Carton Box? ISO 13485:2016 - Medical Device Quality Management Systems 1
M Do I need to do Packaging Validation? Other Medical Device and Orthopedic Related Topics 3
B Packaging Validation is Suffocating me - We deliver our products non-sterilized Other Medical Device and Orthopedic Related Topics 14
B Packaging Validation - Storage Distribution Testing Qualification and Validation (including 21 CFR Part 11) 4
A Packaging Validation / Qualification Report for Medical Devices - Example ISO 13485:2016 - Medical Device Quality Management Systems 5
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 5
Q EU Rep for Packaging waste, WEEE and Battery disposal CE Marking (Conformité Européene) / CB Scheme 0
L AS5553 Clause 3.1.7 e "Control packaging material ..................reused" AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
L Packaging unsterile medical devices ISO 13485:2016 - Medical Device Quality Management Systems 6
M MDR - Packaging - Secondary Medical Device Boxes EU Medical Device Regulations 2
M UDI size on packaging EU Medical Device Regulations 3
M UDI placement - Packaging levels EU Medical Device Regulations 2
E Unit Dose Packaging Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
K Packaging and Damaged Parts returned from a Service Provider (Anodize) - Who is Responsible? Manufacturing and Related Processes 20
B 510(k) clearance claim on medical device product packaging Other US Medical Device Regulations 6
E Packaging Specifications Mercedes-Benz U.S. International IATF 16949 - Automotive Quality Systems Standard 4
TechnicalGuy Colour of symbols on Medical Device labelling and packaging Other Medical Device Related Standards 1
R Labels on sterile packaging EU Medical Device Regulations 5
A Interpretation of Article 16 (2b) - Packaging, samples and Certificate EU Medical Device Regulations 10
I Medical Device Packaging Multilingual Labeling EU Medical Device Regulations 3
N Process Flow diagram steps for inspection and packaging APQP and PPAP 4
C ISO 7010 m002 mandatory action - Color requirements on Packaging IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
shimonv GTIN Number on the Packaging of a Serviced Medical Device EU Medical Device Regulations 0
shimonv Is UDI required on the Packaging of a Serviced/Repaired Medical Device? Other US Medical Device Regulations 3
C QR Code on Medical Device Packaging and Notification to Notified Body EU Medical Device Regulations 1
TheMightyWife Address Change - Medical Device Packaging Labelling Requirements EU Medical Device Regulations 7
E Use of FDA Cleared logo on packaging US Food and Drug Administration (FDA) 8
S Symbols - Device label versus Packaging label ISO 13485:2016 - Medical Device Quality Management Systems 1
Y Sterile device packaging under MDR EU Medical Device Regulations 3
A Packaging seal inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
A Medical Device Class 2A, non sterile bodyworn packaging requirements CE Marking (Conformité Européene) / CB Scheme 7
N Medical device non sterile packaging requirement CE Marking (Conformité Européene) / CB Scheme 1
P Drug packaging / filling operations Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
J Animal-Derived products in Packaging Manufacturing and Related Processes 0
P China drug packaging DMF China Medical Device Regulations 0
