Packaging Workmanship Criteria - Examples needed
samuelng1
I am looking for information on packaging workmanship criteria which I can adopt for my company. Currently, there is no basis to reject and final decision is made by Sales people. This is very difficult for a Quality guy to accept.
Thanks in advance.
Regards
Samuel
Marc
You might want to start out by telling us what you are packaging... Rubber ducks for kids? High-reliability electronic components? TVs? Screws and nuts? Milk?
And what, specifically, is the current criteria sales uses to accept or reject?
Manix
Get Involved!!!
If you are Automotive, then the customer should have defined packaging requirements that meet with the strict control of material on their line. I am sure this applies to other industries also.
Packaging requirements should be defined by addressing the following at a minimum:
1. Does it sufficiently protect the product, for delivery to the end user?
2. Does it make efficient use of the available space? (I.e. are you shipping too much air?)
3. Do the materials used meet with either written or intended environmental and safety considerations?
4. Is the packaging marked correctly to identify what is in it, how it should be handled and meets with any international customs regs. Plus, does it provide efficient traceability?
5. Is the packaging designed for the most efficient methods of handling, both for loading the packaging up and decanting the packaging?
6. Does the packaging meet with all customer specified requirements which might include but not limited to the above points.
These are the areas we look at when defining our packaging requirements and these are checked etc..... during the process.
samuelng1
Well, we provide packaging such as foams and cartons to our customers(electronic and medical industry). However, it seems that our is a secondary packaging. For example our harddisk manufacturer would place their harddisks into ESD bags before placing into foams slots inside our cartons.
Customer specification via drawings are one thing. I am looking at workmanship criteria for raw materials as well as finished goods. Example of what I am looking for is the acceptance criteria for cracks on cartons (how long and how wide can the crack be acceptable) and is it traceable to internationally accepted standard.
Hope that this provides better insight.
Thanks and Regards
Samuel
DsqrdDGD909
I have a little bit of experience in packaging. When you say cracks in the cartons, what do you mean? Are these holes, tears, coating cracks? What is the substrate, corrugated, white board, clay coated?
samuelng1
The cracks on the corrugated cartons appears to be like tear marks. It happen along the folding lines. How much is acceptable based on industry/international standard?
DsqrdDGD909
I did a bit of googling and here is Hewlett Packard's Packaging guidelines. Nothing about cracks per se but lots about package testing.
http://packaging.hp.com/testing/index.htm
Also HP refers to this site: The Institute of Packaging Professionals (IoPP)
http://www.iopp.org/store/category.cfm?category_id=4
JadeS
Thanks and Regards
Samuel
It might be necessary to determine if there are laws for your Country of Origin or for the Country where the product is being shipped or distributed, if not domestic.
For instance in Canada there are Consumer Packaging laws which state that the corrugated packaging must be stamped to hold a certain weight. The contents of the package cannot exceed this weight. For international shipments we are notified that the shipment was off-loaded and inspected at a border. For international we also need to comply with the laws of the Country where the product is shipped.
Regards,
Jade
M Packaging standards - ASTM vs ISTA Other Medical Device Related Standards 0
M Packaging studies - ISTA vs ASTM CE Marking (Conformité Européene) / CB Scheme 0
F UDI-PI required on packaging (MDR) EU Medical Device Regulations 2
C Packaging Long Parts Manufacturing and Related Processes 3
H Software Validation for FFS Packaging Machine Qualification and Validation (including 21 CFR Part 11) 1
G Special 510K possible? Only the packaging has changed Other US Medical Device Regulations 0
B Setting flexible packaging specification limits ISO 14971 - Medical Device Risk Management 4
V Packaging in Distributor Practices EU Medical Device Regulations 0
R Green dot required on packaging? Medical Device and FDA Regulations and Standards News 2
shimonv Single lot release for sterile packaging 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
R Applicable ISO standards - packaging and others Medical Device and FDA Regulations and Standards News 4
A FDA guidance on non-sterile Medical Device Packaging Medical Device and FDA Regulations and Standards News 7
C 21 CFR 803 malfunction detected during packaging - report? Other US Medical Device Regulations 1
E Latex in packaging Other Medical Device Related Standards 4
H Expired packaging material - Expired unused Tyvek pouches Other Medical Device and Orthopedic Related Topics 2
A GUDID - Packaging Levels 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
A Packaging device with accessories already on the market Other Medical Device Regulations World-Wide 0
P Unrealistic Packaging Validation Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 39
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
Q EU Rep for Packaging waste, WEEE and Battery disposal CE Marking (Conformité Européene) / CB Scheme 0
L AS5553 Clause 3.1.7 e "Control packaging material ..................reused" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
L Packaging unsterile medical devices ISO 13485:2016 - Medical Device Quality Management Systems 6
M MDR - Packaging - Secondary Medical Device Boxes EU Medical Device Regulations 2
Y Packaging validation for non-sterile Medical Equipment Other Medical Device Related Standards 1
M UDI size on packaging EU Medical Device Regulations 3
M UDI placement - Packaging levels EU Medical Device Regulations 2
E Unit Dose Packaging Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
K Packaging and Damaged Parts returned from a Service Provider (Anodize) - Who is Responsible? Manufacturing and Related Processes 20
B 510(k) clearance claim on medical device product packaging Other US Medical Device Regulations 6
E Packaging Specifications Mercedes-Benz U.S. International IATF 16949 - Automotive Quality Systems Standard 4
T Colour of symbols on Medical Device labelling and packaging Other Medical Device Related Standards 1
R Labels on sterile packaging EU Medical Device Regulations 5
A Interpretation of Article 16 (2b) - Packaging, samples and Certificate EU Medical Device Regulations 10
I Medical Device Packaging Multilingual Labeling EU Medical Device Regulations 3
N Process Flow diagram steps for inspection and packaging APQP and PPAP 4
C ISO 7010 m002 mandatory action - Color requirements on Packaging IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
shimonv GTIN Number on the Packaging of a Serviced Medical Device EU Medical Device Regulations 0
shimonv Is UDI required on the Packaging of a Serviced/Repaired Medical Device? Other US Medical Device Regulations 3
C QR Code on Medical Device Packaging and Notification to Notified Body EU Medical Device Regulations 1
TheMightyWife Address Change - Medical Device Packaging Labelling Requirements EU Medical Device Regulations 7
E Use of FDA Cleared logo on packaging US Food and Drug Administration (FDA) 8
V Tyvek packaging for Medical device process validation Qualification and Validation (including 21 CFR Part 11) 2
S Symbols - Device label versus Packaging label ISO 13485:2016 - Medical Device Quality Management Systems 1
Y Sterile device packaging under MDR EU Medical Device Regulations 3
A Packaging seal inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
A Medical Device Class 2A, non sterile bodyworn packaging requirements CE Marking (Conformité Européene) / CB Scheme 7
N Medical device non sterile packaging requirement CE Marking (Conformité Européene) / CB Scheme 1
P Drug packaging / filling operations Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
J Animal-Derived products in Packaging Manufacturing and Related Processes 0
