Parallel Cylinders (Dowels or Pins) As Datum Features
optomist1
A Sea of Statistics
Hi To All,
I have a question regarding the use of a pattern of features (dowels or pins) as a Datum Feature. Specifically when using a set of these features as a datum feature and referencing them in datum portion of a feature control frame, the material condition for the construction of the gage must be specified; MMC or LMC. To specify the set of features as RFS is next to impossible; tough to create a repeatable datum axis
How does Y14.5M -2009 standard address this? Is there a difference between 1994 and 2009?
Thank you...
Marty
Stijloor
Hi To All,
Thank you...
Marty
Marty,
Looking at ASME Y14.5-2009, Fig 4-35.
Four examples are provided consisting of a 3-pin pattern.
  1. The axis of an inscribed cylinder (inside the 3 pins simultaneously)
  2. The axis of a circumscribed cylinder (outside the 3 pins simultaneously)
  3. The centerplane of a distance (within) between 2 pins and 1 pin
  4. The centerplane of a distance (outside) between 2 pins and 1 pin
This is different from the 1994 version, where a centroid is developed within a pattern of features of size at MMC. This centroid (the mathematical midpoint within the pattern) becomes the datum axis.
Hope this helps.
Stijloor.
optomist1
A Sea of Statistics
Hi Stijloor,
I do not have access to the 2009 version, more specifically, I noted on another website that the RFS condition is an acceptable material condition for use when using a pattern of features to establish a Datum Axis and construct a gage, am I of the mark?
Thanks again for your insight!!
Marty
Stijloor
Hi Stijloor,
Marty
ASME Y14.5M-1994 provides an example in Fig 4-22, and is explained in 4.5.8. The text only makes references to patterns of features of size at MMC.
Alex Krulikowski in his "Fundamentals of GD&T" book on pages 162 and 163 provides an example of a 4-pin pattern where the datum axis is a centroid of the pattern. In the feature control frame, this datum feature (the pattern) is referred to at MMC.
The datum feature simulator consists of a block with four pins at their virtual conditions from which the centroid (the datum axis) is developed.
Stijloor.
J Does Pakistan Medical Device Import License allows parallel import? Other Medical Device Regulations World-Wide 0
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
R Components in parallel to creepage\clearance IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
G Definition Parallel Loop - Does anyone know what the term Parallel loop means? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
M Parallel processing IEC 60601 testing and 510k submission 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Michael Malis CMS (Centers for Medicare & Medicaid Services) and FDA Parallel Review Program US Food and Drug Administration (FDA) 0
N Capability on Parallel Processes such as Individual Mould Cavities Philosophy, Gurus, Innovation and Evolution 22
F Calculation of Failure - Constant Failure Rates of Parallel System Reliability Analysis - Predictions, Testing and Standards 11
C Is Cycle Time different between Parallel Machines and Single? Lean in Manufacturing and Service Industries 9
E Parallel RBD's (Reliabilty Block Diagram) help - Reliability & MTBF Reliability Analysis - Predictions, Testing and Standards 10
gard2372 RG 1/2" Thread called out on Drawing - Is it an ISO RG parallel gauge thread? Manufacturing and Related Processes 5
J Does anyone know how to adjust/calibrate bench centers that are not parallel? General Measurement Device and Calibration Topics 4
R Portocal II S/W needs some kind of "terminator" to parallel port General Measurement Device and Calibration Topics 3
M Definition Parallel Process - I found two Definitions - Which is correct? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
I Separate procedures for parallel operations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
N APQP phases, sequential or in parallel? APQP and PPAP 8
K Need of calibration procedures for sine plates, v-blocks, and parallel bars General Measurement Device and Calibration Topics 2
O How to establish Datum Planes with two cylinders? Various Other Specifications, Standards, and related Requirements 0
O Datum A and B are both Cylinders (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Example PFMEA for Hydraulic Cylinders wanted FMEA and Control Plans 0
T Traceability of the Contents in Gas Cylinders General Measurement Device and Calibration Topics 5
S AS9100 REV B Sampling Requirements - Heat Treatment of Large Cylinders AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
