Definition Parallel Loop - Does anyone know what the term Parallel loop means?
G
Glass Maker
Hello
Does anyone know what the term Parallel loop means???
Never heard of it and had it mentioned in an Email - relating to machine issues / data etc.
Think he may be trying to be a little clever as googling does not seem to find an answer.
Eredhel
Quality Manager
In the music gear world it can refer to an effects loop. In that case you basically run two signals from a guitar into an amplifier. One signal could be a "series loop" where the guitar signal runs through the amp and all added effects at the same time. Another signal could be a "parallel loop" where the guitar signal gets split and you can have a "dry" signal untouched by the effects plus a "wet" signal with the effects. I'm really oversimplifying but I wonder if there is something similar in your field where this could have a similar application.
Can you provide the context in which it was used?
In process mapping the term might be used to describe parallel process streams where product might take 1 of n identical streams then rejoin the main process flow after the operation(s) are complete.
J Does Pakistan Medical Device Import License allows parallel import? Other Medical Device Regulations World-Wide 0
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
R Components in parallel to creepage\clearance IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
M Parallel processing IEC 60601 testing and 510k submission 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
optomist1 Parallel Cylinders (Dowels or Pins) As Datum Features Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Michael Malis CMS (Centers for Medicare & Medicaid Services) and FDA Parallel Review Program US Food and Drug Administration (FDA) 0
N Capability on Parallel Processes such as Individual Mould Cavities Philosophy, Gurus, Innovation and Evolution 22
F Calculation of Failure - Constant Failure Rates of Parallel System Reliability Analysis - Predictions, Testing and Standards 11
C Is Cycle Time different between Parallel Machines and Single? Lean in Manufacturing and Service Industries 9
E Parallel RBD's (Reliabilty Block Diagram) help - Reliability & MTBF Reliability Analysis - Predictions, Testing and Standards 10
gard2372 RG 1/2" Thread called out on Drawing - Is it an ISO RG parallel gauge thread? Manufacturing and Related Processes 5
J Does anyone know how to adjust/calibrate bench centers that are not parallel? General Measurement Device and Calibration Topics 4
R Portocal II S/W needs some kind of "terminator" to parallel port General Measurement Device and Calibration Topics 3
M Definition Parallel Process - I found two Definitions - Which is correct? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
I Separate procedures for parallel operations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
N APQP phases, sequential or in parallel? APQP and PPAP 8
K Need of calibration procedures for sine plates, v-blocks, and parallel bars General Measurement Device and Calibration Topics 2
B Temperature loop: partial calibration General Measurement Device and Calibration Topics 10
S Disposable Loop Electrode - GMDN/or UMDNS code? Imported Legacy Blogs 3
C Quality Manual Index in Endless Loop Quality Management System (QMS) Manuals 7
A Designing a Closed Loop Water System using Adiabatic Cooling Towers Manufacturing and Related Processes 5
L Purchasing procedure - Seeking suggestions - How to include a 'loop' for follow-up ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
J Component Calibration - Overall TUR for a loop? ANSI/NCSL Z-540 Standard Section 10.2 General Measurement Device and Calibration Topics 6
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
H How does a gas turbine work on diesel fuel? Oil and Gas Industry Standards and Regulations 12
G What does performance specification include? US Food and Drug Administration (FDA) 1
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S How long does it take to register a product with MHRA? UK Medical Device Regulations 3
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N Does anyone have experience of GB/T 34986-2017? China Medical Device Regulations 1
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 9
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
A What does this line from MDCG 2020-3 (MDR art. 120 substantial change) mean to you? EU Medical Device Regulations 4
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
B General Motors and Honda Alliance - What does this mean to suppliers? IATF 16949 - Automotive Quality Systems Standard 3
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
