Definition Parallel Process - I found two Definitions - Which is correct?
MarkJoel
I found a definition for a Parallel Process, but it is much different than what I found in another place.
1. Parallel Process – another process that can be executed at the same time as the primary process. A vaild question was asked by a reviewer that is, By the same or a different trigger? or both?
I don't have the answer would you help?
Below is a definition that I found on the web.
2. A process in which two or more sequences of activities are going on simultaneously. If a physical document is being passed from one person to another, the process is necessarily a single sequence. An electronic document in a workflow system, on the other hand, can be sent to several people, simultaneously.
www.bptrends.com/resources_glossary.cfm
Now which one is correct for ISO processes?
Thanks in advance!
Douglas E. Purdy
Set of Interrelated or interacting activities that transforms inputs into out puts
MarkJoel,
I do not believe that ISO really cares, at least I do not know of any such definition or guidance on parallel processes. But I did want to bring up the fact that even a paper document may have parallel processes when it is reviewed and approved by a committee or group of representatives from those functions that have responsibilities for implementing what the document is stating.
Doug
Wes Bucey
As usual, Doug Purdy has pointed out the obvious:
there is no occurrence of the word "parallel" anywhere in ISO9001-2000.
What Standard is under discussion? In the absence of a Standard or Customer requirement, the organization is free to create its own definitions of processes and activities in its purview. As you cite, there are alternate descriptions of "parallel processes." I, myself, can "devise" still more definitions. The ultimate point is:
The organization describes what it ACTUALLY does. It does NOT try to shoehorn its operation into someone else's definition.
Peter Fraser
Thanks in advance!
MarkJoel
1 What do you reckon is meant by "Primary process"? I don't know - but you will need to know before the definition which uses the term can make sense!
Do you realise that the term "trigger" isn't used in ISO9000 or ISO9001 (although if it was then the idea of a process would make more sense to a lot of folk)? In a business, more or less all processes happen in parallel - sales happen while manufacturing goes on, procurement, training and management review can coincide ... but so what?
2 this definition doesn't make sense to me. Even within a process, activities can happen together or in a "random" sequence (the only requirement being that, say, tasks 4,5 and 6 must be complete before 7 is started. Again ... so what?
MarkJoel
Peter Fraser said:
MarkJoel
Thanks for your advise!
It is now clear to me.
James Gutherson
Exactly. We are tending to move from a flow chart that says this must happen, then that, then that, to mind maps that show the things that must happen but to not force an order on them. The main thing is to define what the required output(s) are, and work out what inputs are required to get those outputs.
Douglas E. Purdy
James,
Would you share an example of a mindmap for a process? I have used a mindmap for training & competency, which I have shared here at the cove, but I would like to see a mindmap that shows interactions and decisions of a process.
Thanks,
Doug
J Does Pakistan Medical Device Import License allows parallel import? Other Medical Device Regulations World-Wide 0
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
R Components in parallel to creepage\clearance IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
G Definition Parallel Loop - Does anyone know what the term Parallel loop means? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
M Parallel processing IEC 60601 testing and 510k submission 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
optomist1 Parallel Cylinders (Dowels or Pins) As Datum Features Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Michael Malis CMS (Centers for Medicare & Medicaid Services) and FDA Parallel Review Program US Food and Drug Administration (FDA) 0
N Capability on Parallel Processes such as Individual Mould Cavities Philosophy, Gurus, Innovation and Evolution 22
F Calculation of Failure - Constant Failure Rates of Parallel System Reliability Analysis - Predictions, Testing and Standards 11
C Is Cycle Time different between Parallel Machines and Single? Lean in Manufacturing and Service Industries 9
E Parallel RBD's (Reliabilty Block Diagram) help - Reliability & MTBF Reliability Analysis - Predictions, Testing and Standards 10
gard2372 RG 1/2" Thread called out on Drawing - Is it an ISO RG parallel gauge thread? Manufacturing and Related Processes 5
J Does anyone know how to adjust/calibrate bench centers that are not parallel? General Measurement Device and Calibration Topics 4
R Portocal II S/W needs some kind of "terminator" to parallel port General Measurement Device and Calibration Topics 3
I Separate procedures for parallel operations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
N APQP phases, sequential or in parallel? APQP and PPAP 8
K Need of calibration procedures for sine plates, v-blocks, and parallel bars General Measurement Device and Calibration Topics 2
A When someone refuses to follow a process.... Misc. Quality Assurance and Business Systems Related Topics 21
R MDEL Process Canada Medical Device Regulations 4
optomist1 Rates Daily or Hourly Process Improvement Training Consultants and Consulting 2
B Toyota PPAP Process - Three Questions APQP and PPAP 3
R Changes vs CMO - How can we simplify this process? Supplier Quality Assurance and other Supplier Issues 3
A Ethics Committee Review Process for IVD Products EU Medical Device Regulations 2
V Laser Welding Process - Impact on Electrical Properties Reliability Analysis - Predictions, Testing and Standards 4
R MRB (Material Review Board) Process using MS Sharepoint or MS Teams Manufacturing and Related Processes 2
M Clinical Benefit of device that only aids in a process for managing or treating disease EU Medical Device Regulations 2
C In-process inspection - Tooling and assembly lines for automotive companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Efficacy of an IT process after a cyber attack ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
N Sterilization Protocol Change in Validation Process and further impacts ISO 13485:2016 - Medical Device Quality Management Systems 1
N Riveting - special process Manufacturing and Related Processes 11
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
A API Spec Q1 Purchasing Process - Supplier Reevaluation based on Supplier Risks 5.6.1.4 Oil and Gas Industry Standards and Regulations 17
D Measurables for Plastic Injection molding process Manufacturing and Related Processes 1
S Cleaning process center change ISO 13485:2016 - Medical Device Quality Management Systems 4
Z Rapid audit template for plastic parts manufacturing process Manufacturing and Related Processes 12
