Parallelism call out of .005" to Datum A - A GD&T question
P
ProProcess
I'm not sure if this is the place for this, I appologize if it is not.
My question:
I have a Parallelism call out of .005" to Datum A.
Is there any obligation to the standard to place the datum on a reference surface and measure the feature?
Or are you free to do it the other way around, that is place the feauture on the reference surface and measure the datum?
Thanks in advance.
Stijloor
My question:
Thanks in advance.
There is an (engineering) reason why that particular surface is specified as a datum feature. Simply follow the GD&T specifications and inspect accordingly.
BTW, why shouldn't you?
Stijloor.
P
ProProcess
I make a part the has a slight deformity on the end of the Datum surface.
This deformity does not exopse itself when the datum is place on the reference surface and the parallelism checks out just fine.
My customer is doing the opposite i.e. clamping the feature and checking the datum.
This in turn exposes the deformity and could be construde as out of spec.
To me, and I think this is what you are saying, the design intent says to place the datum on the reference surface because this is how the part will function, which is in fact, the case for this particular part.
I just have to politely convince my customer that their interpritation of there own drawing is not correct, which is always a slipery slope!
Stijloor
This deformity does not expose itself when the datum is placed on the reference surface and the parallelism checks out just fine.
My customer is doing the opposite; i.e. clamping the feature and checking the datum.
This in turn exposes the deformity and could be construed as out of spec.
I just have to politely convince my customer that their interpretation of their own drawing is not correct, which is always a slippery slope!
A classic example of an interpretation/inspection issue that should have been discussed and agreed upon during the contract review stage.
Stijloor.
P
ProProcess
Stijloor.
True.
The thing is, we've been making this part for more than 20 years.
We/I worked hand in hand with the engineer on both the drawing and machining as the part is very small and barley "makable".
This condition has always been present and has never posed any issue during assembly or in the field.
The company has grown quite rapidly and has new personnel in place that do not work in concert with their own engineering department.
It's not so much that the contract was not reviewed, more like the rules have changed.
Q
qualitytrec
Do you have the original first pieces with sign off from the company?
Also, you say there is a slight deformity on the part. Is there no way to correct the deformity?
The customer should measure to the drawing it is your standard that you build to it should also be the standard they check to.
I have never found the type of discussion you are talking about to be a slippery slope as long as it is done professionally and with integrity. I would pursue discussion of it with some people from the company that know some of the history and try to get some support going in.
mark
P
ProProcess
Do you have the original first pieces with sign off from the company?...
No.
...Also, you say there is a slight deformity on the part. Is there no way to correct the deformity?
Actually, I mispoke in the original post as the tolerance is .0005" not .005". I did not edit it because I did not figure it was relevent for the discussion, but to answer your question, it is.
The area that has the deformity is only .009" thick.
We perform a milling operation that seperates the part from the stock.
At the moment that the remaining material is too weak to withstand the cutting forces, it defletct around .001".
We've tried to eliminate this, but there is not practical way.
Too the deflection does not interfere with the datum or FF&F so it's never been viewed as an issue, that is untill now.
...I have never found the type of discussion you are talking about to be a slippery slope as long as it is done professionally and with integrity. I would pursue discussion of it with some people from the company that know some of the history and try to get some support going in.
mark
I agree with this too.
Luckily the original engineer is still at the company and is scheduled to meet with us and their QAM some time next week.
Thanks for to all for the input, I do appreciate it.
bobdoering
Stop X-bar/R Madness!!
Placing the datum against the reference surface is the correct interpretation. If the customer measures it the opposite way and finds a problem, technically it is irrelevant. But, practically, they are the customer and write the checks. So, until the print can be fixed it would be appropriate to get some kind of written agreement as to how the part is to be measured so that if the proverbial bus runs over someone there is a record as to how you got to where you are now. As it stands, you are doing them a favor to deal with the problem.
G
Geoff Withnell
Stijloor.
Well, to my mind it already was. If Y14.5 is called out, then inspect to Y14. That's what the OP is doing. That's the whole point of having standards, so that every fiddling detail of every drawing doesn't need to be discussed. The design engineer, the manufacturing engineer, the production operator, the supplier inspector and the customer inspection/quality folks should all be using the same rules - the ones in Y14.5!
If the customer insists on measuring and judging conformance some other way, that's an engineering change, which should drive a PO mod!
Geoff Withnell
Stijloor
Geoff Withnell
Geoff, the majority of the engineering drawings that I see when I teach/consult GD&T do not even meet the ASME Y14.5M-1994 (or now the 2009) Standard. I will not even get into GD&T (application/verification)competency!
Stijloor.
M Cp and Cpk for straightness and parallelism Capability, Accuracy and Stability - Processes, Machines, etc. 8
A Outside micrometer anvils parallelism General Measurement Device and Calibration Topics 3
F Flatness VS parallelism Design and Development of Products and Processes 6
M GD&T tolerance or band? Using a symbol like parallelism // Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
B How to check the parallelism error of v axis w.r.t to lateral surfaces General Measurement Device and Calibration Topics 1
C Micrometer Parallelism and Flatness Calibration Requirements and Specs General Measurement Device and Calibration Topics 10
K Calculating (Approximate) Parallelism Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
G Determining flatness and parallelism rapidly Manufacturing and Related Processes 2
Q Micrometers to Measure Coating Thickness - Failed Calibration Flatness & Parallelism General Measurement Device and Calibration Topics 9
B How to measure parallelism btw top surface and bottom surface? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
S SPC on parallelism to the runout of a counterbore feature Statistical Analysis Tools, Techniques and SPC 3
F GD&T Parallelism Interpretation - Print which has a note: //|0.5 | A. Quality Tools, Improvement and Analysis 30
C How to assess Process Capability for parallelism Statistical Analysis Tools, Techniques and SPC 8
D Looking for 100% sort testing equipment for overall length, flatness, and parallelism General Measurement Device and Calibration Topics 1
S ISO 2768-mk print call out Other ISO and International Standards and European Regulations 11
A Call Center troubleshooting guides Medical Device and FDA Regulations and Standards News 5
E BCP (Business Continuity Plan) Call Tree Business Continuity & Resiliency Planning (BCRP) 13
S Call it refurbish or not? Medical Devices Manufacturing and Related Processes 2
T GDT Callout - How to call out a note that requires some clamp load Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
MDD_QNA Accessory or I-don't-know-what-to-call-it-at-this-point EU Medical Device Regulations 3
M Informational EU – Flyer – Call for expression of interest for expert panels on medical devices and in vitro diagnostic medical devices (2019/C 323/05) Medical Device and FDA Regulations and Standards News 0
M Informational EU – Some documents related to Call for expression of interest for expert panels on medical devices and in vitro diagnostic medical devices Medical Device and FDA Regulations and Standards News 0
M Informational EU – Call for expression of interest for expert panels on medical devices and in vitro diagnostic medical devices Medical Device and FDA Regulations and Standards News 1
qualprod Evidence of a talk or phone call in approvals? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Sidney Vianna ISO 18295 - Requirements for Call Centers (Customer Contact Centres) - 2017 Other ISO and International Standards and European Regulations 0
Q Preventive Action - How to call the prevention when there is not a clause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Variation Study on Mined Material - What do you call it (not a control chart) Statistical Analysis Tools, Techniques and SPC 7
G Does ISO 9001:2015 call for a Policy or a Statement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Marc When did you first use what we call E-Mail (aka email) today? Coffee Break and Water Cooler Discussions 17
D A desperate call for help - IEC 62304 software IEC 62304 - Medical Device Software Life Cycle Processes 5
M Update or Replace Nurse Call system? Hospitals, Clinics & other Health Care Providers 3
J RA (Regulatory) Requirements for Outsourced Call Centers Supplier Quality Assurance and other Supplier Issues 3
M Types of Controlled Documentation - Call Lists of Emergency Contacts Quality Manager and Management Related Issues 5
J Passing a variable to the ODBC call in Minitab Using Minitab Software 8
S ASTM-D4000 & FORD "ZW" Call-Outs Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A Should I call this ?Blank Template? a Work Instruction? Document Control Systems, Procedures, Forms and Templates 11
D Complaint Handling Call Centers ISO 13485:2016 - Medical Device Quality Management Systems 7
D Need to include Premise of Outsourced Call Center in ISMS Surveillance Audit? IEC 27001 - Information Security Management Systems (ISMS) 4
A Call for an Expert Speaker @ QuEST Global Career and Occupation Discussions 7
M Monitoring of Processes - Audit of a Call Centre ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
J Perpendicularity-Axis and Plane - Perpendicularity call-out on the print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
M Metric Call Out on a print (from Japan) - 40mm +.002/+.015 Capability, Accuracy and Stability - Processes, Machines, etc. 8
Wes Bucey One of his habits was to call the World Series the "World Serious" Coffee Break and Water Cooler Discussions 24
J GD&T - Concentricity Call Out on a Drawing --> .005 TIR Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
R Should Nurse Call Systems be considered as ME Equipment or System? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
B Flatness Call Out confusing me - What they are wanting and how to check it? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 42
A What do you call the person who is assigned a Corrective Action Request? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Chennaiite Call it, Creativity Funny Stuff - Jokes and Humour 0
Q Gauge R & R for Service Process - Call Center Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
J What do you call this calibration device in your country? General Measurement Device and Calibration Topics 10
