Parallelism, Perpendicularity and Concentricity
#11
Video graphic evidences were presented to the auditor however auditor explained that we should use CMM machine, rather than using traditional measurement method of verification while job is clamped on CNC.
I doubt, it will come back as - "Auditor’s clarification indicates that he was not shown any satisfactory method of measurement of the dimensions mentioned in the Finding and that he did not recommend the use of a CMM machine. Please clarify this discrepancy."
#12
In that scenario, my response would be like this,
We explained this to auditor at CNC machine ABCD, serial number 1234 where machine operator and production manager were present. Suggestion of purchasing CMM machine was discussed however to avoid conflict we withdraw this statement. FARO CMM is already purchased and in use.
#13
@Jigyasa
1. What gaps in your Quality Management System contributed to lack of documentation needed to "validate and document conformity of the finished product to the specified requirements" per API Spec Q1 5.7.7.3?
2. Was an assessment performed to determine if there were any other areas where your facility lacked documentation?
3. What steps have you taken to ensure that, in the future, your facility maintains proper documentation to validate and document conformity to the spec requirements?
#14
These three characteristics were checked and verified during machining stage by QC inspector and at pre-assembly stage by assembly fitter to allow assembly of valve/choke.
Being a routine practice, it was taken for granted and not recorded in dimension inspection report. Verification was done at two stages but not recorded in dimension inspection report, is main gap. Reason of gap, was working team mentality to consider routine practice. This mentality developed gap in QMS system.
We already revised dimension inspection report form to record Parallelism, Perpendicularity and Concentricity. Additionally as described above CMM machine is already in use to assist these characteristics measurements and record.
In our QMS process, product realization start from contract review to final certificate data book and product release. Following stages are followed by us.
  • Contract review
  • Design and development
  • Planning, procurement and receiving inspection
  • Manufacturing and quality control
  • In-process and final inspection
  • Product release after blasting and painting.
While doing analysis of above stages, we corrected contract review stage. We used to do one time contract review against each order either upon email confirmation or against receipt of customer purchase order. We started doing contract review second time for such orders where order realization process started on email confirmation.
For each customer order, we prepare following inspection and test documents to meet specified requirements of the finished products.
  • Inspection Test Plan (ITP)
  • Factory Acceptance Test (FAT) procedure
  • Stage wise manufacturing drawing which includes tolerances
  • Process routing sheet which includes dimension inspection
  • Final pressure test report
  • Blast and paint certificate
  • Product release
Compilation of above procedure’s end result document will be certificate data book. We are making sure to maintain certificate data book which contains all stage wise process records.
#16
Clause description - The organization shall perform all final inspection and testing in accordance with the product quality plan (see 5.7.2) and/or documented procedures to validate and document conformity of the finished product to the specified requirements.
Personnel other than those who performed or directly supervised the production of the product shall perform final acceptance inspection at planned stages of the product realization process.
Objective evidence - Evidenced In process Inspection Report 115, Rev 00 dated 12 Nov 2019 for Machined Body Sl. Number 3018092587, 4-/16”, 5000 PSI, PSL3 API 6A Choke Body. There is no other record evidenced which demonstrates conformity to the requirements.
Thanks.
Can I offer the thought that the finding is less about the methods and more about not recording the results?
From the thread, it seems like you did have a method (although probably not an MSA) to measure the dimensions. If there is still the opportunity, I might probe the auditor further. The correction may be as simple as documenting your indicator checks.
EDIT TO ADD: You will run into the same problem if you buy a Faro, then fail to record evidence after you measure with the Faro.
M Cp and Cpk for straightness and parallelism Capability, Accuracy and Stability - Processes, Machines, etc. 8
A Outside micrometer anvils parallelism General Measurement Device and Calibration Topics 4
F Flatness VS parallelism Design and Development of Products and Processes 6
M GD&T tolerance or band? Using a symbol like parallelism // Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
B How to check the parallelism error of v axis w.r.t to lateral surfaces General Measurement Device and Calibration Topics 1
C Micrometer Parallelism and Flatness Calibration Requirements and Specs General Measurement Device and Calibration Topics 10
P Parallelism call out of .005" to Datum A - A GD&T question Capability, Accuracy and Stability - Processes, Machines, etc. 12
K Calculating (Approximate) Parallelism Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
G Determining flatness and parallelism rapidly Manufacturing and Related Processes 2
Q Micrometers to Measure Coating Thickness - Failed Calibration Flatness & Parallelism General Measurement Device and Calibration Topics 9
B How to measure parallelism btw top surface and bottom surface? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
S SPC on parallelism to the runout of a counterbore feature Statistical Analysis Tools, Techniques and SPC 3
F GD&T Parallelism Interpretation - Print which has a note: //|0.5 | A. Quality Tools, Improvement and Analysis 30
C How to assess Process Capability for parallelism Statistical Analysis Tools, Techniques and SPC 8
D Looking for 100% sort testing equipment for overall length, flatness, and parallelism General Measurement Device and Calibration Topics 1
F How to convert inches to degrees - Inspecting the perpendicularity of 2 lines Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M GD&T (ANSI Y14.5) Perpendicularity Callouts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
F Besides using the CMM - Checking perpendicularity between a plane and an OD Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
F SPC Data Analysis - Excel Spreadsheet I can use for Diameters and Perpendicularity Capability, Accuracy and Stability - Processes, Machines, etc. 6
J Perpendicularity-Axis and Plane - Perpendicularity call-out on the print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J Perpendicularity Callout on a Print - GD&T Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Adjustable Shaft for a Test Fixture to Test Perpendicularity Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
B How to calculate Cpk on Perpendicularity (Cyl Tol Zone at MMC) Capability, Accuracy and Stability - Processes, Machines, etc. 32
S Feature perpendicularity dimension should be good up to how many decimal points? Manufacturing and Related Processes 8
K CMM Filter Settings - Measuring perpendicularity and concentricity Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
D Checking Perpendicularity without using a CMM General Measurement Device and Calibration Topics 7
A Concentricity of two ID's (Inside Diameters) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J Micro Tubing Concentricity Checking using Crosshairs Manufacturing and Related Processes 1
M Position vs. Concentricity vs. Runout - Measurement of a Tube Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
A What is the Standard Tolerance for Concentricity? Various Other Specifications, Standards, and related Requirements 7
J GD&T - Concentricity Call Out on a Drawing --> .005 TIR Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
L Countersink Concentricity Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R Query on Concentricity Inspection Manufacturing and Related Processes 11
Marco Bernardi Concentricity Tolerance: A Unilateral Boundary Situation (Minitab) Using Minitab Software 22
J Blueprint Note: Rectangular Distribution is Permissible - Concentricity of Two Holes Capability, Accuracy and Stability - Processes, Machines, etc. 5
N Concentricity is Out of Specification Manufacturing and Related Processes 15
hogheavenfarm Is there a standard concentricity? Manufacturing and Related Processes 9
B Dimensions and Tolerance Callout - Straightness of shaft - Concentricity Manufacturing and Related Processes 1
D Cpk Studies for Concentricity - Dimension that is spec'd 0.0 - .03 Capability, Accuracy and Stability - Processes, Machines, etc. 15
N Concentricity - Down & Dirty Method? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Explanation of Concentricity and Eccentricity Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
Douglas E. Purdy To Verify Concentricity of Flats to a Centerline General Measurement Device and Calibration Topics 9
M How to Measure Concentricity Correctly Inspection, Prints (Drawings), Testing, Sampling and Related Topics 27
