Part-11 Compliant Document Control & Integrated Training Software
W
Watchwait
We are looking to locate a Part-11 compliant document control software with an integrated training function. That is to say, once a document is (elecronically) approved and released, it would be electronically circulated to all required trainees. Once received, the trainee would have to (electronically) acknowledge receipt thus closing the loop from a tracking standpoint (of course the assumption is that the document was read and understood, but that's a seperate issue). The software would also (upon request) enter reports of training "deficiencies" (released documents where training had not yet been complete).
Right now we do all this manually & it is a huge pain - and we're only tracking ~50 quality system documents. I checked with ArenaSolutions (a fairly significant solutions provider) and they do not have this training function integrated.
Given that it's 2008, I assume we're well behind the curve on this and that no one else is still doing this (training) manually! I know there are a fair number of config control/document control solutions available but in this day & age incorporating the integrated trraining function would seem to be almost standard.
In this regard I'd appreciate any comments/suggestions on specific software solutions that your organization has found to be successful.
Thanks!
W
Watchwait
Thnkas Gert! I had actually checked out that thread and I'm following up on several leads mentioned. Since I noticed you were one of the original posters to the thread, does your Doc Control software automatically route revisions for training? If so does it record the training into reports that can be accessed as needed?:thanx:
B Krause
We are using a system called CAP (Competency: Assessment & Performance) by Soft Design. This is not a document control system per se' but it is a part 11 compliant system for identifying and tracking training requirements via unique sylabi created for each job function.
I also understand that an add-on module is available for developing tests to evaluate the effectiveness of the training.
I hope this helps...
G
Gert Sorensen
Our current system does not have a training module. However, some of the systems that I have been looking at do have one, and when we change this is going to be one of the things that I personally will emphasize.
:bigwave:
Jun Bautista
We use a software called "Plateau" which does the integration that you are referring to. Our Part 11 compliant documents are archived in "Livelink" that automatically links to Plateau which is a software that tracks and maintains training SOPs and requirements. I can probaly explain this to you better if you call me.
rmf180
We utilize Master Control and have recently started using the Training module. The training module is an add-on that can be bundled with your initial contract. The system also has modules for PLM, CAPA, ECO, etc...
Training in Master Control works just like you described. Any document that is identified for retraining will automatically generate training tasks (workflow driven) for all assigned personnel. We utilize an electronic forms process to document if training is required or not. If not, the doc control clerk changes the "route" so that the training task does not initiate. The default setting is launch training.
I'm not sure what else is available. We have used Master Control since 2003.
W
Watchwait
Thanks very much for this feedback! MasterControl looks like it can do the job for us. However, the costs being quoted to me were in the $50k-$100k range for a small (80 person) company. Does that range sound close?
B Part 11 Compliant Document Control Software recommendations Quality Assurance and Compliance Software Tools and Solutions 30
A 21 CFR part 11 compliant Electronic Document Management Systems Document Control Systems, Procedures, Forms and Templates 20
S Is Adobe Sign - E-signature for QMS documents - 21 cfr part 11 compliant? ISO 13485:2016 - Medical Device Quality Management Systems 2
M Suggestions for Electronic Signature Software (FDA 21 CFR Part 11 Compliant) Qualification and Validation (including 21 CFR Part 11) 12
A Alternative to keeping hard copy records that is 21 CFR part 11 compliant Document Control Systems, Procedures, Forms and Templates 0
K 21 CFR Part 11 (and EU) compliant Digital Signatures on a Production Line Other US Medical Device Regulations 5
M How to validate a system to make it compliant with 21 CFR Part 11 Qualification and Validation (including 21 CFR Part 11) 2
M Part 11 Compliant Digital Signature Requirements - Sharepoint Qualification and Validation (including 21 CFR Part 11) 1
D FDA 21 CFR Part 11 Compliant Digital (electronic) Signatures Document Control Systems, Procedures, Forms and Templates 7
D Affordable electronic CAPA system (compliant to FDA 21 CFR Part 11) ISO 13485:2016 - Medical Device Quality Management Systems 1
J Software Outsourcing - 21 CFR Part 11 and HIPAA Compliant Applications Career and Occupation Discussions 1
S Clean room not part of my certification ISO 13485:2016 - Medical Device Quality Management Systems 0
A MDR ANNEX XI part A or Part B EU Medical Device Regulations 0
J Part submission warrant for Level 1 PPAP APQP and PPAP 1
K How to handle GTINs for different configurations of one device with one part number? Other Medical Device Related Standards 0
A 60601-1 : Integrated Dry ECG Electrodes = 2 Patient connections inside 1 applied part? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
D Separation of F-type applied part and remaining parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
V Part selection for R&R studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
D CFR Title 14: Aeronautics and Space PART 120—DRUG AND ALCOHOL TESTING PROGRAM Federal Aviation Administration (FAA) Standards and Requirements 3
D Is PMCF really a continuous activity per Annex XIV,Part B? EU Medical Device Regulations 5
M 21 CFR 820 vs 21CFR820 vs 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
N BF-type applied part MOPP vs secondary IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Relabelling a component that will be sold as a spare part - Do I become legal manufacturer? EU Medical Device Regulations 2
D Partial FAI - AS9102 - One single drawing has 10 part numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Anonymous16-2 21 CFR Part 11 - Steps to take if we want to validate an electronic system Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
T ISO 13485 8.3 - Non-Conforming Materials - on-line rework or part of process? ISO 13485:2016 - Medical Device Quality Management Systems 11
K IEC 62304 compliance - Code reviews as part of verification strategy IEC 62304 - Medical Device Software Life Cycle Processes 5
A 21 CFR part 11 - section 11.100 - Electronic Signature Certification Other US Medical Device Regulations 6
M AS9102B Detail Part/Assembly FAI Form 1 box 13; AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M 2xMOPP insulation for Applied Part B. IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
A ISO 41001:2018 - Clause No.8 Operations Part Quality Management System (QMS) Manuals 2
NDesouza Getting Rid of Part Marking Errors Benchmarking 40
L Wearables 21 CFR Part 11 compliance Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
DuncanGibbons How are part cut out specimens made and tested? Manufacturing and Related Processes 1
S Internal calibrations - Part of an ISO 17025 accredited testing laboratory (Automotive) ISO 17025 related Discussions 16
Ed Panek 21 CFR Part 820 - FDA Label Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
S CQI-23 - Molding System Assessment - Control of part weight IATF 16949 - Automotive Quality Systems Standard 5
DuncanGibbons Looking for example aerospace part CAD files to be used for a case study Career and Occupation Discussions 2
T Overvoltages consideration in Applied Part for RMS Calculation. IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
M Informational How to perform a clinical evaluation of medical devices – Part 2 – Level of clinical evidence and what sufficient clinical evidence means Medical Device and FDA Regulations and Standards News 9
E Part 11 Compliance, Excel living documents (i.e. document master list, equipment list, approved supplier list) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
S FAIR - If we have not produced a part in over 2 years, but nothing has changed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P Scope of application for IEC 60601-1-11 Medical electrical equipment — Part 1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Informational Creating a post market surveillance (PMS) system for medical devices – Part 1 Medical Device and FDA Regulations and Standards News 7
