Part 145 Maintenance Station S/N ESN Character Requirements
totti95
Hello to all,
I am working with maintenance station (PART 145).
I would like to know if there is any specific number of characters for the ESN ?
It is 6 or it can less or more ?
And in the PO the serial number should be write as S/N HLAAC or only HLAAC is fine ?
Thank you in advance.
AEOS_QA
Hi totti95
As a Part 145 you need to use the Serial Number of the dataplate and should also check with your customer if it is different on their order.
I don't believe there is a specific regulatory requirement for the length but the Caption S/N does not form part of the number. There is a heading on your Form 1 Serial Number/Batch No Block or it can be defined electronically. The regulatory authority that issued your Part 145 approval will have guidelines on completing a Form 1
I suggest you have a look at the this document that the ATA efforts for Electronic 8130-3 using Spec 2000 Chapter 16 XML
totti95
Thanks AEOS_QA ! very helpful.
So it not important if the S/N is right like that on the PO : HLAA413 without "S/N" in front of ?
Best Regards
AEOS_QA
The Serial Number is important
It is entered on your Form 1 in Block 10 Serial Number
and needs to match the Dataplate
EASA Form 1 completion instructions state: If the item is required by regulations to be identified with a serial number, enter it here. Additionally, any other serial number not required by regulation may also be entered. If there is no serial number identified on the item,enter ‘N/A’.
A Part 145 Maintenance Data Review EASA and JAA Aviation Standards and Requirements 1
J Maintenance Man Hour Plan which satisfies EASA Part 145.A.30 (example needed) EASA and JAA Aviation Standards and Requirements 4
A EASA Certification Acceptance - The Russian equivalent of EASA Part 145 (Maintenance) EASA and JAA Aviation Standards and Requirements 2
A Maintenance of Aircraft Components - European Regulation Part 145 EASA and JAA Aviation Standards and Requirements 7
M Currently implementing Part 145 repair work - CMM (Component Maintenance Manual) Federal Aviation Administration (FAA) Standards and Requirements 5
P Certifying Staff leaving Part-145 organisation EASA and JAA Aviation Standards and Requirements 4
M List of FAA Part 145 Repair Stations in MS Excel format? Federal Aviation Administration (FAA) Standards and Requirements 0
S C of C release with accompanying EASA Form 1 for EASA Part 145 EASA and JAA Aviation Standards and Requirements 0
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
J MAG 6 and EASA Part-145 Issue 005. EASA and JAA Aviation Standards and Requirements 0
M Transport Canada - EASA Part 145 (Bilateral) EASA and JAA Aviation Standards and Requirements 0
S Calibration and Verification requirement for foreign EASA Part 145 EASA and JAA Aviation Standards and Requirements 7
M Can an organisation hold an EASA Part 145 approval WITHOUT a QMS EASA and JAA Aviation Standards and Requirements 1
X EASA Part 145 / FAA Bilateral Agreement vs. Manufacturing under EASA Part 21 EASA and JAA Aviation Standards and Requirements 2
F When TSA stop to issue new Foreign FAA Part 145 Repair Station? Federal Aviation Administration (FAA) Standards and Requirements 1
J Part-145 Repair Station AS9100 Certification with Scope for Manufacture/Fabrication AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
C AS9100C Audit must include FAA Part 145 (FAA Repair Station)? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
C FAA Part 145/M Compliance Checklist EASA and JAA Aviation Standards and Requirements 7
C EASA Part 145 Audit Programme example wanted EASA and JAA Aviation Standards and Requirements 6
J Certifying Staff Training in a Part 21/145 organisation Training - Internal, External, Online and Distance Learning 3
R FAA Part 145 Vs. AS9110A Comparison and Differences Matrix Federal Aviation Administration (FAA) Standards and Requirements 6
P Currency of Technical Data - FAA Part 145 Repair Station EASA and JAA Aviation Standards and Requirements 4
S How to determine what rating an article falls under - 14 CFR Part 145 Federal Aviation Administration (FAA) Standards and Requirements 5
P Cleaning of Seat Covers under EASA Part 145 EASA and JAA Aviation Standards and Requirements 3
C Desktop Assessment Criteria for Part 145 Certification EASA and JAA Aviation Standards and Requirements 3
B Requirements Summary - Part 21g / Part 21j and Part 145 and DAOS EASA and JAA Aviation Standards and Requirements 4
C FAA Part 145 Compliance Statement help Federal Aviation Administration (FAA) Standards and Requirements 8
D FAA Drug Testing Requirements - FAR Part 145.211 (c)(1)(vi) Federal Aviation Administration (FAA) Standards and Requirements 8
C Part 145 Repair Station Accountable Manager & QE appointments. Federal Aviation Administration (FAA) Standards and Requirements 3
A FAR Part 21/145 vs. EASA Part 21/145 EASA and JAA Aviation Standards and Requirements 5
gard2372 Implementing Lean Flow in Customized Aviation Part 145 Repair Station Federal Aviation Administration (FAA) Standards and Requirements 3
M Any News about the FAA 14CFR Part 121 / 145 Requiring Accredited Calibration? Federal Aviation Administration (FAA) Standards and Requirements 3
C FAR Part 145.161(a)(4) - Summary of Employment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D Human Factors and FAR Part 145.163 'Training Program' Human Factors and Ergonomics in Engineering 9
F Human Factors & Ergonomics - FAR Part 145.163 'Training Program' - Aviation Industry Human Factors and Ergonomics in Engineering 20
R FAA Part 145 Repair Station Postion Descriptions - Seeking Examples Federal Aviation Administration (FAA) Standards and Requirements 3
C Separation of Facilities - Part 145 Repair Station AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 37
R FAA Part 145 Repair Station Drug and Alcohol Testing Policy Federal Aviation Administration (FAA) Standards and Requirements 18
C Part 145 Repair Station - Accountable Manager AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
C Part 145 Repair Station Rating and Capability List vs. ISO 9001 certificate Scope AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 66
Q Interpretation of "external part of implant" in 60601-1 in relation to EN-45502 IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Device History Record Title 21 CFR Part 820.184 (d) QSR 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Wearerofmanyhats Looking for advice on Part Numbers schemes Manufacturing and Related Processes 2
S Customer Defective Part Return Process Process Maps, Process Mapping and Turtle Diagrams 2
S GR & R studies for 16 Cavity part Manufacturing and Related Processes 13
A Has anyone implemented the Adobe Acrobat Sign Validation Pack to be 21 CFR Part 11 Compliant? ISO 13485:2016 - Medical Device Quality Management Systems 9
H Looking to make inspection faster for part with over 100 dimensions. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
S FCC Part 15, 18 harmonized to a standard? Various Other Specifications, Standards, and related Requirements 5
PQ Systems SQCpack Tech Tuesday Webinar 4-Part Series Using SQCpack Software 3
K Device part of combination product certification requirements Medical Device and FDA Regulations and Standards News 3
