Part-145 Repair Station AS9100 Certification with Scope for Manufacture/Fabrication
Can a repair station approved for "repair" works go for AS9100 certification with scope for " manufacture/fabrication"?
The repair station gets work order from customer for "repair" and declares "repair" for return to service activity in FAA Form 8130-3 Airworthiness approval tag/Authorised release certificate.
Will it not violate Part-145.1 Applicability, if AS certificate is issued to same organization for manufacture/fabrication of parts?
BadgerMan
Re: Part-145 Repair Station AS9100 Certification with Scope for Manufacture/Fabricati
Yes, but the scope should specify service, repair, overhaul, or whatever is pertinent.
We have a certificated repair station in the same facility as a PAH and they maintained a common AS9100 cert for several years. The scope read something like "designs, manufactures, and services".
However, last year the repair station "upgraded" to an AS9110 cert.
Sidney Vianna
Post Responsibly
There are repair stations that manufacture replacement parts under their own PMA (Parts Manufacturer Approval). So, in principle, it is possible, but they should only be certified to AS9100 with the proposed scope of certification, IF they are indeed doing it. As I said in a previous post, some repair stations are going for AS9100 certification, rather than AS9110, simply because their CB is not accredited for AS9110.
Hi Sidney,
Your point is correct.So,if the repair station have parts manufacturer's approval,it can definitely go for a certification with scope stating " manufacturing/fabrication of--".
However can a CB grants certificate to a repair station (which is only approved for repair activity) with scope manufacture/fabrication.Will it not violate PART-145 approval?
Yes I agree, a repair station approved for certain scope under FAR-145 can go for AS9100 with same certification scope as it is for repair station approval.Reasons- as you have mentioned- many CBs don't have AS9110.
BadgerMan
I'm confused. There appears to be a conflict here.
So if these are new articles manufactured under a PMA, how will the repair station satisfy a requirement for an FAA form 8130-3?
§ 145.5 Certificate and operations specifications requirements.
(a) No person may operate as a certificated repair station without, or in violation of, a repair station certificate, ratings, or operations specifications issued under this part.
K
kiwisfly
Not too sure what you're asking Joy but there does not have to be a direct relationship between what the 145 repair station scope is and what the 9100 scope is. I agree that perhaps there should be but officially, the two do not have to be the same.
The regulator is only interested in what the organisation repairs, not what it might make and sell to a customer because it will not go out under the MRO's release certificate. The CB might be interested in all the activities included in the scope of AQMS certification, but manufactured parts might go out under a CofC only, repaired items will be sent out on a 8130, Form 1 etc...
A company does not need a PAH (PMA) to make parts and sell them to a customer. The customer may have required them to have 9100 to be an approved supplier. This organisation may be a 145 repair station (maintenance organisation) but the fact their regulatory scope and AQMS scope are different is not an issue. The MRO scope will probably be part of the wider AQMS scope.
Personally, I would like to see IAQG make 9110 mandatory for MROs but reading the 9110B Application statement, to me it appears more likely that more MROs will do 9100, not less.
Cheers,:bigwave:
C:
Here, we have reached to an interesting point.So what happen if the repair station release the part under the MRO's release certificate and stating " repair" in FAA 8130-3? Though the part is fabricated and not repaired.
Also note that customers issues repair order and not for fabrication.As the AMM and SRMs describes the fabrication process,the repair station fabricates those as per those manual.
Original parts are very costly as those are sold by aircraft manufacturers and customer wants cheap replacement through this channel.
K
kiwisfly
Hi Joy
Regardless of who makes a part, a MRO can only fit an 'approved' part to the articles it repairs. The 8130/Form 1 signatory confirms that all the work was completed following the appropriate technical data, all the right equipment was used, and only approved parts were used.
A MRO is allowed to fabricate some new parts but these are normally only replacement parts (such as bushings etc..) that they get made and use themselves. [See EASA 145.A.42.(c)] The parts are only for the MRO's use, they are not allowed to sell them nor attach a release certificate to these manufactured parts, just use them to replace worn parts on the article they're repairing/maintaining. (note the use of the terms article and part - see 9110B definitions)
There's a name for some of those cheap replacement parts you refer to, they're called 'bogus' (see 9110B) or SUP. If anyone wants to make a part for sale (i.e. make it 'approved' in the eyes of the regulator), they can be an OEM, type certificate holder, production organisation or have a PMA.
You will note that the 9100 approval has not been mentioned here, that's because there is no relationship between what a 9100 approval might cover and what a MRO is allowed to do, in the eyes of the regulator. If a MRO thinks 9100 alone will allow them to make parts, attach a release certificate then sell them into the aerospace supply chain, or anyone is selling 9100 stating that this might be a prospect, then I hope you put them right on this point. Very scary if this is happening!!
Cheers,
Thanks friend,you got my point.
F When TSA stop to issue new Foreign FAA Part 145 Repair Station? Federal Aviation Administration (FAA) Standards and Requirements 1
C AS9100C Audit must include FAA Part 145 (FAA Repair Station)? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P Currency of Technical Data - FAA Part 145 Repair Station EASA and JAA Aviation Standards and Requirements 4
C Part 145 Repair Station Accountable Manager & QE appointments. Federal Aviation Administration (FAA) Standards and Requirements 3
M Currently implementing Part 145 repair work - CMM (Component Maintenance Manual) Federal Aviation Administration (FAA) Standards and Requirements 5
gard2372 Implementing Lean Flow in Customized Aviation Part 145 Repair Station Federal Aviation Administration (FAA) Standards and Requirements 3
R FAA Part 145 Repair Station Postion Descriptions - Seeking Examples Federal Aviation Administration (FAA) Standards and Requirements 3
C Separation of Facilities - Part 145 Repair Station AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 37
R FAA Part 145 Repair Station Drug and Alcohol Testing Policy Federal Aviation Administration (FAA) Standards and Requirements 18
C Part 145 Repair Station - Accountable Manager AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
C Part 145 Repair Station Rating and Capability List vs. ISO 9001 certificate Scope AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 66
S C of C release with accompanying EASA Form 1 for EASA Part 145 EASA and JAA Aviation Standards and Requirements 0
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
J MAG 6 and EASA Part-145 Issue 005. EASA and JAA Aviation Standards and Requirements 0
M Transport Canada - EASA Part 145 (Bilateral) EASA and JAA Aviation Standards and Requirements 0
S Calibration and Verification requirement for foreign EASA Part 145 EASA and JAA Aviation Standards and Requirements 7
T Part 145 Maintenance Station S/N ESN Character Requirements EASA and JAA Aviation Standards and Requirements 3
M Can an organisation hold an EASA Part 145 approval WITHOUT a QMS EASA and JAA Aviation Standards and Requirements 1
J Maintenance Man Hour Plan which satisfies EASA Part 145.A.30 (example needed) EASA and JAA Aviation Standards and Requirements 4
X EASA Part 145 / FAA Bilateral Agreement vs. Manufacturing under EASA Part 21 EASA and JAA Aviation Standards and Requirements 2
A EASA Certification Acceptance - The Russian equivalent of EASA Part 145 (Maintenance) EASA and JAA Aviation Standards and Requirements 2
C FAA Part 145/M Compliance Checklist EASA and JAA Aviation Standards and Requirements 7
C EASA Part 145 Audit Programme example wanted EASA and JAA Aviation Standards and Requirements 6
J Certifying Staff Training in a Part 21/145 organisation Training - Internal, External, Online and Distance Learning 3
R FAA Part 145 Vs. AS9110A Comparison and Differences Matrix Federal Aviation Administration (FAA) Standards and Requirements 6
S How to determine what rating an article falls under - 14 CFR Part 145 Federal Aviation Administration (FAA) Standards and Requirements 5
P Cleaning of Seat Covers under EASA Part 145 EASA and JAA Aviation Standards and Requirements 3
C Desktop Assessment Criteria for Part 145 Certification EASA and JAA Aviation Standards and Requirements 3
B Requirements Summary - Part 21g / Part 21j and Part 145 and DAOS EASA and JAA Aviation Standards and Requirements 4
A Maintenance of Aircraft Components - European Regulation Part 145 EASA and JAA Aviation Standards and Requirements 7
C FAA Part 145 Compliance Statement help Federal Aviation Administration (FAA) Standards and Requirements 8
D FAA Drug Testing Requirements - FAR Part 145.211 (c)(1)(vi) Federal Aviation Administration (FAA) Standards and Requirements 8
A FAR Part 21/145 vs. EASA Part 21/145 EASA and JAA Aviation Standards and Requirements 5
M Any News about the FAA 14CFR Part 121 / 145 Requiring Accredited Calibration? Federal Aviation Administration (FAA) Standards and Requirements 3
C FAR Part 145.161(a)(4) - Summary of Employment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D Human Factors and FAR Part 145.163 'Training Program' Human Factors and Ergonomics in Engineering 9
F Human Factors & Ergonomics - FAR Part 145.163 'Training Program' - Aviation Industry Human Factors and Ergonomics in Engineering 20
B Combat Low Part to Part Variation in GRR Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
C Quality Manager as part of Management - 13485 ISO 13485:2016 - Medical Device Quality Management Systems 9
A Complaint review as part of the complaint handling process? ISO 13485:2016 - Medical Device Quality Management Systems 3
D FDA Guidance on Computer Software Assurance versus 21 CFR Part 11 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
F Physical Part Measurement General Measurement Device and Calibration Topics 6
S Clean room not part of my certification ISO 13485:2016 - Medical Device Quality Management Systems 3
A MDR ANNEX XI part A or Part B EU Medical Device Regulations 0
J Part submission warrant for Level 1 PPAP APQP and PPAP 1
K How to handle GTINs for different configurations of one device with one part number? Other Medical Device Related Standards 0
A 60601-1 : Integrated Dry ECG Electrodes = 2 Patient connections inside 1 applied part? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
D Separation of F-type applied part and remaining parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
