Part Number Assignment, Should be coded or Random?
H
harinandu2003
I have just joined on a new electronics company as QA Engineerand just found that the part number assignment of components is not following a fixed scheme?. There are atleast two or three digits which doesn't add any info?. Do you think while adopting part numbering, do we have to code the part number with info such as Value, tolerance, size etc, or just a single digit to classify the class of component is enough and the other digits in the follow an ascending order with the addition of further components into the list.?
Please assist..
MIREGMGR
My experience has been that no matter how carefully you try to construct a coded-significant-identifying-number system, something will come along that your system didn't provide for. Or, someone will second-guess the priorities and assumptions you used.
With fast databases and searchable front ends so easy these days, I think it's easier to assign identifying numbers in some non-significant way, and just provide everyone with easy access to a computer that runs your networked materials management software.
ScottK
Not out of the crisis
Please assist..
Just do what works best with your system.
I don't beleive there are any rules that a part number has to represent anything - it could just be a random string of numbers and letters if you want.
Meaningful part numbers certainly make sense though - especially for new people trying to learn the business.
I mean a part number like "BV-.75-F-F" for a Ball Valve, .75", Female, Female is a lot more intuitive than g4563j673r for the same part.
but the bottom line is you have to work with what your production/inventory tracking system is capable of.
ddunn
Part number assignment should be simple. If you really want to add a single digit to classify a component that's OK but the more significant digits you add the faster the numbering systems falls apart and you end up with more confusion than significance.
The scheme should be consistent such as 6 digits with a dash number (123456-01). Just keep it simple.
Agree with Scott - do what suits your system. Bottom line, there should be a nomenclature system to identify as its for your own good.
H
harinandu2003
Thank you, I have often found this -01 added to the end of the part number. Wonder, if this is a revision to the part mandated by some changes or a new part qualified for the same part number?.
ddunn
The "-01, -02..." can be used to define different configurations of the same basic item. If you use a dash (tab) number you must differentiate between the drawing number and the part number. (drawing number 123456, part numbers 123456-01, 123456-02...)
bommer
Whether you decide to use significant or non-significant part numbering, make sure you are using a centralized system to generate the part numbers and NOT an Excel spreadsheet, a "central" notebook in the office, or a single person in the office. You want to make sure the scheme you come up with is followed correctly and duplicate part numbers are not being generated. If you need such a system, check out part-numbering.com, it's fairly pain-free.
Re: Part Number Assignment, multiple numbers same part
I have been following these threads, and gained much useful insight on numbering, but have not found help for my situation. We are a machine job shop, and we often get the customer part number for the item. We also generate a company job number for ourselves, and there are often multiple customers, each with thier own numbers for the same part. Often a part will have 4 or 5 part numbers, depending upon the customer. Predictably, we are having trouble tracking all this. We are limited on resources and personnel, so we depend on a spreadsheet to look these up manually. For my quality records, I try to use our internal number, but other departments use other numbers. I think the entire scheme is broken and needs rebuilding, but I am having some trouble figuring out how to tie all these numbers together easily. Anyone have any experience with this sort of thing?
I Restricting scope to one part number for one customer IATF 16949 - Automotive Quality Systems Standard 6
K How to handle GTINs for different configurations of one device with one part number? Other Medical Device Related Standards 0
K Relabeling or Not Relabeling - Adding our internal Part Number barcode label 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Change control and configuration management - When to create a new model/part number? Other Medical Device and Orthopedic Related Topics 0
D IMDS for machining - Can my customer request a IMDS number for a part? APQP and PPAP 2
Mikey324 GR&R - Little to no part to part variation in single part number Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
S Number of MOPP for Type BF Applied Part (Medical Device Electronics) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
D PSW (Part Submission Warrant) Question for Part Number Change APQP and PPAP 9
E Control Plan Contents - Part Number / Latest Change Level FMEA and Control Plans 2
J Meeting Feasibility Requirement - High number of part quotes IATF 16949 - Automotive Quality Systems Standard 6
G AS9102 Design Supplier Part Number vs. Customer Part Number AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Supplier Quality with Prototyping Parts with no Part Number or Drawings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
E Does anyone know what a Part Number for an OTC Monographed Drug is? US Food and Drug Administration (FDA) 3
optomist1 Counting the number of Coplanar Surfaces on a Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Is ECN (Engineering Change Notice) Necessary for Part Number Change IATF 16949 - Automotive Quality Systems Standard 4
S Same computer for RUO and IVD - Same part number for 2 different IVDs EU Medical Device Regulations 2
kisxena Separate NCR for each Part Number required or necessary? Nonconformance and Corrective Action 4
S AS9102 FAI for part number with no official drawing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Acceptable Part Number formats in the Aerospace industry Federal Aviation Administration (FAA) Standards and Requirements 1
S Customer Part Number Changes - Control Plan Question FMEA and Control Plans 1
P New Part Traceability - Lot number and finished product traceability ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
G Changing manufacturer's part number Manufacturing and Related Processes 1
D TS 16949 Control Plan and Part Number Revision Change Level FMEA and Control Plans 1
R Vantage/SAP Part Number Nomenclature help Document Control Systems, Procedures, Forms and Templates 1
L Product Identification & Traceability (when a part number changes) ISO 13485:2016 - Medical Device Quality Management Systems 7
R OEM part number is listed in the Indications for Use Question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
K Resubmission of PSW required by customer because of part number change IATF 16949 - Automotive Quality Systems Standard 8
K ECO (Engineering Change Order) Revision - Letter change or part number change? Manufacturing and Related Processes 13
B Can I use Multiple Sub-Tier Suppliers for the Same Part Number APQP and PPAP 2
K Tool crib clerk inventories Perishable Tooling - Part Number Tool Lists - Auditable? General Auditing Discussions 2
J Document control basics - Two different drawings with the same part # and rev number Document Control Systems, Procedures, Forms and Templates 12
G Customer part number for PPAP - Chain of distributors involved - Catalogue items, too APQP and PPAP 6
S Assigning Internal Part Number Document Control Systems, Procedures, Forms and Templates 4
C New PPAP submission required when changing part number? APQP and PPAP 11
M Reject Tags - red tag is a form and needs to have a part number and revision? Document Control Systems, Procedures, Forms and Templates 14
R Control Plans - How Many are Needed? A control plan for every part number? FMEA and Control Plans 6
M Para 4.6.3c - What is meant by the last part; ...number and issue of...? QS-9000 - American Automotive Manufacturers Standard 4
B Final Dock Audit - Dock Audit (inspection) on every part number? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 32
S GR & R studies for 16 Cavity part Manufacturing and Related Processes 12
A Has anyone implemented the Adobe Acrobat Sign Validation Pack to be 21 CFR Part 11 Compliant? ISO 13485:2016 - Medical Device Quality Management Systems 9
H Looking to make inspection faster for part with over 100 dimensions. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S FCC Part 15, 18 harmonized to a standard? Various Other Specifications, Standards, and related Requirements 3
PQ Systems SQCpack Tech Tuesday Webinar 4-Part Series Using SQCpack Software 2
K Device part of combination product certification requirements Medical Device and FDA Regulations and Standards News 3
L "to be treated as APPLIED PART": is shopping in requirements allowed? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
X Separation of battery powered FB type applied part IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
N Direct Part Marking of the "CE" symbol- Class I Device EU Medical Device Regulations 1
P Controls over Systems Documentation in 21 CFR Part 11 Qualification and Validation (including 21 CFR Part 11) 1
R Separation and PE Requirements of a Type B Applied Part IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
P Part 21G - Liabilities of a Quality Manager Form 4 Post Holder EASA and JAA Aviation Standards and Requirements 4
