Re: Gage R&R Experts...Part variation, unilateral tolerance, destructive testing
For the %Tolerance (inspection) decision, it makes no difference how you select the parts.
For % Study Variation (process control) decision, part selection is critical. You have two options:
Do you have data from a long term capability study available?As I said before, the same gages are used for Process control and Inspection.
I'm certain that I can't get parts which represent the entire process spread? So, How should I collect my samples?
Is it ok to collect those 10 parts without representing the entire process spread?
If so, does the standard deviation of part variation from the process capability study and the 10 parts that I select be from the same lot?
- Option A: Find 10 parts that represent your process variation. Can you collect 1 part per production setup? This should represent your expected variation.
- Option B: Use existing information on the process variation from a long-term capability study (if you currently collect data for process control, use that to calculate the long term variation). Ignore the software calculated % Study Variation. Either manually calculate a new % Study Variation as described above, or if the software supports it (e.g., Minitab) use the supplemental metric that is calculated using manually input process variation data.
