Parts Salvage, Overhaul and Resale - AS9120 Registration question
phxsun2001
Involved - Posts
One of the requirement of AS9120 is - Value-added distributors would NOT be included for the standard due to customer-product changes. (Use AS9100). See below.
I am auditing a small stocklist broker and they sometimes obtain as removed (AR) stock and outsource the repair to a 145 Certified Repair Stations.
They "control" parts for airworthness thru the use of the 8130-3 tag and the guidance given in 8130.21 to reissue this tag.
Is this considered "value added" and not qualified to become AS9120 certified? Please help
TY
Description of AS9120 standard:
The AS 9120 Standard is the requirements for a Quality Management System based on AS 9100 which adds 100+ additional requirements that are specific to distributors who carry aircraft components like, fasteners, electronics, gaskets, etc. It helps ensure that they handle the materials properly and track the part from OEM to customer. AS9120 was developed for pass-through distributors of aerospace items and addresses chain of custody, traceability, control and availability of records.
Companies that procure parts, materials and assemblies and sells these products to a customer in the aviation, space and defense industries. This includes organizations that procure products and split them into smaller quantities.
This standard is not intended for organizations that rework or repair products. Organizations that perform work that affect or could affect product characteristics or conformity should use AS9100 or another general quality management system standard.
The standard would be applicable for organizations that resell, distribute, and warehouse parts found in aircraft and other aerospace components. Value-added distributors would NOT be included for the standard due to customer-product changes. (Use AS9100)
Marc
Fully vaccinated are you?
Another quick "Bump" in case someone can help with this one. My Thanks in advance!
dsanabria
Your question is an excellent one - the standard is not clear based on your quotes, however, this paragraph in AS9120A might give you the authority to treat brokers as AS9120 - as long as they do not do repairs, maintain, modify or alter characteristics of the product.
Sidney Vianna
Post Responsibly
If they outsource the repair work, as you mentioned above, they are responsible for product conformity. Certainly, the repair is a value added activity, which, in my opinion, disqualifies this organization from AS9120. The following guidance from the IAQG applicability document applies:
This standard is not intended for organizations that rework or repair products. Organizations that perform work that affect or could affect product characteristics or conformity should use AS/EN/JIS Q 9100 or another general quality management system standard.
dsanabria
So... in conclusion - brokers that purchase or acquire aerospace products should be using AS9110 (overhaul & Repair of products).
They should also read it carefully for Exclusions and Non-Applicable clauses, and they should make it clear that product is outsource but monitored.
Sidney
AS9120 cable and wire distributors place lines - marking on the wire for identification purposes per PO. Is that considered "value added" or just marking per PO.
Sidney Vianna
Post Responsibly
In my opinion, yes, that would constitute value added work, because it affects product conformity.
Keep in mind that the eligibility document from the IAQG is a guidance document and not a strict prohibition. There are non-aerospace organizations certified to AS9100, much to my chagrin. So, it would not be surprising to see an aerospace distributor doing value added work certified to 9120.
AS9100:2009 is better with the clarification of applicability
Organizations that procure parts,materials and assemblies and resell these parts to a customer in the aviation,space and defense industries,including organisations that procure products and split them into smaller quantities for resale,should use the IAQG-developed 9120 standard
above applicability statement does not include repair work and as Sidney mentioned that even the repair is outsourced,the organisation is responsible.
phxsun2001
Involved - Posts
Most of these companies I audited were ISO9001 registered for years and they were outsourcing R&O. They decided to go for AS9120 because of customer request. They would not have upgraded to AS9120, if it would not allow them to outsource R&O. Can they include the part distribution activities in the scope of AS9120 and the monitoring of the outsource Repair and Overhaul activities under the scope of ISO9001?
TY
Marc
Most of these AS9120 certified companies are also ISO9001 certified. Can they use AS9120 to handle the distribution activities and ISO9001 to handle the outsourcing of repair and overhaul activities
TY
I tried to post this comment twice, but it doesn't show up. I am trying it again.
Most of these AS9120 companies are also ISO9001 registered. Can they use AS9120 for the parts distribution activities and use ISO9001 for the outsource of the R&O activities? The activities would be different in the scope of the two certificates. Will this work?
TY
:topic: I see two posts with the same content so I'm not sure what the problem is, but the software is working as it should.
Evelyn7E The fastest way to get supplier to ship good parts to you Supplier Quality Assurance and other Supplier Issues 10
B Cl. 9.2 - Moving parts - Applicable only to machinery? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B How to test operator to see if they can catch the defective parts? Manufacturing and Related Processes 6
P Interchangeable/alternative parts in BOM (medical device) Manufacturing and Related Processes 4
T Is handling chemically treated parts safe? RoHS, REACH, ELV, IMDS and Restricted Substances 18
R Select the 1 Supplier based on the Parts Durability from 6 Supplier Samples using Minitab Using Minitab Software 11
aleexander Grounding of metallic accessible parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
K 10 parts, 4 operators, 3 replications and each part has 3 location to measure. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K Unused Service Parts in Newly Manufactured Medical Device? Other US Medical Device Regulations 1
M MSA angle issue - Nylon parts using Aberlink 3D Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
I What revalidation is necessary if we change parts in a WFI loop ? Qualification and Validation (including 21 CFR Part 11) 1
Fjalar Spare parts for discontinued MDD compliant class I medical device EU Medical Device Regulations 4
S For Parts Manufacturer Approval (PMA) Is 100% Inspection Required? Federal Aviation Administration (FAA) Standards and Requirements 2
S Defibrillator Protection applicability When using Multiple applied parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
F Recording Nonconforming Purchased Parts Nonconformance and Corrective Action 5
D Suggestions for Ishikawa for hyperdetailed customer - plastic molding automotive parts Nonconformance and Corrective Action 9
R Is a FAIR required on parts that we design? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C Packaging Long Parts Manufacturing and Related Processes 3
D Separation of F-type applied part and remaining parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
John C. Abnet VDA 6.3 - Question 7.3 - "blocking of parts" VDA Standards - Germany's Automotive Standards 6
I When is necessary to have RoHS declaration on non-electrical parts? REACH and RoHS Conversations 1
Z Rapid audit template for plastic parts manufacturing process Manufacturing and Related Processes 12
C Scrapping on production floor - Setup parts 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
G Bad Parts cause Customer line stop IATF 16949 - Automotive Quality Systems Standard 13
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
P FDA Approved Product Contact Parts ISO 13485:2016 - Medical Device Quality Management Systems 6
M Identifying Applied Parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Nonconforming parts accepted by operator with intention Human Factors and Ergonomics in Engineering 33
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Sister-company providing parts is only ISO 9001 registered IATF 16949 - Automotive Quality Systems Standard 7
A AS9100D 8.1.4 Prevention of Counterfeit Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
C Difficulties getting RoHS/REACH for cheap parts RoHS, REACH, ELV, IMDS and Restricted Substances 1
G Same parts but new customer - What will the auditor ask me? IATF 16949 - Automotive Quality Systems Standard 2
G Need to change KPI we called NC parts (maximum 3%.) to FTQ (first time quality) IATF 16949 - Automotive Quality Systems Standard 4
Q Do you classify applied parts? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R Defib-proof applied parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
S Earthing of moving parts, designing tips IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C Quantifying risk in choosing the number of parts, operators and replicates in a GR&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Ed Panek Corona Virus impact on Supplier Audits and Received Parts ISO 13485:2016 - Medical Device Quality Management Systems 4
bryan willemot Shipping Aerospace parts without Stress certs Manufacturing and Related Processes 20
H Capability Data for Paint Thickness on Painted Parts Statistical Analysis Tools, Techniques and SPC 10
J SPC - Stamping parts - Small batch size Statistical Analysis Tools, Techniques and SPC 6
D 3 Companies - Medical device parts and substances - Responsibilities EU Medical Device Regulations 4
B Accessible parts per 8.4.2 b) - Touch currents in combination with MOOP or MOPP? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J Traceability of component parts - Bolts, screws and washers ISO 13485:2016 - Medical Device Quality Management Systems 3
R Traceability on Unmarked Parts - AS9100 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
CPhelan Best metrics for monitoring low volume (<1000) parts per vendors Supply Chain Security Management Systems 1
DuncanGibbons Best practice for identifying "items" of parts for DFMEA analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L PPM - wrong parts or defective parts? IATF 16949 - Automotive Quality Systems Standard 18
