Parts used for Gage R&R's
  • Thread starter Thread starter t_partlow
  • Start date Start date
t_partlow
I do not work for a manufacturing company, so we do not have "parts" per se, but we do have reference and working standards. To perform a Gage R&R, is it necessary to know the "true" size of what you are measuring? Example: R&R on a micrometer, do I need to know the actual size of the gage block? Thanks.
No, you don't need to know the true size of the part. R&R is only looking at the variability of the measuring system.
t_partlow,
Howste is right. You do not need to know the true or nominal value. You'll need to know the expected measurement range - tolerance / spec width &/or the process variation - though, because parts should be selected to cover this range. I am not sure how you would construct your "parts" with gage blocks.
Welcome to the forums! :bigwave:
My problem
We presently use an electronic differential level for calibrating granite surface plates. My original thought was to "calibrate" a surface plate "X" number of times with "Y" operators and base the calculations on the results. However, this will not cover the entire measurement range of the levels. The other way I came up with is to use a sine plate and gage blocks to generate angles covering the entire measurement range of the levels. I'm not really sure which would be better. Any insight would be a great help.
Agree with Atul
t_partlow,
I totally agree with Atul.
I also welcome to the forums!
Good LuckQ
:thedeal:
Actually, if you are using the levels that I am thinking of, the gages themselves lend very little to the variations in the process of calibrating granite surface plates. The process of moving the levels to each point winds up being 80% or more of the variation. Surface inperfections of granite, variations in placement, dust on the plate, temperature fluctuations, etc. will be you major contributors. When you measure a plate, check your closure errors. Those will, by and large, be very close to being your process variation.
Granted, I've never done a GR&R, as I've always had to perform full uncertainty budgets, which takes quite a bit more into account. But as far as variation goes, your tool won't be the cause.
Ryan
