Pass through characteristics on PFMEA
I need to understand how to identify the pass through characteristics that need to be linked or controled in to our PFMEA. Are this characteristics coming from customer specifications or do we need to identify them according to the customer needs?
According to my experience, this pass through characteristics are product characteristics generated at the supplier facilities and you as tier 1 dont have any control of them. So this is why I dont consider them in my process PFMEA, the most that I can to is to prevent that those characteristics gets damaged in our process.
Thank you!
Ron Rompen
Just a correction on what a 'pass through characteristic' is.
A PTC (pass through characteristic) is a part feature which is NOT used by your customer, but will be used further down the supply chain. As an example, you manufacture a transmission component. Your customer (the Tier 1) assembles your components into a finished transmission.
On your component there is a hole which is used to allow an assembly bolt to pass through when attaching the finished transmission to the vehicle. This is a PTC for your Tier 1 customer.
Well, yes. In this case I am Tier 1 and I dont use this characteristic, but the customer will. It depends on the level of supply chain you analyze it.
T Definition Pass-through Characteristics Qualification Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
S Definition Pass Through Characteristics - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
Geoff Cotton Ford 'Pass Through Characteristics' - Q1 Assessment Checklist Customer and Company Specific Requirements 14
Crimpshrine13 IATF 16949 and ISO 9001 Remote Support - Pass Through Inventory IATF 16949 - Automotive Quality Systems Standard 20
A IATF certification for pass through supplier IATF 16949 - Automotive Quality Systems Standard 1
D Supplier Scorecard, Assessment of Pass Through Items From Sub Tier Suppliers Supplier Quality Assurance and other Supplier Issues 4
D PVC Packaging on Pass Through Parts - An environmental issue? Miscellaneous Environmental Standards and EMS Related Discussions 3
Q Pass Through Rate Ratio Improvement and Defining Pass Through Rate Preventive Action and Continuous Improvement 6
H Is it a requirement for run charts to have inspection data or can it have just a pass/fail check mark Records and Data - Quality, Legal and Other Evidence 1
M Customer PPm (CPPM) on Pass-Thru Items Statistical Analysis Tools, Techniques and SPC 0
H Pin Gauges - tight fit = pass or fail? Reliability Analysis - Predictions, Testing and Standards 7
E Calibration-Conditional Pass Measurement Uncertainty (MU) 2
B Lowest cost way to pass Lead Auditor exam ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Is using ANSI/ASQ Z1.4-2008 the correct sampling plan to determine Pass/Fail of Apparel measurements? AQL - Acceptable Quality Level 8
S How can a R&D center pass IATF 16949 certification? IATF 16949 - Automotive Quality Systems Standard 9
J AMS 2750 E Clause3.5.17.13 TUS Pass/Fail Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Z Inspection Form With Pass/Fail Formula Excel .xls Spreadsheet Templates and Tools 11
B Best place is to purchase IEC 60417 labels that will pass markings test IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
K UL 6601 - Would an off-the-shelf Android tablet, powered by USB, pass UL 6601? Other Medical Device Related Standards 3
Q Can a fail still be a pass? (Criteria Level B for 61000-4-6 Conducted Immunity) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M What CQA Preparation Material helped you to pass the exam? Career and Occupation Discussions 6
I Device Can't Pass IEC 60601-2 ESD Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
B What is the implication for someone who does not meet the 70% pass mark for QMS-Lead. Professional Certifications and Degrees 2
T First Pass Yield - Welding Process Improvement Manufacturing and Related Processes 3
C Difference between "Pass/Fail Testing" "Test To Failure" "Degradation Test" FMEA and Control Plans 1
Z Pass-Though Characteristics in PFMEA (Process FMEA) FMEA and Control Plans 2
B How to begin tracking FPY (First Pass Yield) and "Downtime" tracking Manufacturing and Related Processes 3
S ISO 9001:2008 Sec 7.6 - Can we just log measurement devices as 'Pass/Fail'? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 118
B Calculation of First Pass Yield (FPY) Six Sigma 9
S Verify Software System Testing: Verify that results meet the Pass/Fail Criteria IEC 62304 - Medical Device Software Life Cycle Processes 1
J Reliability Prove-out, Pass-Fail Testing Reliability Analysis - Predictions, Testing and Standards 2
I Supplier Using Reference Part for PASS/FAIL Inspection Supplier Quality Assurance and other Supplier Issues 8
G How much time must pass after the first Certification Audit for us to appear in OASIS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
L Definition Throughput Yield (TPY) or First Pass Yield Calculation - Help Needed Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
N VDA 6.x - Requirements Pass Down to Suppliers ....Obliged?? VDA Standards - Germany's Automotive Standards 5
Hami812 Gage R&R on Automated Tool that supports Pass/Fail and some Parametric Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Contractor Pass required for Contract Cleaners? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Hami812 Gage R&R Process Method - Pass/Fail Criteria Offered to Operators vs. Parametric Data Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Hoffman Scratch Hardness Test - General Parameters for Pass/Fail (Paint Coatings) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R First Pass Yield - Am I doing correct the First Pass Yield Metric Quality Tools, Improvement and Analysis 2
S How to Calculate Overall FPY (First Pass Yield) Quality Tools, Improvement and Analysis 2
M Limited Calibrations - An instrument that will not pass a full calibration, OOT General Measurement Device and Calibration Topics 8
F First Pass Yield Helped Requested Lean in Manufacturing and Service Industries 1
R Should the fault tests pass if temperature goes high in short time? IEC 60601 - Medical Electrical Equipment Safety Standards Series 15
K False Pass/Fail Information from GR&R (Gage R&R) Minitab Using Minitab Software 6
I Service Supplier Rating where Objective Pass/Fail Data is not Available Service Industry Specific Topics 7
R First Pass Yield Base Line Measurement Lean in Manufacturing and Service Industries 2
R ASQ CQE Practice Exam - Do I need to score very well to pass? Professional Certifications and Degrees 17
R Formula for calculating Money Value equivalent to 1% FPY (First Pass Yield) Six Sigma 5
M Developing a CPI for First Pass Yield Final Inspection - Need help Quality Tools, Improvement and Analysis 7
