Patient Monitor Viewing Distance Usability Requirements
L
LiamD
Are there any usability requirements that define or recommend the acceptable distance that values can be viewed on a screen of a patient montor?
Thanks,
Liam
Mikishots
Thanks,
Liam
Most modern patient monitors have adjustable font size. The idea is to set the text to be legible at the distance required; if you can't read it, either increase the font size until you can or simply move closer. If you can't move closer, the monitor is of no use.
L
LiamD
Thanks Mikishots. Yes there are a number of ways that I can change the fonts.
I wanted to know if there were any regulatory/standards/guidance which define the legibility/readability of important values.
Mikishots
Define "important" values. I'd say that this would depend on the patient's condition and is solely the call of a physician or nurse.
somashekar
Positioning of the monitor at a suitable height to be able to operate and connect / disconnect safely, keeping it within the reach of the monitor cable and sensors length that connects to the mains as well as the patient is considered by the hospital / ICU / OT design and layout. From this position the doctor / nurse must be able to read perhaps standing at the diagonally opposite end of the patient bed. How much this could be ?
Perhaps 8 feet, 10 feet ? or around that. This must be acceptable as a useability input requirement.
L
LiamD
Thanks Somashekar. These are all good points that you highlight.
My fundamental question is regulatory/standards/guidance which define the legibility/readability of important values. Important values would be defined by the intended use of the instrument. For example, the 60601-1-8 alarms standard defines a viewing distance for visual ALARM SIGNALS.
If a visual indicator is necessary for the OPERATOR to identify the equipment or part of the equipment that requires OPERATOR response or awareness, at least one visual ALARM SIGNAL shall be provided that:
a) indicates the priority of the highest priority ALARM CONDITION; and
b) can be perceived correctly at a distance of 4 m from the ALARM SYSTEM.
Is anyone aware of regulatory/standards/guidance which define the legibility/readability of important values.
somashekar
I guess if there is any such regulatory/standards/guidance which define the legibility/readability of important values, it would have been mentioned within the 60601-1-8...
I have had a quick look and haven't found anything directly but from the general standard you get
7.1.2 Legibility of Markings
....shall be clearly legible...
....the viewpoint is the intended position of the operator...
...the illuminance is the least favourable..in the range of 100lx to 1500lx..
7.1.1 Usability of the markings
The manufacturer shall address the...risk of poor usability..associated with the markings..
I have had a look at some of the particular standards (the Part 2 standards) where one might expect those clauses to be modified by a particular requirement but haven't found anything. I don't though have a copy of -2-49 (multifunction patient monitoring equipment) which might be the most relevant.
Without a direct requirement I think it is up to you, as manufacturer, to define the likely use scenario (so where and how is your equipment designed to be used) and use risk analysis to identify what information must be identifiable from, say, the end of the bed and what may be legible only from up-close.
Marcelo
It´s really up to you because it depends on intended users.
IEC 60601-1 third edition has a requirement on legibility of markings which could be used for other information.
AAMI HE 75 has some guidance, for example, a table with Recommended character height and corresponding font sizes for various reading distances.
Anyway, those can be found in a lot of human factors books.
somashekar Lexan 9330 PC FR Grade Processing Problem - Patient Monitor Housing Manufacturing and Related Processes 3
D The right way to monitor in-patient incidents in a hospital Hospitals, Clinics & other Health Care Providers 4
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
A 60601-1 : Integrated Dry ECG Electrodes = 2 Patient connections inside 1 applied part? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
A 60601-1-2 : Integrated Dry Electrodes = PATIENT COUPLED PORT? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
T Documenting hazardous situations associated with user/patient population ISO 14971 - Medical Device Risk Management 3
J Medical software Patient outcome Medical Information Technology, Medical Software and Health Informatics 2
S Immobilization and patient positioning for radiotherapy Other US Medical Device Regulations 10
JoCam Mobile Patient Hoists and Electrical Testing Other Medical Device Related Standards 0
D Defibrillation protection for patient connection except for electrodes IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
M Informational US FDA Draft Guidance – Breast Implants – Certain Labeling Recommendations to Improve Patient Communication Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Draft Guidance – Patient Engagement in Design and Conduct of Medical Device Clinical Investigations Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Patient Engagement Advisory Committee – Cybersecurity in Medical Devices: Communication That Empowers Patients Medical Device and FDA Regulations and Standards News 0
M Informational TGA – Medical device patient information leaflets and implant cards Medical Device and FDA Regulations and Standards News 0
A Moving and positioning of patient - Mechanical hazard IEC 60601 - Medical Electrical Equipment Safety Standards Series 18
T Battery Powered Device - MOP and Patient Auxiliary Currents IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
U Hand-Held dosing device has no PATIENT - Interpretation of the PATIENT definition IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
M Informational US FDA – Patient-Reported Outcomes (PROs) in Medical Device Decision Making Medical Device and FDA Regulations and Standards News 0
M Informational US FDA – Priority List of Patient Preference-Sensitive Areas Medical Device and FDA Regulations and Standards News 0
M Informational US FDA – Patient Preference Information (PPI) in Medical Device Decision-Making Medical Device and FDA Regulations and Standards News 0
S Calibration - Isolated current meter - Measuring patient auxiliary leakage current Calibration and Metrology Software and Hardware 4
L PC in patient environment - BF applied part that uses USB to connect to PC IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
W IEC 60601-1-2 Susceptibility/Immunity for device intended to be used in patient body IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M Medical Device News TGA Consultation: Potential reclassification of active medical devices for diagnosis and patient therapy Medical Device and FDA Regulations and Standards News 0
M Medical Device News CAMD – Patient Safety – The Focus For All Competent Authorities For Medical Devices (CAMD) Members Medical Device and FDA Regulations and Standards News 0
M Position paper Team NB Statement - Patient safety EU Medical Device Regulations 0
U PATIENT CONNECTION for HAND-HELD Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
O Is Patient Cable Exempted from EFT Tests? (IEC 60601-1-2) CE Marking (Conformité Européene) / CB Scheme 1
K How to document a Patient Outcome claim for a Class I device? US Food and Drug Administration (FDA) 5
A US patient gets Medical Device in Europe and needs spare parts 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R Definition Patient - Definition in IEC 60601-1 Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
M "Single Patient Use" Terminology Confusion Other Medical Device Related Standards 9
R Risks to Health - Patient and Clinician ISO 14971 - Medical Device Risk Management 4
F How to provide 2 MOPP (Means of Patient Protection) - Heating Rod IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
B AAMI Standard - 6 Foot Radius Patient Vicinity Various Other Specifications, Standards, and related Requirements 2
M Not sure what standards apply to non-electrical patient bed EU Medical Device Regulations 6
B Use of Y1 capacitors for MOPP (means of patient protection) IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
W How can I test the Patient Leakage Current of an Infusion Pump? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
E Collecting Patient Information and Patient Identifiers - HIPAA Other US Medical Device Regulations 2
T Patient / User Protections in Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 3
D Patient Leakage ISO 7176-14 vs. IEC 60601-1:2005 Reporting Requirements Other US Medical Device Regulations 1
E Minitab for hourly patient census - Control Charts Using Minitab Software 6
Marc Patient Data Revealed in Medical Device Hack Medical Information Technology, Medical Software and Health Informatics 1
M AS 4706 (Personal Response Systems) & AS 3811 (Patient Alarm Systems) Equivalents? Other ISO and International Standards and European Regulations 4
M Understanding DC Patient Leakage Failure from 0.3VDC IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
R Separation of Network Port from other Circuits including Patient Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S Searching for a Lab to test Patient Safety for Product used in Mouth CE Marking (Conformité Européene) / CB Scheme 2
Ronen E 510(k) Exemption: Powered Patient Transport / Wheelchair Elevator (Stairlifts) Other US Medical Device Regulations 0
