sounds you need an entire processes checklist, it will cover several different process such as drilling, plating and etching process....
will see if I can get back to here later.
Look at this in the attachment files. It is a general one which refers to an old revision to the IPC-A-610 standard, but you should be able update it. It's general and may be what you need.
