PCBA Visual Inspection Tools & Methods - discounting Optical Tools
harry
#11
Sorry, did not realise what I had done, did not intend it to be advertising simply stating fact. Will not happen again.
You are welcomed. As stated earlier - We sure do appreciate you coming to the Cove, and do look forward to your continued assistance.
P
Pistonbroke
#12
Hi All,
Has anyone utilize a quick visual inspection method like using a clear template copy of the PCBA fabrication drawing (laying it over the PCBA) to do inspection?
Yes, I've seen this method used to good effect on boards which have multiple stages of assembly - the gerber files for the solder paste masks are blown (the pad sizes increased) and used as a layover which only picks up the components placed for that phase of manufacture.
Downsides : slightly reduced visibility, and poor refraction of lighting along with a limited life of the visual aids - leading to an additional reecurring cost.
Another version of this I have seen was that a cnc driller router was used to cut out the template which was then physically aligned to lie over the pcba, the initial generation of this mask is slightly more time consuming, but it's a superior method, with greater longevity (until someone tears it) and is much preferred by inspectors.
JoCam IEC 60601-1 and 60601-1-2 retest after PCBA change IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
R PCBA process validation Qualification and Validation (including 21 CFR Part 11) 2
D Software Validation - Contract manufacturer of Components (PCBA's) Qualification and Validation (including 21 CFR Part 11) 7
C PCBA Hardware Component different failure types - How to rate detection? FMEA and Control Plans 8
M PCBA Drawing Best Practices IPC Class 3 ISO 13485:2016 - Medical Device Quality Management Systems 1
alonFAI Determining PCBA Xray Test Sampling Size Statistical Analysis Tools, Techniques and SPC 1
S Who is doing BGA cross sectional analysis in assembled PCBA in INDIA? Reliability Analysis - Predictions, Testing and Standards 1
T Faulty PCBA - Our Testing Fails but Manufacturer's Testing Passes Supplier Quality Assurance and other Supplier Issues 2
D PCBA Lab Temperature & Humidity Requirements - Advice needed Manufacturing and Related Processes 7
N Off Shore Supplier PCBA REACH Reporting RoHS, REACH, ELV, IMDS and Restricted Substances 4
P SMT (Surface Mount Technology) and PCBA Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
O PPAP Validation for Electronic Parts (PCBA) APQP and PPAP 6
T PCBA Verification and Testing Manufacturing and Related Processes 3
U Validation of Wave Solder Process - PCBA for Medical Products Qualification and Validation (including 21 CFR Part 11) 7
P Brightness Specification for PCBA Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Q Reliability of a Ferrite Inductor mounted on a PCBA Reliability Analysis - Predictions, Testing and Standards 1
Q PCBA Qualification Plan and Protocol example wanted Qualification and Validation (including 21 CFR Part 11) 1
H Basic questions about Installation, Operational & Performance Qualification - PCBA Qualification and Validation (including 21 CFR Part 11) 11
N PCBA (Printed Circuit Board Assembly) Conformal Coating Material and Thickness? Reliability Analysis - Predictions, Testing and Standards 15
D Would Design & Process FMEA (PCBA) be sufficient to fulfill requirement of Cl 7.1? ISO 13485:2016 - Medical Device Quality Management Systems 2
J Using Weibull to Calculate an Optimal PCBA Burn-In Test? Reliability Analysis - Predictions, Testing and Standards 4
P Can anyone help with ESD Protection (PCBA)? How is ESD generated? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
K Visual Inspection Effectiveness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
P Missing 1m visual alarm signal in case of software/display failure, mitigation? ISO 14971 - Medical Device Risk Management 3
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S PPAP Progress - Visual Status Board APQP and PPAP 0
Marc Visual Inspection - Color Vision Coffee Break and Water Cooler Discussions 15
S Need Assistance in Visual Inspection - Tiny electronic components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
I Best visual description for SOPs? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
John Predmore What size pinhole can be reliably detected using visual inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
A Visual acuity test - Product to have passed a jaeger test Human Factors and Ergonomics in Engineering 6
L Off the Shelf Software VISUAL ERP system ISO 13485:2016 - Medical Device Quality Management Systems 1
S Agreement for allowance for visual criteria after submission APQP and PPAP 1
C EPA NPDES VISUAL ASSESSMENT - No Significant Storm Event ISO 14001:2015 Specific Discussions 0
R Can a Attribute Study be considered a Visual Inspection? Reliability Analysis - Predictions, Testing and Standards 6
P Gage R&R on Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
B Gage R & R on Visual Inspection using the Cross Tabulation Method IATF 16949 - Automotive Quality Systems Standard 4
L IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA) - Visual Inspection IATF 16949 - Automotive Quality Systems Standard 14
S Do you use audio-visual streaming during FDA inspection? US Food and Drug Administration (FDA) 3
T Customer Requirement for Sorting - Visual Defect on Plastic Part IATF 16949 - Automotive Quality Systems Standard 9
R Visual Attribute Inspector Capability and KAPPA Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C Visual Presentation of Supplier Score - .xls Spreadsheet Excel .xls Spreadsheet Templates and Tools 1
D Visual Inspection with No Visual Reference General Measurement Device and Calibration Topics 2
M Use of Excel and VBA (visual basic for applications) in quality systems Excel .xls Spreadsheet Templates and Tools 3
C What are the Visual Requirements for Borescope Inspectors? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Attribute G&R for all Visual Controls in Control Plan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
E Reference Only on Gage or Visual Aid Calibration Frequency (Interval) 4
N How to reduce RPN of Visual Inspection Process FMEA and Control Plans 6
alonFAI Finished PCB Final Visual Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
