PCI PIN compliance and Gap analysis
Hello Elsmar!
My company is looking at starting some business which requires PCI PIN security. Does anyone have experience with this or a gap analysis that could be helpful? We are essentially starting from nothing and I need some help getting everyone to understand how much work this is going to be.
Thanks in advance!
K PCI DSS - MS Paint and other screenshot tools Other ISO and International Standards and European Regulations 0
M Calculating MTBF for plug-in PCI cards Reliability Analysis - Predictions, Testing and Standards 2
M Does anyone here have experience implementing PCI DSS (Data Security Standard) IEC 27001 - Information Security Management Systems (ISMS) 10
C PCI External Expresscard interface After Work and Weekend Discussion Topics 2
M Sample ISO 27001 and 'PCI Security Standard' Gap Analysis Report Other ISO and International Standards and European Regulations 2
G Supplier Checking With Gauge Pin Problem Solving, Root Cause Fault and Failure Analysis 2
G Oversized Threads - What sized stab pin would be best to quickly check for oversized thread holes General Measurement Device and Calibration Topics 5
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
I Can we use pin gauges to measure an accurate Cpk ? Capability, Accuracy and Stability - Processes, Machines, etc. 9
Z Two Payment Identification Number (PIN) for the same order in DFUF website 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M AS9100 Rev D and Pin Gages General Measurement Device and Calibration Topics 7
S GRR on ID with set of pin gauges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Q How can you justify using a more accurate Pin Gage class? General Measurement Device and Calibration Topics 16
A Does an attribute study (Go/NoGo pin gage) need two studies (1 for each pin) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Ron Rompen Question on 'Class of Fit' - Gage Pin Clearance Manufacturing and Related Processes 2
C Black Oxide Gage Pin Calibration Requirements General Measurement Device and Calibration Topics 4
B Can we calibrate a standard pin with a gauge? General Measurement Device and Calibration Topics 2
Q Pin Gauge Setup - Measuring the OD of a Catheter Manufacturing and Related Processes 1
W Hach 5 Pin Connector Pinout Diagram needed General Measurement Device and Calibration Topics 3
C Rolling the correct M8 1.25 Pin Thread Manufacturing and Related Processes 2
W Setting up a Zmike for Pin Gage Calibration General Measurement Device and Calibration Topics 3
C ZZ Pin Gage Tolerances and Calibration General Measurement Device and Calibration Topics 2
S Pin Gage Calibration - Pins seem to be "growing" General Measurement Device and Calibration Topics 9
K Pin Gage Use vs. Calibration Frequency Calibration Frequency (Interval) 13
C Using a Pin Gage to check True Position of Inline Holes, Design, Tolerance. Etc Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Checking True Position with Pin Gage Measurement Uncertainty (MU) 3
O Clavicle Pin Classification Number: UMDNS Code Other Medical Device and Orthopedic Related Topics 1
O ISO Standards For Intramedullary Pin Design History File Other Medical Device Related Standards 2
S GR&R for Dowel Pin Holes Using Deltronics Pins Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
D What is the difference between Pin and Plug Gages General Measurement Device and Calibration Topics 13
A ID Calipers Accuracy and Pin Gages Manufacturing and Related Processes 13
D Calibration of Pin Gages using a Calibrated Caliper that measures to 4 decimal places General Measurement Device and Calibration Topics 15
N Calibration of Setup Fixtures & Pin Gages General Measurement Device and Calibration Topics 5
P How to manage loose Pin Gages without Identification on the machining floor Calibration Frequency (Interval) 19
D Nonadjustable M&TE - 10 year calibration interval? Pin Gages Calibration Frequency (Interval) 11
M Gage pin calibration - Actual calibration readings required on the calibration cert General Measurement Device and Calibration Topics 3
C Gage pin calibration procedure for accurately calibrating gage pins General Measurement Device and Calibration Topics 18
B Pin Gage Calibration Procedure - ISO 17025:2005 accreditation requirements? ISO 17025 related Discussions 8
G Slip fit - Size on size dilemma for pin and plug gages Manufacturing and Related Processes 4
V Calibration of Pin Gauges General Measurement Device and Calibration Topics 2
H E Coat (Electrocoat) Pin Hole Paint Defects - Help needed Nonconformance and Corrective Action 3
A Pin Gage - Gage R&R Studies - One Pin or Entire Set? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Pin Gauge Calibration using a Micrometer - Accuracy & Calibration Level Question General Measurement Device and Calibration Topics 10
L Are you Qualifying your own Gageblocks and Pin Sets? General Measurement Device and Calibration Topics 16
J Using Pin Gages as a Measurement Tool for Ppk/Cpk studies Capability, Accuracy and Stability - Processes, Machines, etc. 11
C Internal Diameter Measurement and Pin Gage Calibration General Measurement Device and Calibration Topics 6
J Calibration of Pin Gages - AS9100 Calibration Requirements General Measurement Device and Calibration Topics 23
B A reference or formula for the largest pin which will fit in a hole General Measurement Device and Calibration Topics 6
ScottK Dimension on the high limit with a plus gauge pin - YOU MAKE THE CALL! Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
G API REG Pin and Box Threading - Minimum Gages Needed - Thread, Plug and Ring gauges? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
