Performing first Gauge R&R study tomorrow
Sean Kelley
We are performing our first gauge r&r study tomorrow and I am wondering if there are any last minute suggestions to successfully complete it. Any problems or issues to avoid or experiences to make it go more smoothly. Thanks to all for your help.
Bob_M
What type of gage?
Do you already have a spreadsheet or gage R&R program setup?
Just explain to the operators to use the gages as they were trained and record HONEST readings. You are not there to judge them. But if they are using the gages wrong you will retrain as needed.
Typical gage R&R i'm experienced with is-
3 operators
10 pieces
3 times each piece
(10 in a row randomly - repeat 2 more times randomly)
Next operator repeats.
Atul Khandekar
Just what Bob said... +
Select your parts carefully so that they represent the entire process range adequately.
Tell us how it goes. Good luck.
JaySturgeon
Part Selection
We are a metal stamping company. I always select parts that represent the population of the production run. Typically three at the beginning of a coil of material, four in the middle and another three at the end.
Appraisers, as Atul mentioned, need to feel at ease with what they are doing. They are not being judged in any way. That point must be clear!
Hope this helps.
J Performing a MSA on a new gauge using different parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Format and/or procedure for performing Gauge R&R on a CMM? Document Control Systems, Procedures, Forms and Templates 2
E Performing a GRR when you get multiple readings over time per part. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Performing Additional Inspections IATF 16949 - Automotive Quality Systems Standard 10
Mr Roo Discovered dishonesty after performing an internal audit General Auditing Discussions 5
D ISO 13485--Question regarding performing calibrations in house. ISO 13485:2016 - Medical Device Quality Management Systems 13
M Who is performing quality control? IATF 16949 - Automotive Quality Systems Standard 2
AllTheThings ISO-17025 accredited TEST lab performing internal calibrations (Yes: Here is how) ISO 17025 related Discussions 8
Geoff Cotton Performing a Delta Audit General Auditing Discussions 12
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
I Root Cause Analysis when someone simply stops performing a task? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
H Question about implications of performing Firmware upgrade via MDDS - Medical Device Data Systems 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
V Sequence of performing risk assessment: User_FMEA (User Errors) vs Design Inputs FMEA and Control Plans 1
Y Performing product audits in a manufacturing facility Manufacturing and Related Processes 13
armani ISO 9001:2015 - How to apply 7.1.5 to an organization performing only design ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Performing PQ on a Small (tabletop) Air Heat Treating Oven ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Thoughts on performing an ISO 9001:2015 Remote Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
H Performing a TUS on a Furnace used at One Temperature - AMS2750-E AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 27
drgnrider EMR performing audits of EMS Miscellaneous Environmental Standards and EMS Related Discussions 13
C Performing an ISO 9001 based Supplier Audit - Multiple Supplier Facilities Supplier Quality Assurance and other Supplier Issues 4
D Performing a Gage R and R with No Specification Range Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Going Rate for Performing a Supplier Audit? Consultants and Consulting 1
B Performing MSA on Straightness of a Cylinder Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
C Performing a MSA as it relates to Calibration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
K Production Operators Performing GP12 (General Motors Containment) Customer and Company Specific Requirements 2
L How is the interaction physically happening while performing ANOVA GR&R? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
E Exam for Personnel performing Calibration General Measurement Device and Calibration Topics 7
B Performing a Gage R&R Study with Minitab 13 Using Minitab Software 5
M Requirements for Laboratories performing ASTM Tests Various Other Specifications, Standards, and related Requirements 4
J 5.15 or 6 Sigma? What multiplier to use when performing a Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A SOP for performing Annual Product Reviews for Medical Device and Pharma Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
D Severity or Occurrence? Performing an FMEA on Motorcycle Operation FMEA and Control Plans 9
K Performing PPAP Retroactively APQP and PPAP 8
H Proprietary Processes - How to Protect and still comply when performing an FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J Performing Internal Calibrations - Dial gauges, micrometers, height gauges, calipers General Measurement Device and Calibration Topics 8
D External Parties performing Internal Audits? TS 16949 Clause 8.2.2 IATF 16949 - Automotive Quality Systems Standard 15
JoCam Budding Consultant: What to charge for performing a desktop study. Career and Occupation Discussions 10
Miner Upcoming article - Within-part variation when performing an R&R Imported Legacy Blogs 6
D Performing Internal Audit of our Accounts System Internal Auditing 4
S Performing Internal Audits as per Canada MDR GD 210 Internal Auditing 7
E Minimum data for performing an Anderson Darling Test Statistical Analysis Tools, Techniques and SPC 1
A Difficulties in performing MSA on Rockwell Hardness Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
G Performing an Internal Audit on the Cost Estimating Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
6 Badly Performing Packaging Machines Manufacturing and Related Processes 1
D People Management - Managing an under performing subordinate Career and Occupation Discussions 15
armani Competence for performing compliance audits - 4.5.2 Miscellaneous Environmental Standards and EMS Related Discussions 6
C New to performing internal audits - Looking for audit questions Internal Auditing 5
P For business performing PRODUCT DEVELOPMENT ONLY, what is best QMS for certification? Quality Manager and Management Related Issues 2
