Perfusion System - HLM Components with Vendor Neutrality
Highground
Would I include the components of a HLM as generic or list them as different systems that can be customized and configured to a central monitoring systems if the components don't have 510K clearance as individual systems? Or will they need individual 510k clearance first before it can be a part of the Perfusion System? Plus the Perfusion system can be use by other manufactures centrifugal pumps with the system...vendor neutrality.
e.g. Ventilation system is a monitoring system that will monitor and adjust to settings and is an accessory to the Perfusion system? :confused:
I did a look up roller blood pumps, ventilation, and blood gas monitors and Perfusion Systems. They all seem to have their own 510k clearances.
Any discussion on the subject would be appreciated.
shimonv
Hi there,
Your post is almost cryptic and it makes it difficult for people to understand and contribute from their knowledge.
From what I could gather, if the HLM (Hear Lung Machine) components are independent medical devices, each with a specific function - you must 510(k) them separately. In order to achieve vendor neutrality you need to present them as different systems that can be customized and configured to a central monitoring system. Of course, you will need to provide V&V records to prove it.
Hope it helps.
-Shimon
Ronen E
Problem Solver
Moderator
If you intend to distribute a perfusion system in the USA, including elements / accessories / peripherals / the like that aren't 510(k) cleared and aren't 510(k) exempt, you'll have to include all of them in your 510(k) scope and treat them as components of your own device (the system).
If you only intend to supply a control unit that is supposed to work with other, interchangeable units, you'll have to support your claims of safety and effectiveness with each and every listed configuration. In that case I don't recommend including devices / units that aren't 510(k) exempt and don't have one.
Cheers,
Ronen.
Highground
This is exactly what I needed to know. Sorry it seemed cryptic, didn't mean for it to be that way.
I thank you both! I was struggling with this all week. reading the FDA guidance was confusing. I pulled up a few of the summary's from different makers, but I couldn't make out if their components were independent of the HLM system or not. I may have a few more questions soon.
:thanx:
Ronen E
Problem Solver
Moderator
You're welcome.
The first and most important thing to do is define the regulatory scope of your product / device / system. This is something only you can do, since we don't have access to the specifics. Once this is done, there might be a lot of guidance to go through, but from my experience FDA guidance is quite instructive in most cases. Don't worry, it'll all fall into place at some point. And you can always come back with more questions.
510(k) summaries are not the ideal reference for strategic regulatory issues because they only contain the bare minimum that's required for informing the public. Applicants will normally only put in there what the FDA makes them divulge. Those summaries become useful later on, when you go to the nuts and bolts of putting your 510(k) submission together (and even then it's usually barely enough!). Your strategy should be derived from a good general understanding of the regulatory system and from a broad knowledge of relevant guidance documents.
Cheers,
Ronen.
Highground
I will certainly know more specifics once I start this new position next week. My previous 510k was working with a team for a needle safety device. It seems like that project was simple compared to this new endeavor.
Highground
You're welcome.
Cheers,
Ronen.
Thank you Ronen. You were correct...things are falling into place. They are not as far as I was lead to believe...thank goodness! Only at mid-point with the devices. So one device at a time will be put forward for clearance. :D
Ronen E Terumo Cardiovascular Systems is recalling some Advanced Perfusion System 1 products Other Medical Device and Orthopedic Related Topics 2
M Go Live With New ERP System before Recertification Audit General Auditing Discussions 6
John C. Abnet Terms- Different Items in a system ISO 26262 - Road vehicles – Functional safety 0
G Management Review (integrated system) Management Review Meetings and related Processes 17
M Unique Quality Management System for 2 sites ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Orthopedic Implants (Knee system) Sterilization Indicators Manufacturing and Related Processes 6
C Projects in the CAPA system Preventive Action and Continuous Improvement 6
E Insulation diagram for ECG monitoring and diagnosis system. IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R Quality System Functional Safety Checklist / Guidance IATF 16949 - Automotive Quality Systems Standard 0
J Mastercontrol or other system ISO 13485:2016 - Medical Device Quality Management Systems 0
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P MSA study for visual system with artifical inteligence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Big companies suffer from quality management system? ISO 13485:2016 - Medical Device Quality Management Systems 1
qualprod Assign a name to a home-made ERP system? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
H IEC 60601-1 ME equipment or ME system IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Biological indicator system classification under MDR EU Medical Device Regulations 2
N Chemical Testing on Medical Devices - Solutions in a container closure system (bag) EU Medical Device Regulations 1
J Audit Checklist for Integrated Management System for ISO 9001:2015, ISO 14001 & OHSAS18001 (IMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
R How would you work without a quality management system? IATF 16949 - Automotive Quality Systems Standard 3
J ISO 13485 System 'soft start' - How to best reflect this in initial audits, management review minutes and other records? ISO 13485:2016 - Medical Device Quality Management Systems 3
P Conformity assessment based on a quality management system or production quality assurance EU Medical Device Regulations 3
D EQMS - When the internet or system might not be available ISO 13485:2016 - Medical Device Quality Management Systems 7
S Quality management system (Well head installation & maintenance) Quality Management System (QMS) Manuals 5
DuncanGibbons Model-Based procedures and Architecting the QMS as a System Document Control Systems, Procedures, Forms and Templates 2
P How to develop executable quality management system for rookies? IATF 16949 - Automotive Quality Systems Standard 9
Anonymous16-2 21 CFR Part 11 - Steps to take if we want to validate an electronic system Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
M Requirement to manufacture under a quality management system EU Medical Device Regulations 4
G IMS (Integrated Management System) 9001, 14001 & 45001- Request Assistance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K Sterile barrier system symbols - Label redlines for a Class III device (Kit Box) EU Medical Device Regulations 0
R SAT (System Accuracy Test) temperature according to AMS2750E AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A Building up a global quality management system ISO 13485:2016 - Medical Device Quality Management Systems 2
A Building up a global quality management system 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
T ISO 17025:2017 requirement 5.7.b. about maintenance the integrity of the management system ISO 17025 related Discussions 1
H Pedicle screw system Conformity Assessment Other Medical Device Related Standards 2
S Rees System Validation Qualification and Validation (including 21 CFR Part 11) 1
Q User Requirement Specification for HR (Human Resource Management System) Manufacturing and Related Processes 1
A Document Change Notice vs complete System re-write Manufacturing and Related Processes 4
C NCR (Nonconformance System) Software Nonconformance and Corrective Action 7
K ISO 15223-1 Sterile barrier system - The 3-layer symbol EU Medical Device Regulations 1
T Ideas for developing a Supplier Quality Management System, non automotive ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Starting an ISO 41001:2018 Facility management system Other ISO and International Standards and European Regulations 3
K ERP System Software Validation - ISO13485 2016 4.1.6 Design and Development of Products and Processes 8
F MDR system/procedurepack (article 22) with device acc. to MDD and MDR CE Marking (Conformité Européene) / CB Scheme 2
M MDR requires the NB to perform "tests in order to check that the quality management system" EU Medical Device Regulations 3
S CQI-23 - Molding System Assessment - Control of part weight IATF 16949 - Automotive Quality Systems Standard 5
D Classification of Syringe (nozzle) of needle free injection system. EU Medical Device Regulations 8
