Periodic Quality Manual and Procedure Review Requirements
TrishDish
Hi everyone, this is my first post since signing up so please bear with me. I probably don't have this question in the correct 'thread' but didn't see a better place.
I am new to my company (we are ISO 9001 registered) and I am looking for others' thoughts and recommendations concerning evidence of periodic review (e.g., annually) of your quality manual and procedures. Should a company be able to provide objective evidence of periodic review by nature of a form, appendix to each document, etc.? Otherwise how do you prove that you've done the review? I know if your manual and/or procedures say you do a periodic review you've got to provide the evidence but if your documents don't say you do it do you think it will be questioned in a 3rd party audit?
Thank you in advance for your thoughts on this subject.
P
Pudge 72
Re: Periodic QM and Procedure Review
I would make sure that what you are describing is included in my Internal Auditing program. When you use the cascade approach to auditing, you are basically starting with the standard, reffering to the Quality Manual, filtering down to the Procedure, and reviewing associated work instructions for whatever particular process that it is you are auditing. Essentially, you are constantly reviewing the documents that you mentioned specific to the element and the standard. The biggest benefit of course is that the results of the audit are documented - so, you always have the objective evidence that this "review" was completed as well as the results and findings of conformance and effectiveness. Your specific document or procedure numbers and revisions will be listed within the body of the audit report - easy for an auditor to see that it actually took place.
Hope that helps.
sagai
Hi Trish,
internal audit (8.2.2) and management review (5.6) responsible for that with documented results and planned follow ups.
br
Sz.
qusys
Hi TrishDish,
welcome in the forum and nice to meet you.
What you say shall be included in the mandatory procedure for the documentation control, as per related ISO 9001 clause.
Clearly it is up to the organization to establish how to meet the requirement to provide review. For example, some organizations that I visited as a quality auditor set a periodical review of the quality documentation ( I intend procedures and work instruction) each two years at a minimum, if in the meantime no modification were done to the document.
They use to put again the procedure in the approval workflow and update the revision history putting the comment "periodical biennial review", also updating the revision in the template as well as the revision date .
THere are also some electronic document mgmt software that remembers the due date coming to the expiration for each procedure, otherwise you should create a list of all quality documentation and procedures and setting a reminder for reviewing on outlook calendar for each procedure owner.
Hope this helps
see you and let us know:bigwave:
TrishDish
This is exactly what I was looking for! Thank you so much for your help.
B SAP Audit trail Periodic Review EU Medical Device Regulations 1
D CSV - Periodic Review Qualification and Validation (including 21 CFR Part 11) 1
Marc Interesting Discussion The periodic table is 150 years old - March 2019 Coffee Break and Water Cooler Discussions 3
P Periodic Review - Deviations/incidents that are reviewed Qualification and Validation (including 21 CFR Part 11) 5
M FDA or CE requirements for periodic checks of data backups and retrievals EU Medical Device Regulations 4
T Regulation (EU) 2017/745 and PSUR (periodic safety update report) EU Medical Device Regulations 9
V Periodic review criteria for reviewing/updating SOPs US Food and Drug Administration (FDA) 1
P EU MDR and PSUR (Periodic Safety Update Report) EU Medical Device Regulations 38
V Periodic Audit Trail Review - Scope, Content & Frequency Qualification and Validation (including 21 CFR Part 11) 10
B IATF 16949 Cl. 8.5.1.5 - Requirement for Periodic Overhaul IATF 16949 - Automotive Quality Systems Standard 10
S How to document revisions after Periodic Review of documents ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
I Does ISO 13485 have a Periodic Document Review Requirement? ISO 13485:2016 - Medical Device Quality Management Systems 7
A Current Control Periodic Document Reviews - Process Updates in the FMEA FMEA and Control Plans 3
F Periodic Review Requirements for Software - Medical DeviceS Software Quality Assurance 2
S Is hiring a CB for certification and periodic audits an outsourced activity? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
V Where & How to Capture Details of Periodic Reviews of Change Control & CAPAs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
T Clause for Maintenance - Periodic Maintenance Activity (Oil change) Internal Auditing 4
C API Q1/ISO-TS 29001 Periodic Assessment of Stock Oil and Gas Industry Standards and Regulations 3
S Auditing our own activity - Periodic audit of our documentation Internal Auditing 11
B Can I Claim That Periodic Calibration is Not Required? ISO 13485:2016 - Medical Device Quality Management Systems 6
Q Computerized System Periodic Review Requirement - Pharma Company Qualification and Validation (including 21 CFR Part 11) 7
R Periodic evaluation of suppliers - ISO 17025 4.6 Purchasing services and supplies ISO 17025 related Discussions 3
R Do Engineering Standards require periodic review? ISO 9001 4.2.4 (b) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
M Documents of External Origin - Periodic or annual verification of revision status ISO 13485:2016 - Medical Device Quality Management Systems 10
M Surface plates - Questioning the need for periodic calibration of surface plates General Measurement Device and Calibration Topics 12
I Periodic Review of Process and Equipment Validation Qualification and Validation (including 21 CFR Part 11) 4
R Periodic / Maintenance Audits Schedule ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Periodic Product Requalification Process IATF 16949 - Automotive Quality Systems Standard 1
tony wardle Periodic Evaluation of Legal Compliance - ISO 14001 - 4.5.2.1 - Legal Requirements ISO 14001:2015 Specific Discussions 22
K Periodic validation of raw material test reports (7.4.3) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
K Review complete, no changes needed - When a Procedure is due for a periodic review? Document Control Systems, Procedures, Forms and Templates 10
T QP-5.6.0 - Management Review should be both periodic and continual Management Review Meetings and related Processes 14
S ISO 14001 - Periodic External Audit by Consultant Requirement? ISO 14001:2015 Specific Discussions 99
A Meeting the ISO 14001 Periodic Audits Requirement - Internal vs. External Auditing ISO 14001:2015 Specific Discussions 11
D ISO 9004 6.2.2.2 has listed "periodic refresher programs for people already trained" General Auditing Discussions 6
M What does the APQP manual mean by the term 'Periodic Requirements' FMEA and Control Plans 2
J Document Control NCR - Periodic Reviews Document Control Systems, Procedures, Forms and Templates 3
M Doubt about the element 15.3 (VDA) - Periodic cross-check and repeated inspections VDA Standards - Germany's Automotive Standards 3
N Guidance - Cost of Good Quality Misc. Quality Assurance and Business Systems Related Topics 2
D Quality plan for moving locations ISO 13485:2016 - Medical Device Quality Management Systems 3
was named killer Job Opportunity-Quality Engineer-Tampa Florida Job Openings, Consulting and Employment Opportunities 0
Marc Job Opportunity – Quality Assurance Specialist - Suspense 7 April 2021 Job Openings, Consulting and Employment Opportunities 0
J Quality Objective for QMS prior to Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
J Quality Objectives and resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M PSA Suppliers - CSR matrix and need the quality manual of PSA APQP and PPAP 2
A Quality Control Datasheets Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
T Quality auditor legal right to see Board meeting minutes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
