Personal names in docs - Goes against every documenation practice I know!
AmandaMusser
Hello Fellow Covers!
I have yet another Quality issue that I'm fighting and I need some input from you so that I am armed when I head into battle!
One of the many hats I wear is Quality Documentation. I have a Process Engineer who is trying to get all of our control charts in the same format, so he's created a template. They'll all look alike & we'll be able to read them :) GREAT IDEA!
The problem is, he is calling out specific employees names on the charts themselves as the persons responsible for filling out the forms! :nope:
Example: Control Chart - Freezer #1, "Persons Responsible for Completion - James".
This goes against everything I have ever learned about documentation & I've been doing this for 20+ years! Unfortunately, I'm not able to find anything anywhere that says you shouldn't do it.
Have any of you ever run into this issue & how do you handle it?
:popcorn:
Pancho
wikineer
Re: Goes against every documenation practice I know!
Hi Amanda,
If you have a good org chart, then this is easy. Just instruct doc authors to use positions rather than persons.
If not, then you have an opportunity.
Using folks names is easier than using positions when positions aren't so well defined. With a missing or outdated org-chart or vague position descriptions, document authors will often resort to using "James" rather than trying to figure out what post should be doing it. Maybe James does it because he's always done it and no one else wants to touch it, even though he really shouldn't be doing it.
Sorting that out is complicated. But that is the opportunity.
As a bonus, cleaning up the org-chart is like the proverbial low tide: those not wearing their shorts will have to put them on.
AmandaMusser
Hi Pancho,
The Process Engineer is attempting to create accountability for the completion of the charts and he believes that calling out names in the charts will accomplish this. He lists himself as the document owner, the manager as the person responsible for the chart & the employee for filling it out. (Of course, I told him that if the manager is the ultimate responsibility, why do we have to also have the employee names.)
That's minimum 3 persons names on each document. When a person leaves for better (or worse) employment, someone will be responsible for making sure that a QDO will be done to update the documents.
I'm currently sitting in a customer audit with an ISO 13485 company, their Senior Engineering Manager is here performing the audit. I asked his opinion on this subject and he said he wouldn't allow it in his company.
What if James isn't here for a week because he's on vacation? The document states that he fills the chart out. If someone else does it, technically, we could get an NC for that, right?
Randy
Doomed for failure before it even starts :lmao:...
Hey tell the Engineer to go for it, step back, give him all the credit in the world, and enjoy the results :ca:
AmandaMusser
Randy, your response is awesome and it's what I have been contemplating since this subject came to light!
:agree1:
Pancho
wikineer
Hi Pancho,
I wonder why he thinks that calling out personal names provides more accountability than calling out positions.
What's a QDO?
Regardless, you've hit upon one good reason to give your Process Engineer: If he would use posts rather than names, then no document updates are required when folks leave, get transferred or are absent.
(BTW, in any policy you could provide for automatic responsibility reassignment up the chain of command to cover any type of absence, whether or not your docs use personal names. But your Process Engineer might not think of that. :) )
Guess so. Unless you have that auto-responsibility reassignment.
I agree with you and your customer auditor. It's better to avoid personal names in docs. But the whole thing might not be worth a fight now. It's good that the standard forms and instructions are being created. You might let your process engineer use them like that for a while, and leave the corrective action for your continuous improvement cycle. Eventually (quickly) a NCR will come up, and the corrective action may be to remove the personal names from docs. That will then be reflected in your [SOP: Document Writing], and no-one will use personal names anymore.
Randy
Amanda I'm an auditor, I do nothing else but audit, mainly for CB's and this is a case that if we auditors were awarded the status of Ace, like a fighter pilot, in a scenario like you've described, I would only need one mission to make it.
Golfman25
How big is the company? What is the turnover? You may be making a mountain out of nothing.
Can work ok in a smaller company. Not the best practice in the world and can complicate things due to personnel changes, but hardly worth "fighting." Good luck.
drgnrider
Had a similar problem when I took over as ISO Mgnt. Rep.
MANY documents had names, I spent too much time revising documents when someone no longer had that responsibility, a minimum of three every time: document, document register, org chart. Used the time savings, (doc owner requesting changes, modifying, proofing, publishing (written & electronic), notification to all, etc.), to justify using positions... and this was my annually required 6-Sigma project. :lol:
Other than the org chart, I have only been changing documents as process change, not people.
msec0990
While I agree that the size of the company and turnover rate can factor in, I don't think it's enough to justify such a practice. It just feels unprofessional to me. As Pancho already mentioned, if you have a good organizational chart you have job titles and structure in place. If not, it would be a great time to implement such a chart. Hopefully, it doesn't become a knock down drag out fight.
One of my former bosses actually implemented the ISO framework when he updated that company's quality manual even though it was a definitely non-ISO environment. This is a bit extreme in my view, but it was what he was experienced in and comfortable with. Besides, I was still the "new guy" and wasn't going to tell him he was wrong :lol: In quality as in life, sometimes what you don't say is as important as what you do say.
Just my thoughts.
Mark
D PPE (Personal Protective Equipment) in the UK CE Marking (Conformité Européene) / CB Scheme 1
E Comparison of Personal Protective Equipment Standards EN 14605 vs GB24539 and ISO 13982 vs GB 24539 Occupational Health & Safety Management Standards 0
P MDR PRRC (person responsible for regulatory compliance) and personal liability EU Medical Device Regulations 3
A OHSAS 18001 external auditor finding personal interpretation? Occupational Health & Safety Management Standards 5
J CE Marking for vibrator personal pleasure toy CE Marking (Conformité Européene) / CB Scheme 16
TheMightyWife Can not start Personal Conversations Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 18
L GDPR scope - "Personal data" definition - General Data Protection Regulation EU Medical Device Regulations 5
K Regional Hosting of Personal Health Information Medical Information Technology, Medical Software and Health Informatics 2
L Requirements for employees personal precision measuring tools ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M AS 4706 (Personal Response Systems) & AS 3811 (Patient Alarm Systems) Equivalents? Other ISO and International Standards and European Regulations 4
J Auditor Training: Examples of Personal Behaviors General Auditing Discussions 10
AnaMariaVR2 Warning Letter to Fercy Personal Care Products - company kicked out FDA Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
Marc Life after the Personal Computer After Work and Weekend Discussion Topics 14
AnaMariaVR2 Change Anything: The New Science of Personal Success [book] The Reading Room 1
S Clean Room Training for Manufacturing Operators (Personal Hygiene, Gowning, etc.) Other Medical Device and Orthopedic Related Topics 4
J Small Company with an established Secretary/Admin person with "Personal" procedures Quality Manager and Management Related Issues 8
B Customer Property Exclusion as it applies to Personal Data ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
E Should I refuse to answer personal questions during the interview? Career and Occupation Discussions 59
L Calibrating Tool Makers Personal Tools General Measurement Device and Calibration Topics 9
ScottK Companies with no receptionist are colder and less personal Career and Occupation Discussions 12
C ISO 17024 - Personal Certifications Programs Checklist Other ISO and International Standards and European Regulations 27
A Personal Data as it pertains to clause 7.5.4 of AS9100C - Definition AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Root Cause Analysis and Personal Blame ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Developing your own personal "Body of Knowledge" document. Professional Certifications and Degrees 3
S Withholding of Information from Employers - Strategic Target or Personal Behavior? Career and Occupation Discussions 14
U Honda U3-X Personal mobility device World News 4
S How to better manage files on a personal computer? After Work and Weekend Discussion Topics 8
A Essential Requirements Checklist for PPE (Personal Protective Equipment) CE Marking (Conformité Européene) / CB Scheme 6
F Personal Notes on Production Floor vs. Documented Work Instructions Document Control Systems, Procedures, Forms and Templates 188
M Your Personal Emergency Preparations Coffee Break and Water Cooler Discussions 15
T On a personal level... Imported Legacy Blogs 1
Claes Gefvenberg Environmental efforts on a personal level Philosophy, Gurus, Innovation and Evolution 30
ScottK Vacation/Sick/Personal days in the USA - how widely do they vary? Career and Occupation Discussions 23
T Document Management Software for Personal Use Coffee Break and Water Cooler Discussions 4
Marc DEC's 'Personal Mainframe' Computer After Work and Weekend Discussion Topics 3
S Does your company allow the use of Personal cell phones during working hours? Coffee Break and Water Cooler Discussions 51
T Personal advice needed on ISO 9001 Quality System and Management ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
O Personal Care/Cosmetics Testing Requirements Manufacturing and Related Processes 1
N Personal Business Software to Track Expenses - I.e. Travel and Business Expenses Career and Occupation Discussions 10
E Sampling Plan for Destructive Testing - Personal Body Armor Plates Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
F Attribute Gage R&R Basis for Applications - Personal Perception Criteria Statistical Analysis Tools, Techniques and SPC 3
L Personal Gages and Calibration - Mold department uses personal gages in some aspects General Measurement Device and Calibration Topics 6
A Personal Organizational Tools - What tools do you use for personal organization? Coffee Break and Water Cooler Discussions 26
A Personal control of design drawings/documents Document Control Systems, Procedures, Forms and Templates 8
W Employee Personal Liability once we get our ISO 14001 up and running ISO 14001:2015 Specific Discussions 1
B ISO 14001 Environmental Policy - Personal Liability - Making Managers Sign Policy ISO 14001:2015 Specific Discussions 4
R Do all personal tools need to be calibrated? Why? General Measurement Device and Calibration Topics 4
P Personal Gages - Do they have to be calibrated and traceable? General Measurement Device and Calibration Topics 4
S One formulation for two products/brand names (MD/cosmetics) EU Medical Device Regulations 0
V Sister companies selling same medical device under different names ISO 13485:2016 - Medical Device Quality Management Systems 3
