Personal Notes on Production Floor vs. Documented Work Instructions
Wes Bucey
#21
Re: Personal Notes on Production Floor
Hehe...that's like one of the 10th commandments of Quality in any system....too bad for those who did not make that clear from the start.
So I guess every operator who starts his machine using his memory without referring to the official WI is in nonconformance? Tsk tsk to all those fork lift operators who don't open up and refer to the WI before moving a skid.
JoCam
#22
To me this is quite simple. A handwritten work instruction does not form a part of the quality management system, and is therefore uncontrolled. It would probably not be reviewed or updated, and could therefore lead to a task being performed incorrectly.
The policy at my Organisation is that uncontrolled documents are not to be referred to and therefore shouldn't exist, meaning that on this occassion a non-conformance would ensue.
Having said this, each Organisation has different ways of doing things, and if there are no policies stating that uncontrolled documents should not be used, then this would not create a non-conformance, just perhaps an opportunity for improvement.
Jo
bobdoering
Stop X-bar/R Madness!!
#23
That's right, they may have found that there is an OSHA required checklist to complete prior to jumping in the seat! Do they have to read it every time? No, not if you have documented training for any of the document changes. Somehow, they must be able to answer the question correctly: "How do you know the current procedure?" or, yes, there is a nonconformance.
Pancho
wikineer
#24
Fascinating thread to read right after the one on the new iPad.
I think if we could make access to the electronic documents at points of use, for read, markup or write, convenient enough and the paper personal notes will disappear.
hogheavenfarm
#25
I think JoCam is on the money. The bottom line is "does the note/memo/whatever" affect product quality, therefore requireing control. My experience is that most notes I see DO affect product quality. Extrusion temperatures, packing notes, bend angles, etc. and yes, different notes by different operators. Frequently changes do occur, and must flow down to the operator. When the operator ignores the intsructions and runs off his own notes, he breaks the chain of communication. We go from a controlled document to an uncontrolled one. Here, every operator has a binder with specific instructions for each job. Every page of that binder is a controlled document, directly affecting product quality. Every process needed to complete the product is spelled out in this binder, (there is a binder for every job). To add personal notes to this circumvents the control, and leaves us wondering what went wrong with the process, when really nothing went wrong, the process wasnt followed.
Sorin
#26
If there is a potential for an impact of the quality of the product/service then the operator shall check the available documentation.
O/c we can go and search for (im)plausible situations and waste our time back and forth, I am right and you are not situations, but the bottom line is that every procedure/instruction with a demonstrated quality impact shall be controlled.
Unfortunately, memory/handwritten notes are not yet controlled.
#27
Howdy folks. I've referenced The Cove many times, but this is a first-timer post.
I performed an internal audit of my production floor the other day. I found some personnel referencing personal notes to do some jobs (such as starting a machine, mixing marking ink, etc.). My company has documented work instructions for these tasks, and the instructions are readily available. Interestingly, the notes were right on track with the documented instructions. Is this a nonconformance?
Thanks, and I look forward to the responses and discussion.
So many good responses already. As usual.
I'm going to just address for a minute the specific items listed above because they are quite different items in my view.
The First, "starting a machine", is something that is "Documented" in the operations manual which may or may not be kept by the machine. In addition, operations manuals can be devilishly hard to use sometimes, especially if they are translations from aonther language.
This instruction is not likely to change during the life of the machine and so crib notes at the machine are probably not a problem.
The next one, "mixing marking ink", can be a bit more problematic. I assume that the mixing instructions for this are on the container the items come in and, again, are unlikely to change. However in this case, a change in supplier, or a change in formula of the ink could cause a change in the instructions that could be missed in the "notes". This certainly could cause a problem and the "notes" should be should be controlled.
Auditing, particularly internal auditing should look at these potentialities, ask questions and then make a rationaljudgement based on the answers received.
Peace
James
BadgerMan
#29
I am surprised that no one has mentioned this yet but.......how about involving the operator in the creation of the work instructions, in accordance with the organization's document control procedure?
SteelMaiden
#30
Oh, how very interesting, you mean that some people don't? If you wait for me to write the work instruction to do your job, you will be waiting for a long, long time.
P MDR PRRC (person responsible for regulatory compliance) and personal liability EU Medical Device Regulations 3
A OHSAS 18001 external auditor finding personal interpretation? Occupational Health & Safety Management Standards 5
J CE Marking for vibrator personal pleasure toy CE Marking (Conformité Européene) / CB Scheme 16
TheMightyWife Can not start Personal Conversations Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 18
L GDPR scope - "Personal data" definition - General Data Protection Regulation EU Medical Device Regulations 5
K Regional Hosting of Personal Health Information Medical Information Technology, Medical Software and Health Informatics 2
A Personal names in docs - Goes against every documenation practice I know! Document Control Systems, Procedures, Forms and Templates 30
L Requirements for employees personal precision measuring tools ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M AS 4706 (Personal Response Systems) & AS 3811 (Patient Alarm Systems) Equivalents? Other ISO and International Standards and European Regulations 4
J Auditor Training: Examples of Personal Behaviors General Auditing Discussions 10
AnaMariaVR2 Warning Letter to Fercy Personal Care Products - company kicked out FDA Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
Marc Life after the Personal Computer After Work and Weekend Discussion Topics 14
AnaMariaVR2 Change Anything: The New Science of Personal Success [book] The Reading Room 1
S Clean Room Training for Manufacturing Operators (Personal Hygiene, Gowning, etc.) Other Medical Device and Orthopedic Related Topics 4
J Small Company with an established Secretary/Admin person with "Personal" procedures Quality Manager and Management Related Issues 8
B Customer Property Exclusion as it applies to Personal Data ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
E Should I refuse to answer personal questions during the interview? Career and Occupation Discussions 59
L Calibrating Tool Makers Personal Tools General Measurement Device and Calibration Topics 9
ScottK Companies with no receptionist are colder and less personal Career and Occupation Discussions 12
C ISO 17024 - Personal Certifications Programs Checklist Other ISO and International Standards and European Regulations 27
A Personal Data as it pertains to clause 7.5.4 of AS9100C - Definition AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Root Cause Analysis and Personal Blame ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Developing your own personal "Body of Knowledge" document. Professional Certifications and Degrees 3
S Withholding of Information from Employers - Strategic Target or Personal Behavior? Career and Occupation Discussions 14
U Honda U3-X Personal mobility device World News 4
S How to better manage files on a personal computer? After Work and Weekend Discussion Topics 8
A Essential Requirements Checklist for PPE (Personal Protective Equipment) CE Marking (Conformité Européene) / CB Scheme 6
M Your Personal Emergency Preparations Coffee Break and Water Cooler Discussions 15
T On a personal level... Imported Legacy Blogs 1
Claes Gefvenberg Environmental efforts on a personal level Philosophy, Gurus, Innovation and Evolution 30
ScottK Vacation/Sick/Personal days in the USA - how widely do they vary? Career and Occupation Discussions 23
T Document Management Software for Personal Use Coffee Break and Water Cooler Discussions 4
Marc DEC's 'Personal Mainframe' Computer After Work and Weekend Discussion Topics 3
S Does your company allow the use of Personal cell phones during working hours? Coffee Break and Water Cooler Discussions 51
T Personal advice needed on ISO 9001 Quality System and Management ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
O Personal Care/Cosmetics Testing Requirements Manufacturing and Related Processes 1
N Personal Business Software to Track Expenses - I.e. Travel and Business Expenses Career and Occupation Discussions 10
E Sampling Plan for Destructive Testing - Personal Body Armor Plates Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
F Attribute Gage R&R Basis for Applications - Personal Perception Criteria Statistical Analysis Tools, Techniques and SPC 3
L Personal Gages and Calibration - Mold department uses personal gages in some aspects General Measurement Device and Calibration Topics 6
A Personal Organizational Tools - What tools do you use for personal organization? Coffee Break and Water Cooler Discussions 26
A Personal control of design drawings/documents Document Control Systems, Procedures, Forms and Templates 8
W Employee Personal Liability once we get our ISO 14001 up and running ISO 14001:2015 Specific Discussions 1
B ISO 14001 Environmental Policy - Personal Liability - Making Managers Sign Policy ISO 14001:2015 Specific Discussions 4
R Do all personal tools need to be calibrated? Why? General Measurement Device and Calibration Topics 4
P Personal Gages - Do they have to be calibrated and traceable? General Measurement Device and Calibration Topics 4
C E signatures on Engineering Change Notes AS9100 / AS9116 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L IATF 16949 Cl. 7.1 - Lotus Notes for Document Control IATF 16949 - Automotive Quality Systems Standard 0
K Accounting for Drawing Notes in PPAP APQP and PPAP 1
E File Notes: planned deviations or acknowledged mistakes? ISO 13485:2016 - Medical Device Quality Management Systems 2
