PFMEA and Semi Conductor Supplement - ISO/TS 16949 Clause 7.3.3.2S
Q
qualityboi
The semi conductor supplement to the ISO/TS 16949 states in 7.3.3.2S
"PFMEAs shall consider processes from incoming material receipt to shipping and warehousing. Mistake proofing tools shall be used to prevent mixed material, wrong labeling and other common shipping,
logistics and storage errors."
Does this mean we need to ahve a PFMEA for shipping, material receipt and warehousing or can we just lump it all into one PFMEA called incoming material or material control process? What do you think?
:thanx:
Bill Ryan - 2007
qualityboi - I moved your thread to this forum so our FMEA gurus might better "find" it and help out.
I don't have a copy of the semi conductor supplement but the verbage sounds awfully close to what needs to/should be followed with any other PFMEA. In my view, it is up to you whether you have a separate PFMEA for each processing step that can produce a Failure Mode, or you can have a "flowing" PFMEA which covers each step from receipt of raw materials to shipping. If you were to go with the "individual" PFMEA scenario, you might have 10 (whatever the end number is) separate PFMEAs for any given product line. That call is entirely up to your organization.
cheahga
Hi Bill,
I've attached the supplement for your review and advice since you're the FMEA guru of this part of the world.....:biglaugh:
The supplement can be downloaded from the AEC website as well. Since the content does not mentioned any copyright, so I would presume it's safe to post it here....
S Initial PFMEA FMEA and Control Plans 6
L PFMEA for test procedures (ISO 14971) ISO 14971 - Medical Device Risk Management 5
K PFMEA Severity (9-1) mitigation needed? FMEA and Control Plans 17
Sonja D AIAG VDA PFMEA and Control Plan training FMEA and Control Plans 6
J Error Proofing sensors in PFMEA FMEA and Control Plans 2
DuncanGibbons Process flow & PFMEA for production planning and simulation activities? Process Maps, Process Mapping and Turtle Diagrams 7
D PFMEA Software search IATF 16949 - Automotive Quality Systems Standard 7
P Benefit risk analysis on pFMEA ISO 14971 - Medical Device Risk Management 9
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 8
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
T Linking Control Plans and PFMEA's FMEA and Control Plans 3
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
A PFMEA new AIAG FMEA and Control Plans 0
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 23
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
A PFMEA English language question IATF 16949 - Automotive Quality Systems Standard 4
S Is there any connection between PFMEA and Acceptance Plan FMEA and Control Plans 1
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
T DFMEA/PFMEA and SCCAF alignment FMEA and Control Plans 19
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
A PFMEA - How long should the recommended actions remain in the recommended actions column? APQP and PPAP 3
S How to fulfill PFMEA "requirement" column? FMEA and Control Plans 2
T Informational Family or Baseline PFMEA Rules FMEA and Control Plans 22
A PFMEA severity score different applications FMEA and Control Plans 11
M Control Method correspondence between PFMEA and CP FMEA and Control Plans 8
W Is the RPN (risk priority number) in the PFMEA really a RPN without the detectability ISO 14971 - Medical Device Risk Management 4
I Making a process PFMEA, no DFMEA (non-automotive toll manufacturer) FMEA and Control Plans 1
Proud Liberal DFMEA / PFMEA linkage - Where in the standards do I find it? FMEA and Control Plans 5
N PQC (Product Quality Characteristics) and PFMEA FMEA and Control Plans 3
N PFMEA Potential Failure Mode for Weight FMEA and Control Plans 5
M I need a sample Reverse PFMEA Process Checklist FMEA and Control Plans 2
C PFMEA example with machining (lathe+mill) FMEA and Control Plans 1
L Simple Example for PFMEA / Control Plan Training Training - Internal, External, Online and Distance Learning 1
