PFMEA Assumption to Exclude Latent Failures
sjqlty
Hello-
Can anyone provide me some insight as to whether it makes sense and is common to exclude latent failures (failures that occur past the point of final manufacturing) as part of a manufacturing PFMEA for a medical device? And why or why not?
It seems to me that while this is drawing a clear line in the sand, it may not address all the risks that the product could experience that we'd want to assess and possibly mitigate.
Other options would be:
1. to exclude latent failures that occur after a short time past the point of sale (to include any shipping and handling related causes past manufacturing).
2. to include latent failures
Thanks!
somashekar
When that latent failure is assessed to be effecting to the risk of patient or user of the medical device, it needs to be included and suitably mitigated based on the risk evaluation.
The focus is risk to patient / user.
Helmut Jilling
Auditor / Consultant
For comparison, in Automotive, the Severity evaluation requires us to consider the severity on the final assembly and on the end user, and take the higher of the two. Thus, an impact on the end user could cause a high Severity, even if iit does not become a problem during manufacturing.
sjqlty
Thanks Helmut-
Please help me understand- I'm a little confused by your response. For a manufacturing PFMEA, isn't the severity always considered from the device end user's perspective (with exception to the case in which there is a risk to an operator of the process for example)? I don't understand what the impact would have on the final assembly, if the product isn't used.
What I was getting at in my question was to include both the effects that occur immediately upon use (or even occur in testing during manufacturing) and those effects that occur later due to some use condition being applied to the device.
For example- a non latent failure would be that an operator forgets to connect a cable (completely unconnected) and the device fails to power ON during testing.
A latent failure example would be that a manufacturing operator only partially connects a connector (it is electrically connected, but not fully latched) and through either vibration during shipping or during early use by an end user, the connector becomes loose and the device won't continue to power ON. I'm curious if this type of failure could be excluded from the PFMEA for any good reason?
Helmut Jilling
Thanks Helmut-
In Automotive, we apply it pretty much as you described, but we consider Severity of failure at Manufacturing, at Assembly, and at the end user. Examples:
The connector is not attached, Failure Effect is the unit will fail final test. Severity might be a 6.
The connector is not fully attached, Failure Effect is the unit will pass the final inspection, but fail in the coming months in the hands of the end user. Severity might be a 7 or 8.
The connector is not fully attached, Failure Effect is the unit could short out and shock the holder, either in final inspection, or in the hands of the end user. Severity might be a 9 or 10 in this case.
The position of Automotive approach, is to consider who could be affected by each Failure Mode, and determine the max Severity on that situation. In other words, it is seeking the "worst case" scenario.
MIREGMGR
Sure, you can include an issue from one section of the overall risk analysis, as long as it's included in another section of that analysis. So, if you want to analyze issues that arise or are fixable during manufacturing in a separate section from those that arise during distribution or use, OK.
Just as long as all patient risk issues are addressed, all the way through use and even beyond use if there are identified risks there.
sjqlty
Ah, gotcha. That clarifies your situation. The bottom line is that you include those failures that occur past manufacturing. I don't see any reason why we wouldn't want to do that, but wanted to throw it out there.
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
T Linking Control Plans and PFMEA's FMEA and Control Plans 3
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
A PFMEA new AIAG FMEA and Control Plans 0
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 23
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
A PFMEA English language question IATF 16949 - Automotive Quality Systems Standard 4
S Is there any connection between PFMEA and Acceptance Plan FMEA and Control Plans 1
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
T DFMEA/PFMEA and SCCAF alignment FMEA and Control Plans 19
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
A PFMEA - How long should the recommended actions remain in the recommended actions column? APQP and PPAP 3
S How to fulfill PFMEA "requirement" column? FMEA and Control Plans 2
T Informational Family or Baseline PFMEA Rules FMEA and Control Plans 22
A PFMEA severity score different applications FMEA and Control Plans 11
M Control Method correspondence between PFMEA and CP FMEA and Control Plans 8
W Is the RPN (risk priority number) in the PFMEA really a RPN without the detectability ISO 14971 - Medical Device Risk Management 4
I Making a process PFMEA, no DFMEA (non-automotive toll manufacturer) FMEA and Control Plans 1
Proud Liberal DFMEA / PFMEA linkage - Where in the standards do I find it? FMEA and Control Plans 5
N PQC (Product Quality Characteristics) and PFMEA FMEA and Control Plans 3
N PFMEA Potential Failure Mode for Weight FMEA and Control Plans 5
M I need a sample Reverse PFMEA Process Checklist FMEA and Control Plans 2
C PFMEA example with machining (lathe+mill) FMEA and Control Plans 1
L Simple Example for PFMEA / Control Plan Training Training - Internal, External, Online and Distance Learning 1
B Proactive efforts to reduce risk - PFMEA risk reduction activities IATF 16949 - Automotive Quality Systems Standard 8
N PFMEA no effect ratings FMEA and Control Plans 15
N DFMEA, Drawings and PFMEA of an Assembly Process FMEA and Control Plans 12
A PFMEA for DC Motor FMEA and Control Plans 5
Crimpshrine13 PFMEA Scope - Oversized Special Characteristic FMEA and Control Plans 4
B PFMEA and Control Plan Links APQP and PPAP 2
B Update our PFMEA after Supplier updates their PFMEA? FMEA and Control Plans 4
Q PFMEA Scope and Detection Controls FMEA and Control Plans 1
