PFMEA Detection Controls and Ranking - Prevent Shipment
Z
Zbigniew Huber
Regarding detection controls in PFMEA the AIAG manual, page 99 says:
When more than one control is identified, it is recommended that the detection ranking of each control be included as part of the description of the control. Record the lowest ranking value in the Detection column.
Assume the failure has occurred and then assess the capabilities of all "Current Process Controls" to prevent shipment of the part having this failure mode.
How to properly interpret the text: “Assume the failure has occurred and then assess the capabilities of all "Current Process Controls" to prevent shipment of the part having this failure mode”
Prevent shipment from one operation to next operation or prevent shipment from the factory/line?
Let’s assume following situation:
A defect occurs at op.80.
The control method for it is visual inspection at op.80, then visual inspection at op.120 and then the failure mode is detected at an EOL (end of line tester) op. 280 with automatic part lock when failed.
I always included all controls for the specific failure mode (when evaluating op.80) in the following manner:
- visual inspection at op.80 (7)
- visual inspection at op.120 (8)
- EOL final test op. 280 (4)
And then the detection ranking in the detection column was 4.
I saw a PFMEA where only detection present at the op.80 was considered as valid for detection ranking for the failure mode (the op.120, and op.280 was not considered at all).
What approach would you recommend?
Al Dyer
Automatic lock on failure at OP 280???
You say you saw a PFMEA where...........??
Sounds like you already have a good handle on your PFMEA structure and control. Don't worry about how others do it, let others ask about how you do it.
These things are so individualized to the specific process, just remember that the end goal is a good part for the customer. Do it your way.
Al...
Z
Zbigniew Huber
Al...
The end of line tester (EOL at station 280) detects the failure mode (missing small part in a manufactured product) and then prevents the defective part from subsequent processing. The failure mode is caused at op.80.
Al...
I saw a PFMEA of very similar process at different company. They also have EOL tester and process is very similar but their PFMEA does not include failure mode detections in subsequent stations (post processing). I would like to know if such approach is correct or not.
Al...
Thanks.
Q PFMEA Scope and Detection Controls FMEA and Control Plans 1
P Detection Rating in PFMEA and Process Controls FMEA and Control Plans 6
J PFMEA Controls - Rating Prevention, Detection and Occurrance FMEA and Control Plans 10
M Changing FMEA template to include Detection Ranking for the PFMEA FMEA and Control Plans 2
A PFMEA (Process FMEA) Detection Rating - Actions to Reduce RPN FMEA and Control Plans 3
Casana Detection level in PFMEA (Process FMEA) - Bulk Fluids FMEA and Control Plans 10
Chennaiite PFMEA rating - Occurence Rating and Detection Rating - Some clarification FMEA and Control Plans 15
C PFMEA (Process FMEA) Detection Scale - Aerospace engine components FMEA and Control Plans 4
V Detection rating for visual inspection in PFMEA FMEA and Control Plans 19
Y PFMEA detection value for checking C of C in receiving inspection FMEA and Control Plans 2
S Detection Criteria Examples - PFMEA (Process FMEA) - Emergency Safety Fixtures FMEA and Control Plans 2
M PFMEA Detection Rating for Operator Hazards FMEA and Control Plans 5
F pFMEA Detection Rating Scale - No automated inspections FMEA and Control Plans 5
R PFMEA - RPN - Severity, Occurrence and Detection - Which one does not change? FMEA and Control Plans 67
M PFMEA Detection Evaluation Criteria - Visual Check - Page 52 of the AIAG FMEA manual FMEA and Control Plans 2
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
T Linking Control Plans and PFMEA's FMEA and Control Plans 3
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
A PFMEA new AIAG FMEA and Control Plans 0
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 23
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
A PFMEA English language question IATF 16949 - Automotive Quality Systems Standard 4
S Is there any connection between PFMEA and Acceptance Plan FMEA and Control Plans 1
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
T DFMEA/PFMEA and SCCAF alignment FMEA and Control Plans 19
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
A PFMEA - How long should the recommended actions remain in the recommended actions column? APQP and PPAP 3
S How to fulfill PFMEA "requirement" column? FMEA and Control Plans 2
T Informational Family or Baseline PFMEA Rules FMEA and Control Plans 22
A PFMEA severity score different applications FMEA and Control Plans 11
M Control Method correspondence between PFMEA and CP FMEA and Control Plans 8
W Is the RPN (risk priority number) in the PFMEA really a RPN without the detectability ISO 14971 - Medical Device Risk Management 4
