PFMEA Detection Evaluation Criteria - Visual Check - Page 52 of the AIAG FMEA manual
  • Thread starter Thread starter Megan
  • Start date Start date
Megan
Please clarify following issue:
page 52 of the FMEA manual, 3 rd edition – column “Current Process Control Detection” states the following:
“Visual check each hour 1/shift for film thickness (depth meter) and coverage”
The detection ranking is 5
Current process control is – preventive maintenance program to maintain heads
Page 53, table 8 of the same manual lists Ranking 5 as Moderate, Inspection type B, which corresponds to gauging (B)
It is confusing to me – example on page 52 uses VISUAL CHECK, while table 8 describes ranking 5 as follows:
“Control is based on variable gauging after parts have left the station, or Go/No Go gauging performed on 100% of the parts after parts have left the station.
Please clarify this issue. Also please elaborate what is considered
“ERROR PROOFED” – process/product design ……….
Megan,
Good morning and welcome to the cove.
I think what they are describing is and this might be a stretch,is:
visually check the spray head each hour to verify that it is fully inserted; once per shift, using a depth meter, check film thickness and coverage.
The rating of 5 is based on the use of the depth meter.
Error proofing is the act of taking action to prevent ( or help prevent)an error. In the case of the spray head a positive stop was added. An electric switch could also be added so that a light would turn on/off when the head was properly seated.
Do a search,here at the cove, for error proofing, mistake proofing and you will find several threads that on this topic.
