pFMEA Detection Rating Scale - No automated inspections
F
fionanm
Hi all,
I wonder if anyone could share a detection rating scale for a pFMEA for a process that does not involve any automted inspections??
thanks
fionanm said:
Hi all,
thanks
Whether or not there is automated inspection has no direct bearing on PFMEA detection ratings. The same scale should be used whether inspection is by human or machines, because the idea is to determine the likelihood that defects will escape detection (or be detected, if you're more of a glass-half-full type:D ).
Bill Ryan - 2007
fionanm said:
Hi all,
thanks
Welcome to the Cove :bigwave:
Here's a copy of one of my customer's rankings table. As Jim alluded to, the table includes both automated and "manual" detections.
F
fionanm
Thanks,
I did think that myself, but every example I come across seems to differenciate between the 2.
fionanm said:
Thanks,
My point was that automated inspection might be more likely to detect defects than human inspection, but the likelhood of detection should be rated using the same scale.
Added in edit: Just to clarify, if you use different scales for automated and human inspection, you have no valid way to compare the two.
A PFMEA (Process FMEA) Detection Rating - Actions to Reduce RPN FMEA and Control Plans 3
P Detection Rating in PFMEA and Process Controls FMEA and Control Plans 6
Chennaiite PFMEA rating - Occurence Rating and Detection Rating - Some clarification FMEA and Control Plans 15
V Detection rating for visual inspection in PFMEA FMEA and Control Plans 19
M PFMEA Detection Rating for Operator Hazards FMEA and Control Plans 5
J PFMEA Controls - Rating Prevention, Detection and Occurrance FMEA and Control Plans 10
Q PFMEA Scope and Detection Controls FMEA and Control Plans 1
M Changing FMEA template to include Detection Ranking for the PFMEA FMEA and Control Plans 2
Z PFMEA Detection Controls and Ranking - Prevent Shipment FMEA and Control Plans 3
Casana Detection level in PFMEA (Process FMEA) - Bulk Fluids FMEA and Control Plans 10
C PFMEA (Process FMEA) Detection Scale - Aerospace engine components FMEA and Control Plans 4
Y PFMEA detection value for checking C of C in receiving inspection FMEA and Control Plans 2
S Detection Criteria Examples - PFMEA (Process FMEA) - Emergency Safety Fixtures FMEA and Control Plans 2
R PFMEA - RPN - Severity, Occurrence and Detection - Which one does not change? FMEA and Control Plans 67
M PFMEA Detection Evaluation Criteria - Visual Check - Page 52 of the AIAG FMEA manual FMEA and Control Plans 2
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
T Linking Control Plans and PFMEA's FMEA and Control Plans 3
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
A PFMEA new AIAG FMEA and Control Plans 0
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 23
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
A PFMEA English language question IATF 16949 - Automotive Quality Systems Standard 4
S Is there any connection between PFMEA and Acceptance Plan FMEA and Control Plans 1
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
T DFMEA/PFMEA and SCCAF alignment FMEA and Control Plans 19
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
A PFMEA - How long should the recommended actions remain in the recommended actions column? APQP and PPAP 3
S How to fulfill PFMEA "requirement" column? FMEA and Control Plans 2
T Informational Family or Baseline PFMEA Rules FMEA and Control Plans 22
A PFMEA severity score different applications FMEA and Control Plans 11
M Control Method correspondence between PFMEA and CP FMEA and Control Plans 8
W Is the RPN (risk priority number) in the PFMEA really a RPN without the detectability ISO 14971 - Medical Device Risk Management 4
