PFMEA example for SMT (Surface Mount Technology)
joewang
Hi! I'm new to FMEA and have read up a bit of FMEA. I was wondering if anyone could provide a PFMEA sample sheet for surface mount. We're a OEM manufacturing memory and I have no idea how to start doing the PFMEA. I know the foamt, but do not know how to categorise as it seems I'm into component level...
Bill Ryan - 2007
Welcome to the Cove :bigwave:
I can't give you an example but I can ask you a couple questions. I have no experience in Surface Mount Technology but if you're stuck with me to help out, you will need to help walk me through your process. I know it involves soldering or radiation of some type to adhere the components, some type of heat treat, and some kind of wash, but that's about the extent of my "knowledge".
* Have you/your team prepared a Process Flow Diagram (from "front door" to "back door"?
* Have you/your team decided whether to base your PFMEA on product characteristics, process characteristics, or both?
* Have you/your team looked at each step in your process and identified how the process can fail to deliver the required product characterisitics? or meet the required output parameters of the process step?
I'm not sure I understand what you mean by "it seems I'm into component level". Are you producing the components or assembling them to the board or both?
joewang
Hi Bill! First of all...a big thank you to replying to this thread! Some heads up of the SMT process:
It includes solder paste printing on a printer, then surface mount components like caps and res and ICs on SMT machines and finally going into a hot air reflow oven to "bake" the solder paste so that it harderns into electronic PCB that we see commonly.
We have prepared a process flow diagram. But, I'm not sure what you mean by front to back door. Do you mean raw materials received from store, get processed and sent back as finished product? If so, then our diagram does not include that. What we've drawn up is only the process for the manufacturing (SMT) part.
What is the difference between PFMEA based on product characteristics and process characteristics? I think we tried to do one based on products. Thats why I wrote we could be into component level FMEA.
We've reviewed the process and listed down the possible failure at each step.
Sorry for asking so many questions as we're new to this FMEA thingy. I really appreciate any help. Thanks. :)
Bill Ryan - 2007
Let's start with the "front" to "back" door. You purchase material and or components ("front" door). Do you have any type of receiving inspection? This should be addressed in the Flow Diagram, PFMEA, and Control Plan. If your automotive customer(s) follow the AIAG guidelines, the receiving step needs to be depicted in all 3 documents - whether there are Failure Modes and Controls identified or not. At the other end ("back" door) you need to identify the steps your shipping dept goes through to loading the truck.
Can you share your Process Flow Diagram? It would make this a bit easier for me to visualize what you are doing.
Regarding the product or process based approach - We employ a product approach. A Failure Mode in our PFMEAs is a nonconformance measureable on the part/product. The Failure Causes are the things in our processing that produce the nonconformance to the part. As an example, an as cast hole diameter can be oversized or undersized (two separate Failure Modes). The Failure Causes are those settings in our die casting process that could be attributed to the out of spec. condition (hot oil temperature, hold time, lube spray time, water flow setting, etc.).
If we were to use the process based approach, the Failure Modes would be hot oil temperature too hot/cold, hold time too long/short, lube spray time too long/short, water flow set too high/low, etc. The Failure Causes would then address how those modes could occur. The product specs. would then be identified in the Effects column. Don't get confused. The product based approach is just our preferred method due to our software (which I rave about at every opportunity).
Am I helping a little bit? Your Flow Diagram and just a partial list of some of your Failures would help me a lot if we are going to get into the nuts and bolts of addressing your process.
Later :bigwave:
Eric ng
Hello Joe, I am also a new comer in Cove Forum. Although I have worked in Electronic Industries for more than 20 years, and also as an FMEA instructor, I have not involved in the development of a process FMEA for SMT processes. If I come across one , will be glade to share it with you. I think the attached files in Cove Forum contained lots of information on FMEA.
I hope, the attached several files from my personal resources do help. Let me know if you need any information on FMEA methodology.
Anyway, it's a pleasure to know you
Eric Ng
(Retired QA Manager, and Training Consultant)
C PFMEA example with machining (lathe+mill) FMEA and Control Plans 1
L Simple Example for PFMEA / Control Plan Training Training - Internal, External, Online and Distance Learning 1
J Example PFMEA for Hydraulic Cylinders wanted FMEA and Control Plans 0
O Need Example PFMEA for Turret Punch Press Manufacturing and Related Processes 2
L Rotational Molding and Machining PFMEA (Process FMEA) - Plastics - example wanted FMEA and Control Plans 6
C Machined Parts PFMEA - Example of a CNC produced part PFMEA wanted FMEA and Control Plans 1
U Example of DFMEA & PFMEA for a throttle body (Butterfly valve) FMEA and Control Plans 2
J Plastics molding control plan and PFMEA - Example wanted FMEA and Control Plans 17
M Example - PFMEA for Machined Parts on CNC Mills & Lathes FMEA and Control Plans 3
S Sheet Metal Fabrication Process FMEA (PFMEA) example needed FMEA and Control Plans 4
K Process FMEA (PFMEA) For Plastic Injection Molding - Seeking Example FMEA and Control Plans 17
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
T Linking Control Plans and PFMEA's FMEA and Control Plans 3
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
A PFMEA new AIAG FMEA and Control Plans 0
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 23
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
A PFMEA English language question IATF 16949 - Automotive Quality Systems Standard 4
S Is there any connection between PFMEA and Acceptance Plan FMEA and Control Plans 1
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
T DFMEA/PFMEA and SCCAF alignment FMEA and Control Plans 19
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
A PFMEA - How long should the recommended actions remain in the recommended actions column? APQP and PPAP 3
S How to fulfill PFMEA "requirement" column? FMEA and Control Plans 2
T Informational Family or Baseline PFMEA Rules FMEA and Control Plans 22
A PFMEA severity score different applications FMEA and Control Plans 11
M Control Method correspondence between PFMEA and CP FMEA and Control Plans 8
W Is the RPN (risk priority number) in the PFMEA really a RPN without the detectability ISO 14971 - Medical Device Risk Management 4
I Making a process PFMEA, no DFMEA (non-automotive toll manufacturer) FMEA and Control Plans 1
Proud Liberal DFMEA / PFMEA linkage - Where in the standards do I find it? FMEA and Control Plans 5
N PQC (Product Quality Characteristics) and PFMEA FMEA and Control Plans 3
N PFMEA Potential Failure Mode for Weight FMEA and Control Plans 5
