PFMEA failure modes for Process Function of Inspection/test
G
GBGYMDAD
What is the general consenus on what the failure modes should be if you have a process step where all you are doing is some type of inspection or test. I was told in a training class by a consulting group that the failure modes should always be "Accept a bad part" or "Reject a good part". Any comments?
Ron Rompen
The failure modes are fairly simple, and I would agree with the two you have listed. Possibly add in one more (Misidentify part).
The more DIFFICULT part of this exercise is to determine the potential failure mechanism, and the prevention and detection controls that are in place.
Having spent years inspecting initial samples, I would agree with that, and can also come up with another failure mode:
Inspection / test not carried out, or incomplete. It's been known to happen... ...for a number of reasons :rolleyes: .
/Claes
Bill Ryan - 2007
Welcome to the Cove, GBGYMDAD :bigwave:
Just a couple of others to consider might be "gage out of calibration/damaged/broken/etc." and "Poka-Yoke not validated".
W
wangxingde
For Visual inspection PFMEA
we have a same situation with your process, and we have some visual inspection, maybe we also should conside operator tiredness? but it difficuld define the Detection, even for other failure modes.
Bill Ryan - 2007
I would tend to look at operator "tiredness" as a Potential Cause as opposed to a Potential Failure Mode. One way to address "tiredness" might be rotation of inspectors/operators.
Just as an FYI - Most of my automotive customers won't accept a Detection index of less than 6 when a visual inspection is involved - and then only with three layers of 100% inspection.
bgwiehle
Inspection and Testing PFMEA
Last year (as a result of the research on the Cove!), we created a number of new PFMEAs, including generic FMEAs for inspection and testing.
The potential failure modes and causes we identified of course would never all be applicable to a particular program or test but during the planning for the cross-functional meeting, I was able to reference examples for most of the scenarios! :bonk:
This PFMEA was intended for internal planning rather than distribution to customers.
B.G. Wiehle
(PFMEA co-ordinator)
Failure modes and causes:
(A) Missed inspection or missed task in list of tasks.
• Wrong frequency or timing, including out-of-sequence.
• Lack of opportunity to do test (can't get parts, access equipment, manpower, communication).
• Operator / inspector error, including wrong assumptions.
• Missing tool/ fixture/ document.
• Changed requirements because of GP-12 or FPSC.
• Test never specified (requirement not documented).
(B) Wrong task completed.
• Wrong frequency
• Similar task substituted.
• Operator / inspector error.
• Missing or wrong criteria.
• Changed requirements because of GP-12 or FPSC added or removed.
(C) Wrong technique.
• Part loaded incorrectly, part test location incorrect.
• Wrong fixturing/ missing fixture.
• Data misinterpreted (gauge scale needs conversion, hard to read)
• Test run incorrectly.
• Wrong sample size.
• Wrong sample selection.
• Wrong sample preparation (cooling, aging, etc.)
• Wrong ambient conditions (temperature, humidity, dust, etc.)
• Test not appropriate for parameter being tested.
(D) Wrong or bad tool used (gauges, measuring equipment, read-outs, etc.).
• Out of calibration / calibrated incorrectly.
• Broken / poorly maintained / dirty.
• Replaced with different model.
• Sensor malfunction (if present)
• Wrong rev level (esp. attribute gauges)
• Reagent shelf-life expired or contaminated (if applicable).
• Low battery (if applicable).
(E) Wrong decision / determination made after inspection / test.
• Criteria too subjective / missing / wrong / still in development.
• Insufficient lighting / lack of contrast surface.
• Decision made by wrong (unauthorized) person (ie. operator or supervisor instead of inspector).
• Inexperienced inspector / operator, including new defects not previously identified.
• Operator / inspector disability (color-blindness, poor vision, illiteracy, innumeracy).
• Determination based on documentation / labeling error.
• Operator / inspector error, including time pressures, lack of commitment to quality, etc.
(F) Test samples / part being inspected not dispositioned properly.
• Defective/ failed parts returned to production.
• Passed parts returned to production downstream of a required operation or test.
• Parts being sorted placed in wrong container (during sorting).
• Parts replaced in wrong container.
• Set-up parts or parts generated during maintenance/ trouble-shooting not segregated as suspect parts.
(G) Test results not acted on (process not adjusted, parts not segregated).
• Operator / supervisor / lead-hand/ facilitator error. Lack of communication.
(H) Test / inspection not documented, or recorded incorrectly (if required).
• Operator / inspector error (including forgot, couldn't find form, didn't know how to fill in form, too long between test & record creation).
• Form missing place to record data due to new or changed requirements (document control issue).
• Record misplaced / sent to wrong location.
Bill Ryan - 2007
Nice list, BG. Looks like your team really put forth some effort. :applause:
Might I ask how your Detection levels panned out for the eight Failure Modes identified (or did you lean more towards the Prevention control side of things)?
P
pthareja
PFMEA's list for inspection and testing.
It is an exhaustive compilation. gr8 work! claps again.
May we add:
( D) Calibration zero error corrections not applied.
ovelap with (G) or (H) can't be ruled out ;-)
Room temperature /environmental situations in say hot & cold junctions or where some chemical reaction or shielding is necessitated are some other FMEA's. More like gage setting correction (like selection of right scale) could be pertinent in deserving cases.
P Thareja
bgwiehle
Thanks!
Most of our Detection ratings on the Inspection & Testing PFMEA are 8 (visual detection), some 9 (random checks). On the prevention side, we identified qualification testing for personnel, adequate training, document control & updating for work instructions and forms, checklists, MSA studies, gauge control, DVP&R (APQP) planning activities, etc.
More and more of our processes supplement operator inspection with set-up & process poka-yokes. Self-checking sensors are now standard for new assembly machines (program logic ensures sensor must cycle every machine cycle and should fail all parts when sensor fails). Automated data gathering is also used when feasible. Always room for improvement!
B.G. Wiehle
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
K MIG Welding Failure Modes and PFMEA Sample Needed ASAP FMEA and Control Plans 10
V Failure Modes & Causes in dFMEA & pFMEA FMEA and Control Plans 3
K Developing a PFMEA - Confused about Potential Failure modes FMEA and Control Plans 7
N PFMEA on lean tools - Failure modes of a PFMEA of the tool "implementation process", FMEA and Control Plans 6
M Family or individual PFMEA's (process failure modes effects analysis)? FMEA and Control Plans 3
A I have two doubts about PFMEA failure modes - How should I describe a "failure mode" FMEA and Control Plans 24
N PFMEA Potential Failure Mode for Weight FMEA and Control Plans 5
Z Failure Mode Identification in PFMEA according to AIAG FMEA Rev.4 FMEA and Control Plans 6
J Should failure mode caused by Fixture problem be into PFMEA? FMEA and Control Plans 2
C DFMEA vs. PFMEA Relationship: The cause in DFMEA becomes Failure in the PFMEA FMEA and Control Plans 2
Ron Rompen Wording of potential cause of failure in a PFMEA FMEA and Control Plans 8
M PFMEA (Process FMEA - Potential Causes and Failure) - Operator's Role FMEA and Control Plans 11
J Product Failure - PFMEA/Control Plan actions FMEA and Control Plans 4
P Problem with "failure mode? interpretation in PFMEA (Process FMEA) FMEA and Control Plans 8
S Process Failure Mode Effects Analysis (PFMEA) Basics FMEA and Control Plans 4
S Basic PFMEA (Process Failure Mode Effects and Analysis) Questions FMEA and Control Plans 22
J Updating a PFMEA (Process FMEA) after a Process Failure FMEA and Control Plans 3
W Plastic Part Painting/Spray Failure Mode - Sample PFMEA or control plan Manufacturing and Related Processes 7
G Mechanical Failure as a Failure Mode in the PFMEA FMEA and Control Plans 28
Y Design (DFMEA) and Process (PFMEA) FMEA Failure Mode Identification Design and Development of Products and Processes 8
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
T Linking Control Plans and PFMEA's FMEA and Control Plans 3
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
A PFMEA new AIAG FMEA and Control Plans 0
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 23
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
A PFMEA English language question IATF 16949 - Automotive Quality Systems Standard 4
S Is there any connection between PFMEA and Acceptance Plan FMEA and Control Plans 1
T DFMEA/PFMEA and SCCAF alignment FMEA and Control Plans 19
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
A PFMEA - How long should the recommended actions remain in the recommended actions column? APQP and PPAP 3
S How to fulfill PFMEA "requirement" column? FMEA and Control Plans 2
T Informational Family or Baseline PFMEA Rules FMEA and Control Plans 22
