PFMEA for a Membrane Assembly - Automotive Application
ROOTS
Can any one help me on the following querry?
We are an ISO/TS 16949 company manufacturing Automotive parts.
We are having different types of process and we have PFMEA for all process.
One of the process is measuring a membrane assembly and the requirement is height of the membrane assembly. The membrane assembly is assembled by spacers and washers and the height will be measured. Due to cumulative tolerance variation in the Spacers / washers, if the height is not achieved the membrane assembly will be reworked to achieve the required height by adding or removing washers. (May be 50% of the assemblies are reworked). The height will be measured 100% for all the membrane assemblies to check whether the height is within the specification. If the height is within the specification then only the assembly will be moved to next operation.
We have prepared a PFMEA stating the Failure mode as "Diaphragm assembly height not within the limit" and given the occurance rating as 1 because all the membrane assemblies are checked 100% for height and none of the assemblies will moved to next operation if the required specification is not met. Hence there is no failure in meeting the height when the assemblies are move to next operation. Whether our understanding is correct or we have to consider the rework at the individual stage and rate the occurance accordingly?
Pl help?
Re: Pfmea
Pl help?
Somewhere within your process there's a cause for the inconsistency in assembly height. If that cause has been identified and it's been decided that the best way to proceed is to measure and adjust (as needed) all assemblies, the fact that an assembly doesn't initially meet the height requirement isn't a "failure"--it's an expected result. It seems to me that your risk is in passing nonconforming assemblies after measurement and adjustment, and from what you say, that risk is negligible and worthy of a relatively low "Occurrence" number. Whether that number is 1 or something higher is a matter of how your rating system is defined.
ScottK
Not out of the crisis
Re: Pfmea
Pl help?
I'm coming from a medical device perspective, but here's my 2 cents:
First - inspection is represented in the Detection number, not Occurrence.
Occurrence would be the 50% rework you say in the first paragraph, which would be a pretty hight number.
Second - I would not give 100% inspection a 1 for detection unless it is fully automated (and validated) inspection. If it's 100% manual inspection I would give it 5 on my scale. Fully Automated inspection is the only way I'd give 1 for detection.
(The scale I use is based on GE Heatlhcare's RPN guide)
Re: Pfmea
Well... I agree that the rating should be low, but suppose the measuring equipment goes awry?
/Claes
Re: Pfmea
Thanks Claes for your reply,
But the measuring equipment is maintained and calibrated with a specified frequency and there is no chance of going away...
Good. I expected as much, :agree1: but with all due respect, there is always a risk (albeit a small one) that something happens to the equipment between calibrations.
/Claes
ROOTS
Re: Pfmea
Thanks ScottK,
As you said we have given the detection rating 5 only and not 1 since this is 100% manual inspection. But i would like to know what the occurance rating has to be given? The confusion is, 50% rework done at this stage, so whether we have to give the rating as high (more than 5) or it is measured and adjusted before passing to next stage, so whether we have to give low occurance rating (i.e 1)
I
Ingo1966
Re: PFEMA for a Membrane Assembly - Automotive Application
as allready stated from the Gentlemen here
WHAT are the CAUSES from the Failure Mode "Diaphragm assembly height not within the limit" ?
There might be several reasons why these Operation failed.
And for these reasons (Causes of the Failure) the Team gives an assesment of how often it happens (Occurence).
Also for every single reason (causes of the Failure) the Team discusses "Clever Prevention" and Dedection for the cause or the subsequent Failure.
ScottK
Re: Pfmea
Thanks ScottK,
Here's how I'm visualizing the flow...
1. Assemble
2. Measure - if with in spec then pass on to next process, if not then...
3. Adjust
4. Measure
5. Pass on to next process
is that about right?
Chennaiite
Never-say-die
Re: Pfmea
This makes lot of sense. It is very important how the Top Management sees the adjustment activity. If the focus is on eliminating or reducing the thing, 'Wrong height' would be the appropriate Failure mode, tolerance stack up - the cause and your occurrence rating shall correspond to 50% rework. Other way around, if adjustment is considered the most feasible option, it becomes part of the process flow and failure mode could read 'wrong height setting' of sorts.
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
T Linking Control Plans and PFMEA's FMEA and Control Plans 3
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
A PFMEA new AIAG FMEA and Control Plans 0
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 23
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
A PFMEA English language question IATF 16949 - Automotive Quality Systems Standard 4
S Is there any connection between PFMEA and Acceptance Plan FMEA and Control Plans 1
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
T DFMEA/PFMEA and SCCAF alignment FMEA and Control Plans 19
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
A PFMEA - How long should the recommended actions remain in the recommended actions column? APQP and PPAP 3
S How to fulfill PFMEA "requirement" column? FMEA and Control Plans 2
T Informational Family or Baseline PFMEA Rules FMEA and Control Plans 22
A PFMEA severity score different applications FMEA and Control Plans 11
M Control Method correspondence between PFMEA and CP FMEA and Control Plans 8
W Is the RPN (risk priority number) in the PFMEA really a RPN without the detectability ISO 14971 - Medical Device Risk Management 4
I Making a process PFMEA, no DFMEA (non-automotive toll manufacturer) FMEA and Control Plans 1
Proud Liberal DFMEA / PFMEA linkage - Where in the standards do I find it? FMEA and Control Plans 5
N PQC (Product Quality Characteristics) and PFMEA FMEA and Control Plans 3
N PFMEA Potential Failure Mode for Weight FMEA and Control Plans 5
M I need a sample Reverse PFMEA Process Checklist FMEA and Control Plans 2
C PFMEA example with machining (lathe+mill) FMEA and Control Plans 1
L Simple Example for PFMEA / Control Plan Training Training - Internal, External, Online and Distance Learning 1
B Proactive efforts to reduce risk - PFMEA risk reduction activities IATF 16949 - Automotive Quality Systems Standard 8
N PFMEA no effect ratings FMEA and Control Plans 15
N DFMEA, Drawings and PFMEA of an Assembly Process FMEA and Control Plans 12
A PFMEA for DC Motor FMEA and Control Plans 5
Crimpshrine13 PFMEA Scope - Oversized Special Characteristic FMEA and Control Plans 4
B PFMEA and Control Plan Links APQP and PPAP 2
B Update our PFMEA after Supplier updates their PFMEA? FMEA and Control Plans 4
Q PFMEA Scope and Detection Controls FMEA and Control Plans 1
