PFMEA for DC Motor
Ambadas Satav
I have to start work on PFMEA for DC Motor. Can any one giude to me how to start? What parameter to be consider etc. etc.
Regards,
Ambadas
Marc
Fully vaccinated are you?
I would like to be able to help, but...
There are many different types of motors and many different processes to make them. Personally I have no experience with making electric motors, but I am sure that while there are surely some processes in common, process equipment will differ. You would have to tell us a lot about the process equipment and the motor its self, as well as the process flow.
Hopefully someone will be able to help, but at this time there isn't much information to start with.
howste
Thaumaturge
The method to start should be the same for all process FMEAs. It doesn't matter if it's a DC Motor, a molded plastic bottle, or an aircraft engine.
Start with the process flow. Break down each step in the flow as detailed as you can and identify what could go wrong (failure mode) at each step. For each failure mode, identify what is the effect and give it a severity ranking (1 to 10 or whatever scale you're using).
For each failure mode identify the cause(s) and give it a ranking (1 to 10) for how often it is expected to occur with the current process.
Now for each failure mode list the controls you have in place that will detect the failure. Give the controls a ranking (1 to 10) for how likely it is to detect the failure.
The Risk Priority Number is calculated by multiplying the severity ranking by the occurrence ranking by the detection ranking.
After you've evaluated the whole process you should identify where the highest risks are and determine actions to take to reduce these risks.
If you don't already have an FMEA manual I would suggest that you get a copy of the AIAG FMEA manual. It has good guidance and tables to use for the rankings.
Marc
Howste is right - That's how you do one, and as you go along you derive what parameter(s) to consider, etc. etc. You should also be drawing from your design FMEA as well.
O Process Flow Diagram, DFMEA, PFMEA, Control Plan integrated softwares FMEA and Control Plans 4
R Installation Activities in pFMEA? FMEA and Control Plans 4
D PFMEA IATF 16949 - Automotive Quality Systems Standard 5
N Must PFMEA Occurrence Factor be Changed Periodically? FMEA and Control Plans 17
A PFMEA - Minor Non-Conformance for field left blank IATF 16949 - Automotive Quality Systems Standard 56
M PFMEA bending of steel tube FMEA and Control Plans 11
I IEC 60812 or ISO 14971 for PFMEA? What should we use? ISO 14971 - Medical Device Risk Management 3
J PFMEA severity with no knowledge of operating conditions FMEA and Control Plans 3
T PFMEA vs MFMEA or DFMEA on equipment/machinery FMEA and Control Plans 19
C Inspection Operation in PFMEA FMEA and Control Plans 13
J PFMEA/control plan question- PLEASE HELP ! IATF 16949 - Automotive Quality Systems Standard 8
C Pass through characteristics on PFMEA FMEA and Control Plans 3
S Initial PFMEA FMEA and Control Plans 6
L PFMEA for test procedures (ISO 14971) ISO 14971 - Medical Device Risk Management 5
K PFMEA Severity (9-1) mitigation needed? FMEA and Control Plans 20
Sonja D AIAG VDA PFMEA and Control Plan training FMEA and Control Plans 9
J Error Proofing sensors in PFMEA FMEA and Control Plans 2
DuncanGibbons Process flow & PFMEA for production planning and simulation activities? Process Maps, Process Mapping and Turtle Diagrams 9
D PFMEA Software search Quality Assurance and Compliance Software Tools and Solutions 8
P Benefit risk analysis on pFMEA ISO 14971 - Medical Device Risk Management 10
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 10
M Material incoming to the production process reflected in PFMEA FMEA and Control Plans 9
T Linking Control Plans and PFMEA's FMEA and Control Plans 3
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
A ISO 14971 PFMEA Manufacturing Risk ISO 14971 - Medical Device Risk Management 2
D Can PFMEA be used in disposition of NC material? ISO 14971 - Medical Device Risk Management 4
A PFMEA new AIAG FMEA and Control Plans 0
Q Is that any difficulty to do software DFMEA and PFMEA in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 28
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
A PFMEA English language question IATF 16949 - Automotive Quality Systems Standard 4
S Is there any connection between PFMEA and Acceptance Plan FMEA and Control Plans 1
N PFMEA repetitive failure modes in subsecuent stations. FMEA and Control Plans 1
T DFMEA/PFMEA and SCCAF alignment FMEA and Control Plans 19
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 6
A PFMEA - How long should the recommended actions remain in the recommended actions column? APQP and PPAP 3
S How to fulfill PFMEA "requirement" column? FMEA and Control Plans 2
T Informational Family or Baseline PFMEA Rules FMEA and Control Plans 22
